343 Pages V « < 3 4 5 6 7 > »
> Rebuiding Inside-out
bkrantz
post Dec 26 2019, 09:11 PM
Post #81
Left side needed a 3/4 inch wide filler for the gap in the raised ridge below the tail light. Looks a bit crude, but will be better after grinding.
bkrantz
post Dec 26 2019, 09:12 PM
Post #82
Same on the right side, but the gap was only 3/16 inch.
bkrantz
post Dec 26 2019, 09:14 PM
Post #83
And what was the lap joint in the front panel, now ready for a tidy butt joint weld.
FourBlades
post Dec 27 2019, 09:47 AM
Post #84
From Wreck to Rockin
Nice work! (IMG:style_emoticons/default/first.gif)
Great to fix things the correct way.
You are making rapid progress.
These cars are worth much more now then they were when new, kind of ironic.
John
bkrantz
post Dec 27 2019, 09:48 PM
Post #85
QUOTE(FourBlades @ Dec 27 2019, 08:47 AM) *
John
Thanks. It is fun indulging my sense of "doing it right", even if my skills are not pro level. And while I do not expect to make money, at least the hole will not be too deep.
bkrantz
post Dec 27 2019, 09:52 PM
Post #86
Getting the front seam stitched up, along with the horizontal brace (it needs a patch to fill the gap in the center).
bkrantz
post Dec 27 2019, 09:57 PM
Post #87
Here are the accessory pieces I made for the rear: heavy gauge L-brackets for the bumper mounting holes below the floor, light gauge reinforcements for the holes above the floor, and reinforcing patches for the floor above the rear sway bar brackets.
Kansas 914
post Dec 28 2019, 06:29 AM
Post #88
Bob - you are doing everything right.
It was nice to see the progress in person Friday.
Keep up the great work and let me know if you need another set of hands after your son leaves.
FourBlades
post Dec 28 2019, 08:28 AM
Post #89
What are the reinforcement pieces for?
John
bkrantz
post Dec 28 2019, 09:45 PM
Post #90
John, the 1/8 inch thick L-braces are for the bumper mount holes under the trunk floor. They replace original factory braces that were pressed in a design too hard for me to duplicate. I created my own 18 gauge rectangular reinforcement for the upper holes. These have no big hole in the center yet. And the trapezoidal pieces double up the floor above the sway bar brackets that mount on the underside of the trunk floor.
bkrantz
post Dec 28 2019, 09:48 PM
Post #91
Got the trunk floor welded in, with plug welds all around, and some creative thick beads in the rear corners (these will get ground down).
bkrantz
post Dec 28 2019, 09:50 PM
Post #92
Lower bumper mount hole reinforcement, using 1/8 inch flat bar to replace the factory L-brace.
bkrantz
post Dec 28 2019, 09:51 PM
Post #93
And my own additional brace for the upper bumper mount hole, to double the metal and add strength.
bkrantz
post Dec 28 2019, 09:54 PM
Post #94
And a simple bent strip to bridge the gap between the left and right horizontal braces in the front trunk.
bkrantz
post Dec 28 2019, 09:57 PM
Post #95
Now the fun part: fabricating brackets from 2 inch square tubing to attache the car to the rotisserie lift using the bumper mount holes. This is the back.
bkrantz
post Dec 28 2019, 09:58 PM
Post #96
And the front, where greater curvature requires longer stand-off.
bkrantz
post Dec 28 2019, 09:59 PM
Post #97
Here's the rear, with the horizontal mount from the lift bolted on.
bkrantz
post Dec 28 2019, 10:02 PM
Post #98
Finally! The car is on the rotisserie lift. This was the big milestone I hoped for, with my son visiting for 2 weeks. His willingness to help, and welding skills, made it possible.
ndfrigi
post Dec 28 2019, 10:10 PM
Post #99
wow @bkrantz you and your son are doing a lot of accomplishment each day! keep up the pace and for sure next summer the car will be on the road. thanks for sharing all the details!
bkrantz
post Dec 29 2019, 10:03 PM
Post #100
Final steps. First, we detached the suspension--took the front out as one assembly, including the steering rack. Then some final adjustment of the lift, and the car spins nicely onto its side.
- Lo-Fi Version Time is now: 4th April 2025 - 01:41 AM
