343 Pages V « < 35 36 37 38 39 > »
> Rebuiding Inside-out
bkrantz
post Jun 1 2020, 08:49 PM
Post #721
I got through grinding all the remaining welds on the body today--job done!
bkrantz
post Jun 1 2020, 08:51 PM
Post #722
And then a short interlude, to remove the grill from the engine lid. Note the custom location for the model and engine numbers. (The PO installed a reflector across the rear panel)
bkrantz
post Jun 1 2020, 08:52 PM
Post #723
And now on to the final job before sending the car to the paint shop: doors.
Here are the good doors, including a donor for the left side.
bkrantz
post Jun 1 2020, 08:54 PM
Post #724
Here's the original left door. When I peeked inside months ago, I found some wrinkly metal. So more bondo.
bkrantz
post Jun 1 2020, 08:55 PM
Post #725
And the botched repair led to some rust along the bottom edge.
Lilchopshop
post Jun 2 2020, 10:14 AM
Post #726
QUOTE(bkrantz @ Jun 1 2020, 10:47 PM) *
QUOTE(Lilchopshop @ Jun 1 2020, 01:04 PM) *
I notice you’re using an electric die grinder with carbide burrs. How do you like this setup for grinding welds? I’ve been alternating between using a 4.5 inch angle grinder and a dremel tool with a cutoff wheel for grinding welds. The dremel tool is great for precise control, but it’s very slow. Been contemplating buying the same tools you show in your pictures.
Thanks,
I like it very much. It cuts quicker (beware!) and reaches into corners. Of course, it also leaves a more irregular surface unless I am VERY patient and careful.
Thank you. I ordered my electric die grinder and set of carbide burrs this morning. Hopefully they will lessen the chore of weld grinding a little bit. (IMG:style_emoticons/default/sad.gif)
mbseto
post Jun 2 2020, 11:17 AM
Post #727
Pferd makes a set of wheels called CC-GRIND for your angle grinder. For weld grinding, these things are pretty amazing. Turned a task I dread into one I can tolerate.
bkrantz
post Jun 2 2020, 07:54 PM
Post #728
QUOTE(mbseto @ Jun 2 2020, 11:17 AM) *
Thanks--looks interesting. When possible I use a flap disk (mostly 60 grit).
bkrantz
post Jun 2 2020, 07:56 PM
Post #729
I got the right door stripped down today, removing the glass, frame and guides, the winding mechanism, and the lock. Amazing how little the bare door weighs.
bkrantz
post Jun 2 2020, 07:57 PM
Post #730
This door has a bit of surface rust in the weatherstrip channel along the bottom, but nothing significant.
bkrantz
post Jun 2 2020, 08:01 PM
Post #731
The only work to do is fixing the mirror holes. The PO had aftermarket mirrors (cheap Vitaloni copies). I need to weld the forward hole, and rescue the stock rear hole with internal nut. (And open up the other stock hole.)
bkrantz
post Jun 2 2020, 08:02 PM
Post #732
BTW, here is the new list--and progress.
dereknlee
post Jun 2 2020, 10:31 PM
Post #733
Looks good, great work. That electric die grinder looks pretty handy - as someone who doesn't have a compressor big enough to run air tools. Will have to look into that. Keep it up!
-Derek
bkrantz
post Jun 3 2020, 09:03 PM
Post #734
I also have compressor limitations. And I bought the big electric die grinder after burning out multiple Dremel tools.
bkrantz
post Jun 3 2020, 09:06 PM
Post #735
I got the left door stripped today. This is a donor door to replace the original, which has to much collision damage and rust.
bkrantz
post Jun 3 2020, 09:07 PM
Post #736
This door has the internal collision beam. The original doors did not (October 1972 build date). BTW the beam adds about 14 lbs to the door shell, 35 lbs vs. 21 lbs.
bkrantz
post Jun 3 2020, 09:08 PM
Post #737
The donor door also has a pretty thick undercoat layer. I assume this was not factory.
bkrantz
post Jun 3 2020, 09:09 PM
Post #738
And this door has some rust along the bottom channel seam. Have to decide how to fix this.
bkrantz
post Jun 3 2020, 09:10 PM
Post #739
An update on the list.
bbrock
post Jun 3 2020, 10:03 PM
Post #740
All the doors I've seen had that undercoating. I think it was sprayed in as a sound deadener but don't quote me on that.
- Lo-Fi Version Time is now: 20th April 2025 - 12:49 PM
