It's on PMs sent -GB for Trailing Arm bushings Rubber and option for Urethane, Who's interested? 4 pcs (one car) $28 a set rubber $36 Poly |
Mikey914 |
Nov 18 2019, 04:08 PM
The rubber man Group: Members Posts: 12,739 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are in the process of doing the A arm bushings in rubber
We can easily do these up in a polyurethane at the same time, just have to do enough to pay for the materials and set up would be looking at 25 sets to do the Poly The GB would be for a set of 4 (enough for 1car) For $28 in rubber and $36 in poly To get the pricing right we need 40 takers in rubber and 25 in Poly We've been in testing on these for some time and had made a couple variations. This is what they look like. SO Who's in? Attached image(s) |
yellowporky |
Nov 18 2019, 06:50 PM
Member Group: Members Posts: 427 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
do you mean trailing arm bushings? I already bought the kit so will the shaft be the same? Will these squeak after a while?
Thanks |
Nov 18 2019, 08:02 PM
914-6 GT in waiting Group: Members Posts: 19,635 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Mark - how do these differ from the previous ones. Thanks
Mikey914 |
Nov 18 2019, 09:01 PM
Previous ones were the self lubricating Poly-graphite we did not make them. The feedback from Eric was that we needed to make these to do exactly what factory ones did, he was mentioning that there was some squeak from them as they needed to be lubricated, as the rubber ones were not. There is some room for improvement that we will be doing also.
Mikey914 |
Nov 18 2019, 09:04 PM
do you mean trailing arm bushings? I already bought the kit so will the shaft be the same? Will these squeak after a while? Thanks The shaft kit will be the same. The stainless is bulletproof. I was amazed to see the factory was a hollow tube and the welds were not great. So water got in the inside and rusted. |
djway |
Nov 18 2019, 09:07 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Tbrown4x4 |
Nov 19 2019, 08:00 AM
Senior Member Group: Members Posts: 706 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
I'll help support the cause. One set please.
Mendivil26 |
Nov 19 2019, 10:26 AM
Newbie Group: Members Posts: 31 Joined: 26-July 18 From: Riverside, Ca. Member No.: 22,344 Region Association: Southern California |
Count me in, one set for me please
Retroracer |
Nov 19 2019, 10:32 AM
Senior Member Group: Members Posts: 622 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
I'll take one set please; rubber.
- Tony |
Tdskip |
Nov 19 2019, 12:52 PM
Advanced Member Group: Members Posts: 3,702 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Poly compound is CRITICAL. Interested for sure but how will we get the right balance of compliance and firmness?
Genuine question / don’t know how to do that and haven’t tried to make bushings before. |
Mikey914 |
Nov 19 2019, 02:05 PM
Poly compound is CRITICAL. Interested for sure but how will we get the right balance of compliance and firmness? Genuine question / don’t know how to do that and haven’t tried to make bushings before. Fortunately I have (IMG:style_emoticons/default/biggrin.gif) |
johnhora |
Nov 19 2019, 03:17 PM
Senior Member Group: Members Posts: 874 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
One set in rubber please...Thanks
Tdskip |
Nov 19 2019, 03:24 PM
Poly compound is CRITICAL. Interested for sure but how will we get the right balance of compliance and firmness? Genuine question / don’t know how to do that and haven’t tried to make bushings before. Fortunately I have (IMG:style_emoticons/default/biggrin.gif) Well alright then! |
MM1 |
Nov 19 2019, 03:29 PM
914 obsession continues Group: Members Posts: 619 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
I’m in for one rear set in rubber. . .
and one front set in rubber (add on?)! |
bdstone914 |
Nov 19 2019, 05:03 PM
bdstone914 Group: Members Posts: 4,726 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Mikey914
Are the shafts going to be offered in a bundle deal? I have found most original shafts are not straight which makes bushing installation very difficult. I have done several sets of the Elephant Racing sets and the installation is tricky. Good installation tools are a must. I added tapers to the Elephant tools. Delrin might be more slippery and better. I have a couple clean blasted trailing arms and would be willing to install them. I also have sets of used shafts for test installation. I am betting the new shafts will make installation much easier. Bruce |
Mikey914 |
Nov 20 2019, 11:04 AM
@Mikey914 Are the shafts going to be offered in a bundle deal? I have found most original shafts are not straight which makes bushing installation very difficult. I have done several sets of the Elephant Racing sets and the installation is tricky. Good installation tools are a must. I added tapers to the Elephant tools. Delrin might be more slippery and better. I have a couple clean blasted trailing arms and would be willing to install them. I also have sets of used shafts for test installation. I am betting the new shafts will make installation much easier. Bruce Thanks Bruce, We have actually installed in the shop and had our 1st non commercial customer do an install. His shafts were shot so he also used the stainless shafts. @tvdinnerbythepool I personally found these much easier than the front. And yes I need to change the title as it's confusing. But A arm bushings will also be on special. Anything you want to add? http://www.914world.com/bbs2/index.php?sho...41074&st=25 |
morgan_harwell |
Nov 20 2019, 11:35 AM
Ha! Finally snuck up on a camera! Group: Members Posts: 126 Joined: 28-January 03 From: Santa Cruz Mtns., Ca. Member No.: 203 Region Association: Northern California |
One rear set in rubber please...Thanks
tvdinnerbythepool |
Nov 20 2019, 08:18 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
The install of the bushings was VERY easy! The original rubber was deteriorating/cracking, stiff and definitely past it's better days. Getting those out was the most time consuming part but not too bad.
The stainless shafts matched the rubber bushings really nicely. They are a little heavier than stock but far superior craftsman ship. Pressed nicely into the bushings with my little shop press. My Original Shafts were toast, deep rust pits and threads were toast. Would definitely recommend both the shafts and bushings from @mikey914 Before.... |
tvdinnerbythepool |
Nov 20 2019, 08:21 PM
While I was in there did the Springs from 914Rubber too!
Attached thumbnail(s) |
tvdinnerbythepool |
Nov 20 2019, 08:23 PM
Lo-Fi Version | Time is now: 16th December 2024 - 07:56 PM |
