Restoration Literati914 Build, A clipped car rebuild |
Literati914 |
Dec 12 2021, 06:51 PM
Senior Member Group: Members Posts: 1,778 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Been away from this project for a while, but got back on it the other day. This time I addressed the holes that were drilled in the rear center panel when a previous owner mounted one of the long reflectors (w/ Porsche script). I began this repair yesterday after I’d misplaced my phone (camera) for half the day, so no before shots unfortunately.. and no pics where I filled the holes with metal and welded them closed. Here’s a pic of the area leveled with FG filler though:
Attached thumbnail(s) |
Literati914 |
Dec 12 2021, 06:53 PM
Lightly primed.. and check this one off the list. Next is on to the seal channel for the front trunk (frunk (IMG:style_emoticons/default/rolleyes.gif) )
Literati914 |
Dec 17 2021, 11:06 PM
Next, I needed to fix all the holes in the front part of the seal channel for the frunk.. including the perimeters of the headlight bucket areas. Here’s some before shots showing some of the rusted parts.
Literati914 |
Dec 17 2021, 11:08 PM
More ugly :
Literati914 |
Dec 17 2021, 11:10 PM
Literati914 |
Dec 17 2021, 11:17 PM
Some typical repair techniques performed :
Literati914 |
Dec 17 2021, 11:18 PM
Crap cut away:
Literati914 |
Dec 17 2021, 11:19 PM
Patch made and ready :
Literati914 |
Dec 17 2021, 11:21 PM
And welded in place, and it’s front edge piece made up..
Literati914 |
Dec 17 2021, 11:31 PM
A picture of the completed bucket perimeter area… took lots of pics but it’s all the same thing through out the entire main seal channel. All this took about 5 x as long as I thought it would (IMG:style_emoticons/default/biggrin.gif) . I only have one small dime size hole to repair in this channel now, it’s up near the driver’s side wiper arm area. More on that later. Here’s a sample of the finished work covered in rust preventative paint, just before I leveled the channel with FG filler, mainly to fill weld seams:
Puebloswatcop |
Dec 18 2021, 09:34 AM
Senior Member Group: Members Posts: 1,407 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
^ frustrating, when I use the forums 'attachment' buttons for pics, they get turned in all kinds of directions - is there something I can do to fix this? My Phone makes the pictures to large and will make them fit any way the site wants. I have to go in and edit them down to about 25% of their original size. . |
Literati914 |
Mar 10 2022, 10:34 PM
What !!! You mean I was finally able to get something 914 related done? (IMG:style_emoticons/default/dry.gif)
Ok not directly to car on the rotisserie but at least something. I’m having to add sway bar tabs to a set of front a-arms because my other two sets that already have them (from the factory) are still mounted on cars (IMG:style_emoticons/default/headbang.gif) that’ll need to be jockied around so I can not dismantle those. So yea, I got to break the welder out for the first time in months. I will media blast this set later but for now I used the grinder to get to shined metal for welding: Attached thumbnail(s) |
Literati914 |
Mar 10 2022, 10:35 PM
I used a fourth set that I have to guide in placement of the sway bracket:
Literati914 |
Mar 10 2022, 10:39 PM
I’m looking forward to getting back to this project, and this small accomplishment was kinda motivating tbh. Here the completed tabs. I’ll dissemble the arms later (Wish me luck - these things are rusty!!) :
ClayPerrine |
Mar 10 2022, 10:43 PM
Life's been good to me so far..... Group: Admin Posts: 15,949 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I’m looking forward to getting back to this project, and this small accomplishment was kinda motivating tbh. Here the completed tabs. I’ll dissemble the arms later (Wish me luck - these things are rusty!!) : I have about a dozen sets in my garage, most of which have the sway bar tabs. You could have just come over and picked out a set. Clay |
Literati914 |
Mar 10 2022, 11:11 PM
Oh well.. thanks anyway Clay! There was something I was thinking of hitting you up for the other day, but I’ve forgotten what it was now. (IMG:style_emoticons/default/beer3.gif)
ClayPerrine |
Mar 11 2022, 08:43 AM
Oh well.. thanks anyway Clay! There was something I was thinking of hitting you up for the other day, but I’ve forgotten what it was now. (IMG:style_emoticons/default/beer3.gif) . Memory is the second thing to go... and I forgot what the first one was. (IMG:style_emoticons/default/lol-2.gif) |
Puebloswatcop |
Mar 11 2022, 07:29 PM
Coming along very nicely Doug. I should have had you come do my front trunk channel. I hate it, mine rusted through up near the fender to cowel joints.
Literati914 |
Mar 20 2022, 11:24 PM
I got around to stripping these old A-arms of their bushings and ball joints - they did put up a bit of a fight I must say (IMG:style_emoticons/default/smash.gif)
Literati914 |
Mar 20 2022, 11:28 PM
Then I decided to patch a hole in the bottom of a stock 2.0L air box that I have. I’m not sure which car this will be used on, or if I’ll use it at all but I figured it needed to be repaired before I proceed with sandblasting stuff.
Before: Attached thumbnail(s) |
Lo-Fi Version | Time is now: 22nd December 2024 - 11:38 AM |
