343 Pages V « < 324 325 326 327 328 > »
> Rebuiding Inside-out
bkrantz
post Jun 20 2023, 06:54 PM
Post #6501
Mixed with a bit of dye, the oil glows orange.
bkrantz
post Jun 20 2023, 06:55 PM
Post #6502
I poured the entire bottle into the oil fill, and check the UV reaction.
bkrantz
post Jun 20 2023, 06:57 PM
Post #6503
I first ran the engine for about 30 seconds, to see if there is an obvious leak. Underneath with UV light I only found some residue that did not get cleaned off. And no orange.
bkrantz
post Jun 20 2023, 07:00 PM
Post #6504
I then did 60 seconds (idle), 5 minutes (idle), and 5 minutes with some revving up to about 2500 rpm. Nothing visible in UV underneath. I checked the oil on the dipstick and still got some orange, but maybe less than before, and more blue.
bkrantz
post Jun 20 2023, 07:07 PM
Post #6505
I then did two sessions of about 8 to 10 minutes, with running and revving at 3000 to almost 5000 rpm. The temp gauge got into normal warmed-up range, and my new oil pressure gauge showed about 40 psi at 4000 rpm.
Underneath I found a bit of new oil dripped down--but no orange under UV. At this point, any oil, new or old, showed only as blue. This now reduces the utility of the UV.
bkrantz
post Jun 20 2023, 07:11 PM
Post #6506
I spent a lot of time looking with UV, and took a lot of pictures. My best guess is that I have a leak from the upper oil galley plug. Way back I had the original plugs pulled and the case threaded. During my second rebuild, I installed the threaded plugs with Weld-on White Seal Plus thread sealant.
bkrantz
post Jun 20 2023, 07:31 PM
Post #6507
I also found a path of oil on the angular case piece that leads up to the oil cooler. This was not really wet, and the uncertainty about the dyed oil makes me unsure.
bkrantz
post Jun 20 2023, 07:35 PM
Post #6508
Bottom line, I am pretty sure that at least one threaded plug is leaking, and have a maybe on oil cooler seals. When it cools down I will look more carefully.
But I am disappointed that the UV dye gave up its color, and made it harder to recognize new leaks.
930cabman
post Jun 21 2023, 11:15 AM
Post #6509
I feel your pain, built a 2056 and she runs great. Chasing an oil leak in the same area, I found one of the new aluminum tapped plugs was leaking. Completed an (attempted) repair in place. Thought I had it, but I am still getting a small leak in the same area.
Puebloswatcop
post Jun 21 2023, 05:05 PM
Post #6510
Bob, Sorry you didn't have better luck with the UV dye. I have had good success in the past, so not sure why it didn't produce better results. I hope you can at least seal up the oil plug leak.
bkrantz
post Jun 22 2023, 08:48 PM
Post #6511
I took another look today, with regular light. Here is the biggest oil drip, which I think came from the galley plug.
bkrantz
post Jun 22 2023, 08:49 PM
Post #6512
Hard to see, but a possible second leak might be from the oil cooler seals.
bkrantz
post Jun 22 2023, 08:50 PM
Post #6513
And so I stripped everything off the top of the motor, and disconnected all wires, cables, and fuel lines.
bkrantz
post Jun 22 2023, 08:52 PM
Post #6514
This time I put a bright red rag in the oil filler cavity. You might remember that last time I tucked a paper towel in there, forgot about it, and then tried to fill the engine with oil and made a BIG mess.
bkrantz
post Jun 22 2023, 08:54 PM
Post #6515
Underneath, I removed the muffler, shift rod, and some sheet metal, and disconnected all the cables and half-shafts. I then got my plywood cradle and motorcycle jack in place.
bkrantz
post Jun 22 2023, 08:56 PM
Post #6516
A piece of cardboard on each side to protect the sheet metal from the nuts in the trailing arm pivots.
bkrantz
post Jun 22 2023, 08:59 PM
Post #6517
Then time to undo the cross beam bolts and the transaxle mount bolts, and lower the engine down. It took me about 4 hours, taking my time and with a few distractions.
bkrantz
Post #6518
Ready for the second attempt to find and fix oil leaks.
Cairo94507
post Jun 23 2023, 07:55 AM
Post #6519
Michael
Man, I feel for you. Gotta love your determination chasing that leak.
I still have a couple on my car but they will have to wait until we drop the motor/transaxle to address them. Maybe over the winter that will happen. Right now I get 2 dime-sized drips when parked after a week or so. No where near how bad it was as we solved a few of the easy to do leaks. (IMG:style_emoticons/default/beerchug.gif)
Puebloswatcop
post Jun 23 2023, 04:52 PM
Post #6520
Bob, I gotta say your love and dedication to this car is awesome. Don't give up, I know you will track this down
- Lo-Fi Version Time is now: 19th April 2025 - 05:51 PM
