Restoration Literati914 Build, A clipped car rebuild |
Literati914 |
Oct 29 2021, 08:09 PM
Senior Member Group: Members Posts: 1,777 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
done with that:
Attached thumbnail(s) |
Literati914 |
Oct 29 2021, 08:12 PM
Finally, I replaced the lid to the factory access hole, welding it - just ‘cause (IMG:style_emoticons/default/confused24.gif)
Literati914 |
Nov 2 2021, 08:11 PM
Time for installing seat brackets and hinges to the floor. Here again I’m reusing the old hinges, all except one which was too rusted. There was more prep to getting these ready for welding than I assumed. So it took a couple days and both times I finished near dark.. therefor the welds were a bit chunky but the brackets ain’t going nowhere!
Literati914 |
Nov 2 2021, 08:16 PM
Drivers side done. Had to install the brackets to the bottom of the Large seat rail assembly, then fit the middle adjuster in place to get the correct placement of the floor brackets before welding (as advised).
Literati914 |
Nov 2 2021, 08:17 PM
Passenger Side prepared for brackets:
Literati914 |
Nov 2 2021, 08:20 PM
Note: I believe you could measure 11” from the crossmember back to the middle of the pivot pin on the floor hinge and get a proper placement, but YMMV
..and, done: Attached thumbnail(s) |
autopro |
Nov 3 2021, 12:55 PM
Member Group: Members Posts: 306 Joined: 14-January 18 From: San Diego / Tijuana Member No.: 21,797 Region Association: Southern California |
Great! Glad it worked out for you.
Literati914 |
Nov 5 2021, 08:26 PM
My stock jack points both needed a little work, neither were really all that bad but the outer shells both had some rusted out areas. Here’s where I cut away the bad area on the passenger side:
Literati914 |
Nov 5 2021, 08:28 PM
The metal was pitted so I found a convenient piece of left over sheet metal to overlay and hopefully prolong the life of this area:
Literati914 |
Nov 5 2021, 08:29 PM
Welded it in and smoothed it out a little :
Literati914 |
Nov 5 2021, 08:33 PM
Sprayed some protective paint inside the cavity and cut the needed section from a RD piece I’d picked up some time back:
Literati914 |
Nov 5 2021, 08:34 PM
Passenger side done:
Literati914 |
Nov 5 2021, 08:36 PM
Literati914 |
Nov 5 2021, 08:38 PM
Cut it open, painted cavity with rust incapcilater:
Literati914 |
Nov 5 2021, 08:40 PM
Driver side welded up:
Literati914 |
Nov 5 2021, 08:42 PM
Then I fabricated (IMG:style_emoticons/default/biggrin.gif) the tab that sits above the parking brake cable holes:
Literati914 |
Nov 5 2021, 08:43 PM
Hope I got it stuck in the right place cause it was dark when I welded it in:
Literati914 |
Nov 5 2021, 08:47 PM
And just cause I’m a glutton for punishment, I decided to continue my welding in the dark non-sense! This time, the thin little metal strap for holding down the wiring under the passenger seat:
Literati914 |
Nov 15 2021, 09:29 PM
Next on the agenda is to repair the rusted out area that the frunk handle pull mounts to.. under the dash on the driver’s side. I made this repair over a few days work. First picture highlights the rusted out holes, but the area in between was pitted and thin so I opted to cut a large area out:
Literati914 |
Nov 15 2021, 09:31 PM
Same area from the topside:
Lo-Fi Version | Time is now: 22nd December 2024 - 05:50 AM |
