bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,342 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
So, after removing the 6 main case bolts, and undoing 20 fasteners around the perimeter and elsewhere, I am ready to split the case. But the seam is resisting.
Attached thumbnail(s) ![]() |
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
![]() I'd bet something like this could split the case halves..... (IMG:style_emoticons/default/shades.gif) |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,272 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Did you get the bolt that goes through the windage tray? It is between the two cylinder spigots in a recess.
Kansas 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains ![]() ![]() |
bkrantz |
All the bolts were out (I counted them at least a dozen times).
I tried the method of prying between the front shaft impeller flange and the front seal. After a gentle pry, the seam opened up along the front, but the back was still stuck. I resorted to some plastic wedges (door frame shims), and that did the trick. Attached thumbnail(s) ![]() |
bkrantz |
Inside the case looks very good. Left side.
bkrantz |
Right side.
bkrantz |
Number 2 bearing looks good.
bkrantz |
Cam bearings also look good.
bkrantz |
The cam lobes look very good.
bkrantz |
But the bolt-on cam is not stock, right?
bkrantz |
The crankshaft, fully assembled.
bkrantz |
The number 1 bearing and journal.
bkrantz |
Rigged up to pull the camshaft drive gear.
bkrantz |
The gear itself looks very good.
bkrantz |
Time to remove the connecting rods.
bkrantz |
The number 1 con rod bearing looks good.
bkrantz |
But the number 2 bearing shows a bit more wear. This is the worst one.
bkrantz |
All the crank journals look great.
After a quick measuring session, the mains are about 2.3520 inches, suggesting these were ground one step undersize. And the con rod journals are about 1.959 inches, two steps undersize. Attached thumbnail(s) ![]() |
bkrantz |
A bit more tinkering today, starting with removing the oil pressure relief valve. Step one was to make a tool to fit the slot profile in the cap.
Lo-Fi Version | Time is now: 21st April 2025 - 09:10 AM |
