bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,341 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
OK, here with go. Wait for a surprise(?) ending.
First I took off the front sheet metal, alternator, and blower housing. Looking around, not much I did not see from underneath. Attached thumbnail(s) ![]() |
bkrantz |
Under UV, the same indication that the galley plugs leaked.
bkrantz |
No indication of leaks from the front seal.
bkrantz |
Some older-looking oil on the case flange and the left motor mount. I think this is left over from the topside spill.
bkrantz |
Also left-over(?) oil on the rubber.
bkrantz |
Again the front seal looks dry--yay!
bkrantz |
Looks like the stock front plug is also leaking.
bkrantz |
Oil pooled on top of the filter, almost certainly from above.
bkrantz |
As planned I went to remove the oil cooler, but the bracket for the Hall sensor is in the way. So another part comes off.
bkrantz |
The cooler seals actually look pretty good. But there's a clue from up above the cooler.
bkrantz |
Yup, there's my creative plumbing for the dual oil pressure senders. I guess I have been in denial about the potential for this to leak.
bkrantz |
No denying now--this looks like a real leak.
bkrantz |
Looks leaky and cruddy.
bkrantz |
I pulled all the sheet metal on the right side for better access.
bkrantz |
And the oil filter mount. This gasket looks good.
bkrantz |
And finally the galley plugs. The upper one looks wet.
bkrantz |
And the lower one, too.
bkrantz |
And the stock plug.
bkrantz |
But the smaller plug on the right side, on the casting for the oil cooler mount, looks dry.
bkrantz |
I have to think about what to do with the oil pressure senders, but replacing the galley plugs should be easy, right?
Here is what I used last time. Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 19th April 2025 - 03:03 PM |
