EJP914 |
Member ![]() ![]() Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 ![]() |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,562 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
That's your 'dual relay'. Only found on L-Jet cars like your 74 1.8L. Its part of your fuel injection system. That thick red with black casing cable going to it supplies direct battery power to your FI system.
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,579 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
But the fact that I can only see one fuel line coming out of the engine shelf means you have carbs. So you don't really need that relay, unless someone wired it up to run the fuel pump. |
EJP914 |
Thanks for the info. FI is long gone. Will check if wired to fuel pump, but I don't think so.
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,578 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) But the fact that I can only see one fuel line coming out of the engine shelf means you have carbs. So you don't really need that relay, unless someone wired it up to run the fuel pump. Goodness gracious ! Clay you and Jeff are awsome. Unbelievable depth of knowledge. |
brcacti |
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region ![]() |
Thanks Clay and Jeff, I (brcacti) ALSO was wondering what that relay was for, I do have FI so its important for me.
Lo-Fi Version | Time is now: 22nd June 2024 - 07:44 PM |
