Rebuiding Inside-out |
bkrantz |
Mar 24 2024, 08:08 PM
914 Guru Group: Members Posts: 8,150 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Last bits to remove: the latch cover plates.
Attached thumbnail(s) |
bkrantz |
Mar 24 2024, 08:09 PM
The mounting ears were bent out. I took the chance and bent them back in, which helped with the fit in the new pad. I also has to trim the corners in the pad recesses.
bkrantz |
Mar 24 2024, 08:10 PM
I also had to trim the corners in the new pad recesses, to make them more angular.
bkrantz |
Mar 24 2024, 08:11 PM
Final adjustment: take a bit off the sharp corners of the mounting ears.
bkrantz |
Mar 24 2024, 08:13 PM
Not 100% but pretty good. I did have to drill holes for the mounting ear screws.
bkrantz |
Mar 24 2024, 08:14 PM
Installed. I did have to punch a few new screw holes in the targa bar.
bkrantz |
View from the other side.
bkrantz |
Mar 24 2024, 08:15 PM
No cracks--very happy! (IMG:style_emoticons/default/cheer.gif)
bkrantz |
Mar 24 2024, 08:16 PM
First task in 2024 done. Now, can I keep the momentum?
930cabman |
Mar 25 2024, 04:52 AM
Advanced Member Group: Members Posts: 3,697 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Depends if you are able to get your grandkids involved in your "hobby"
btw: lookin good |
Cairo94507 |
Mar 25 2024, 07:00 AM
Michael Group: Members Posts: 10,094 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Very nicely done. The remainder of the list should be a breeze for you. (IMG:style_emoticons/default/beerchug.gif)
Dion |
Mar 25 2024, 02:44 PM
RN Group: Members Posts: 2,801 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Targa bar looks great.
bkrantz |
Mar 25 2024, 08:22 PM
bkrantz |
Mar 30 2024, 06:37 PM
Time to install the towing tie-downs (more later). I got the 914 up on jack stands for the first time in 2024.
bkrantz |
Mar 30 2024, 06:42 PM
Here are the rear tie downs. These mount on the shock lower bolt.
bkrantz |
Mar 30 2024, 06:43 PM
Step 1: pop off the rear sway bar links. A good use for the ol' ball joint fork.
bkrantz |
Mar 30 2024, 06:44 PM
To make clearance, I lowered the shock-spring assembly after unbolting the top mount.
bkrantz |
Mar 30 2024, 06:45 PM
With the trailing arm lowered, and the nut undone, the big bolt slides out.
nivekdodge |
Member Group: Members Posts: 273 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region |
Bob
I used 3M 8857 for a lot of rubber repairs and it seems to work well, except in extreme heat, and is sandable to make it nicer looking Kevin |
bkrantz |
Mar 30 2024, 06:46 PM
Here's the tie down on the bolt.
Lo-Fi Version | Time is now: 24th November 2024 - 11:51 PM |
