18 Pages V « < 2 3 4 5 6 > »
> Restoration Literati914 Build, A clipped car rebuild
Literati914
post Sep 12 2021, 06:31 PM
Post #61
Now to tackle the loose clutch tube bracket midway down the tunnel.. in this pic a small section of the tunnel has been peeled back and my pen is pointing to where the bracket snapped, and pulled the tube towards the front of the car.
Literati914
Post #62
Literati914
post Sep 12 2021, 06:36 PM
Post #63
Bracket realigned and rewelded… I didn’t shoot a pic but I rewelded the tube to the inside of the rear firewall, the correct length exposed now. All is VERY solid! Well, I will need to address the typical clutch tube repair at the front of the tunnel, but that’s for later..
Literati914
Post #64
Closed up, worked down and lightly primed
bkrantz
post Sep 12 2021, 07:17 PM
Post #65
Nice.
One step at a time.
ClayPerrine
post Sep 13 2021, 12:09 PM
Post #66
This is amazing work. I so need to come see it in person.
Clay
Literati914
post Sep 13 2021, 03:13 PM
Post #67
Thanks guys! Clay I look forward to having you out at some point.. want to show you my Volvo 1800E too, it’s shoe-horned in between the house and the fence at the moment tho.
I got around to thoroughly coating the interior of the tunnel, the area between the rear firewalls, and longs (as much as possible) - with Eastwood’s Internal Frame paint.
Literati914
post Sep 13 2021, 03:19 PM
Post #68
I attached the flexible nozzle to a long flexy thin rod which was helpful in getting the paint where it needed to be. The nozzle sprays the paint in a radial fan pattern.
Literati914
post Sep 13 2021, 03:20 PM
Post #69
Done
Literati914
post Sep 13 2021, 03:24 PM
Post #70
I’ve got this stuff running out of the longs but could only do so much with the heater tubes installed. Still though I think I got it in the most significant areas, around where the firewalls intersect. Here’s the tunnel, topside.
Literati914
post Sep 13 2021, 06:07 PM
Post #71
Wanted to polish off a bottle .. no, not that kinda bottle - welding gas! So I did some preventative work to the hinge brackets, both sides (engine lid to body).
Literati914
post Sep 13 2021, 06:10 PM
Post #72
Does anyone know if there is a reference measurement for the rear deck lid hinge mount… mine as all over the place on the passenger’s side. Looks like it’s been moved a couple of times and I want to weld it in, get rid of those screws .. take a look and advise please:
ClayPerrine
post Sep 14 2021, 06:50 AM
Post #73
QUOTE(Literati914 @ Sep 13 2021, 07:10 PM) *
I am NOT a body man, I pay to have this done. But I was told by Richard Fisher that he puts the hinges on the lid and puts the lid in place, with the seal, then he tacks the hinge in place. That way everything fits correctly before the welding is done.
Hope that helps.
Clay
Literati914
post Sep 14 2021, 10:23 AM
Post #74
Yes that makes perfect since, thanks!
Literati914
post Sep 27 2021, 07:41 PM
Post #75
Rusted through areas of the floor and firewalls are officially replaced. We have fresh clean metal there and buttoned up now - feels like a bit of a milestone.
I used the internal frame paint (shown earlier) as weld thru primer between the floor and tunnel/firewall sections, which is high in zinc and worked out great. I welded these panels on the outside of the car as well as the inside.. probably over kill but at least I can say it’s thoroughly done.
Literati914
post Sep 27 2021, 07:43 PM
Post #76
In process
Literati914
post Sep 27 2021, 07:44 PM
Post #77
.. and completed - I’ve got solid floors again !! (IMG:style_emoticons/default/piratenanner.gif)
mbseto
post Sep 28 2021, 06:54 AM
Post #78
Good persistence, good looking progress!
Literati914
post Sep 28 2021, 07:00 PM
Post #79
QUOTE(mbseto @ Sep 28 2021, 07:54 AM) *
Thanks, I set myself a paint date goal of mid- October.. so that’s my motivation as of late.
Ok so I installed the external seat supports .. coated the internal side with internal frame paint.
Literati914
post Sep 28 2021, 07:01 PM
Post #80
Here it is all buttoned up:
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 21st December 2024 - 07:09 PM
