Thursday, 3 April 2025 |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,764 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Nice Upgrade !!!
Charles Freeborn |
Member ![]() ![]() Group: Members Posts: 276 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest ![]() |
Sweet!
If you'd be interested in selling the T4 engine separate from the car let me know. |
infraredcalvin |
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,615 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California ![]() ![]() |
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,965 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
Congrats on your new beast @infraredcalvin
Maybe you can show your new car on the coming SoCal meet in San Dimas. |
infraredcalvin |
Thanks, I’d like to, but I’m still trying to get her sorted. Finding out there is no easy way to change the lower spark plugs without dropping the engine. It’s coming out anyway, valve job and closeup inspection as she’s been sitting awhile. Once done you’ll see her on the street as well as the track.
infraredcalvin |
Who would have thought spark plugs would be on back order... yanked the motor, did the valves, spot on, took a look inside, I think I still see assembly lube... how many miles are on this engine???
![]() Decided to do a leak down test as well... at 70, 90, and 100 psi I got less than 1% leak down on all cylinders (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) this thing is near new! ![]() Ordered valve cover seals, will button her back up. |
Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,729 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Score!
Justinp71 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,623 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None ![]() ![]() |
Nice Motor! What are the specs on it (size, cams, etc...)? |
infraredcalvin |
Motor came with limited info, but finding notes referencing:
3.4 max moritz 9.8 comp pistons with 964 cam 46 ida Webers Electromotive HPV-1 dual plug ignition Once I get it dialed in at the track I’ll get it up for some dyno pulls |
Tdskip |
I have 964 cams in the ‘74 911 with the 3.2, they work well.
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,616 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
Wow congrats, that looks like a lot of fun!
slivel |
Old car....... older driver ![]() ![]() ![]() Group: Members Posts: 528 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California ![]() |
Motor came with limited info, but finding notes referencing: 3.4 max moritz 9.8 comp pistons with 964 cam 46 ida Webers Electromotive HPV-1 dual plug ignition Once I get it dialed in at the track I’ll get it up for some dyno pulls Similar build as my engine except I have GE 80 cams. For comparison, mine made 290 at the wheels. |
infraredcalvin |
Got motor back in, everything hooked up, 6 qts of VR1 for starters, immediately fired, but took about 10 tries to prime the carbs before she stayed running.
Was sitting in the car keeping the rpms up when I started hearing loud popping and what I assumed were engine bits being thrown to the floor... Turns out it was this... ![]() A crew is retrofitting the lights in the warehouse, these were stacked on the W/D near the rear of the car, the exhaust vibrated them off. (IMG:style_emoticons/default/lol-2.gif) |
Charles Freeborn |
Got motor back in, everything hooked up, 6 qts of VR1 for starters, immediately fired, but took about 10 tries to prime the carbs before she stayed running. Was sitting in the car keeping the rpms up when I started hearing loud popping and what I assumed were engine bits being thrown to the floor... Turns out it was this... ![]() A crew is retrofitting the lights in the warehouse, these were stacked on the W/D near the rear of the car, the exhaust vibrated them off. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) The beast ROARS! |
infraredcalvin |
https://www.youtube.com/watch?v=JZiq93JBxTY I was able to tune most of the popping and hacking out, but on three of the 6, idle mixture had no effect, time to start taking apart and cleaning out... |
infraredcalvin |
Still have the 4, finally got my new FAT build back. According to the builder, this is what 180 horses looks like...
![]() (IMG:style_emoticons/default/idea.gif) This car is so fun and lightweight, I’m going to have a hard time putting it up for sale... |
Justinp71 |
https://www.youtube.com/watch?v=JZiq93JBxTY I was able to tune most of the popping and hacking out, but on three of the 6, idle mixture had no effect, time to start taking apart and cleaning out... Start with just cleaning the idle jets if you haven't already... Then if needed pull out the idle mixture screws (with idle jets out) and blow out with carb cleaner. |
infraredcalvin |
Thanks, I ended up, rebuilding the carbs, glad I did as some of the gaskets were ready to start leaking. It also gave me some piece of mind that gaskets were not the culprit for my current tuning issues.
![]() I was still getting spits and misses, worse than before, so I attached my lm2 data logger and pulled spark plugs. She was running pig rich across the board. PO had notes about finally getting the carbs dialed in, so I was trusting his base settings, my gut kept telling me everything was too big... Venturis: 42 Main jets 170 Idle jets 55 Emulsion tubes F7 I finally got the balls to change main jets to 160 and idles to 50, wow what a difference! No more popping and missing, still rich, but no flat spots where the motor was getting bogged by fuel, moving closer to the sweet spot. I started having issues with my lm2, so I installed a permanent afr gauge in the cockpit. No data logging, but I can start fine tuning now... anyone know any good carb tuners? Looks like I’m going to make it to big Willow the weekend of the 15th... looking for a trailer to rent also... My girls wanted to see some purple on the car so I’m playing with livery schemes on photoshop. ![]() |
Justinp71 |
Fyi, they run rich all the time. This is so the transition from idle to main circuit is smooth. These were designed for max power and with economy not in mind. You sound like you have it tuned fairly well.
IMHO main thing is to have it in the 12's or low 13's AFR at full throttle in the high RPM band, then you won't do any damage to the motor. I'm only running 160 mains on my 3.2 to give it 12.8 -13.4 AFR (@68f outside air temp) at the high end which is good. This motor has cams and headers, should be about 280hp. I would think you might need larger jets? It also depends on on your air jet sizes too, mine are 190. I have F11 emulsions, I thought about trying F7's but it is running good right now just wish it was a little leaner at idle and cruise (12 afr best case). |
Justinp71 |
Also I'd just drive it to the raceway... much more fun! Get AAA 200 mile incase of a mechanical breakdown. Only thing to consider if you do break on the raceway AAA may not tow you out of the raceway not sure. I've done about a half dozen track days this way. Would probably be nice to eventually get your own small 914 size trailer if you go alot.
Lo-Fi Version | Time is now: 3rd April 2025 - 03:52 PM |
