bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,342 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Then a bit of welding.
Attached thumbnail(s) ![]() |
bkrantz |
And grinding. I will give this another pass, since I plan to powder-coat the engine sheet metal so can't use filler.
bkrantz |
Today, after 2 more rounds of weld and grind. I think this is good enough, and ready for the powder coat shop.
bkrantz |
And also another round of paint stripper on the outer blower housing. Not sure what will come next.
bkrantz |
And then I opened the dreaded box I have ignored for months.
bkrantz |
The engine/FI harness is in pretty good shape, but needs all new connector boots.
bkrantz |
The main harness has several PO modifications.
bkrantz |
Another
bkrantz |
And another
bkrantz |
I stopped by the body shop again today, which is about 3 weeks since they started work.
bkrantz |
They are almost done with the second phase of filler, getting the surface smoothness and contours precise.
bkrantz |
With luck, the car will be in primer in a few days.
Frankvw |
working on my first 914 ! ![]() ![]() ![]() Group: Members Posts: 653 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe ![]() |
nice to see this progress, and good luck with the wireloom ! although it has some PO-modifications, it does not look too bad (from the pics at least). Good that you have created a space for it to work on !!
bkrantz |
nice to see this progress, and good luck with the wireloom ! although it has some PO-modifications, it does not look too bad (from the pics at least). Good that you have created a space for it to work on !! Thanks. I took a more careful look, and removed most non-stock coverings. I flagged all the problems with blue tape, and then chickened out and put it back in the box. Attached thumbnail(s) ![]() |
bkrantz |
I also wanted to clear my table so I could lay out the suspension. Here are all the parts as they came off the car last September.
bkrantz |
I surveyed everything and spotted some minor problems, including worn and loose bushings and a beat-up steering rack boot flange.
bkrantz |
I took apart the front struts. Interesting inserts, and look relatively new.
bkrantz |
Unfortunately, the left strut housing has a bigger problem: the threads on the inside are worn away on one side. My guess is that the original insert got loose and wore away the threads.
bkrantz |
I will need to replace this. Any specific years that match (or not) my 1973? Here's the only number I could find on the strut housing.
bkrantz |
I had a busy day taking the suspension components apart. Here's my method for removing the end fittings and bushings on the front A-arm: using my cheater extension to rotate and twist the fitting off.
Lo-Fi Version | Time is now: 21st April 2025 - 01:57 PM |
