4 Pages V < 1 2 3 4 >
> It's on PMs sent -GB for Trailing Arm bushings Rubber and option for Urethane, Who's interested? 4 pcs (one car) $28 a set rubber $36 Poly
Literati914
post Nov 20 2019, 09:01 PM
Post #21
1 Rubber Set plz.
pete000
post Nov 20 2019, 10:17 PM
Post #22
I would be in for a set of the rubber rear bushings, The stainless shafts are just too heavy for me. The factory shafts are hollow and half the weight as long as they are not rotten...
bbrock
post Nov 21 2019, 08:31 AM
Post #23
Well, shoot. I have a set of as yet, unused poly-graphite from the first GB but always wanted rubber so I'm in for a set.
I'd like to hear a bit more about the installation though. Seems like if the tolerances are OEM, then some cussing should be required to get them in much like the fronts.
TonyA
post Nov 21 2019, 08:44 AM
Post #24
Nachmal
QUOTE(Mikey914 @ Nov 18 2019, 05:08 PM) *
We are in the process of doing the A arm bushings in rubber
We can easily do these up in a polyurethane at the same time, just have to do enough to pay for the materials and set up would be looking at 25 sets to do the Poly
The GB would be for a set of 4 (enough for 1car)
For $28 in rubber
and $36 in poly
To get the pricing right we need 40 takers in rubber and 25 in Poly
We've been in testing on these for some time and had made a couple variations.
This is what they look like.
SO Who's in?
put me in for two sets for two cars both front and rear
jc73-914
post Nov 21 2019, 09:08 AM
Post #25
I'd like to take a set pls. Rubber bushings + shaft, thx.
Highland
post Nov 21 2019, 09:25 AM
Post #26
I too would like to be added for a rubber set (IMG:style_emoticons/default/smile.gif)
jsaum
post Nov 21 2019, 09:37 AM
Post #27
I’ll take a set of the rubber bushings. Possibly the shafts once I see the prices.
Mark Henry
post Nov 21 2019, 08:59 PM
Post #28
that's what I do!
Not sure if I want rubber or poly? new shafts? (IMG:style_emoticons/default/confused24.gif)
This is about the only job I haven't done because I don't have any issues.
If you do poly is there a way of adding grease fittings?
I have Full Motion (needle bearings) on the fronts.
Hot street car only, I might do a DE now that I'm a PCA member.
Mark Henry
post Nov 21 2019, 09:07 PM
Post #29
that's what I do!
I can't find the shaft on your site (IMG:style_emoticons/default/confused24.gif)
Literati914
post Dec 1 2019, 12:36 AM
Post #30
QUOTE(Mark Henry @ Nov 21 2019, 09:07 PM) *
'cause they're not going to be available 'til end of Dec?
..So - as for the current A-arm bushings on the site, they say "NEW" but have no mention in the description of what they are made of (tho the tool is described as delrin). So I'm confused again, are these the latest iteration new rubber that the rear trailing arm bushings are GOING to be offered in? And are the current rears on the site (which also have no description of material composition) an "old" version?
Just trying to put together an order for the current sale and not wanting to purchase soon to be outdated parts by mistake.
Can-Am
post Dec 1 2019, 09:51 AM
Post #31
I'd like a set of rubber ones for the rear if I'm not too late. Thanks
bbrock
post Dec 1 2019, 10:06 AM
Post #32
QUOTE(Literati914 @ Nov 30 2019, 11:36 PM) *
I bought a pair of their SS shafts in the GB for poly graphite bushings at least a year ago, so they've been available for quite awhile. I don't see them on either the new or old web site though. (IMG:style_emoticons/default/confused24.gif)
Mikey914
post Dec 2 2019, 12:21 AM
Post #33
The rubber man
QUOTE(Literati914 @ Nov 30 2019, 10:36 PM) *
The "OLD" material is a poly-graphite, we are making a OEM version with an option for urethane if we have enough interest. So far I'm not seeing it we can bring in a multitude of compounds so I'm sure we could make a great product, but at the small quantity we will be using it will be at a premium, so unless we have enough interest it will not pencil out.
At this point the OEM version has held up very well for many years, so we will definitely be making these.
Mikey914
post Dec 9 2019, 02:08 AM
Post #34
The rubber man
These will be ready soon. Still not seeing enough demand to do the Poly. I have to bring in a min 50lbs of material. For the cost it's not penciling out at this time.
Bueller ……. Buelleer ……...Bueller
injunmort
post Dec 9 2019, 06:50 AM
Post #35
I would take a set of poly
Mark Henry
post Dec 9 2019, 12:18 PM
Post #36
that's what I do!
I see you haven't shipped my "Black Friday" order yet, can you hold it till these are ready?
I'll take a poly set, but if you don't have the numbers I'll take the OE set.
Mikey914
post Dec 10 2019, 12:36 AM
Post #37
The rubber man
QUOTE(Mark Henry @ Dec 9 2019, 10:18 AM) *
I'll check with Scott, but he has got very good at getting stuff out fast. I'll let you know tomorrow.
Mark
Porschef
post Dec 10 2019, 05:55 AM
Post #38
How you doin'
QUOTE(injunmort @ Dec 9 2019, 07:50 AM) *
Otherwise a set of rubber if not.
Mikey914
post Dec 11 2019, 12:25 AM
Post #39
The rubber man
I did get ahold of Scott and we did get it held.
Mark
Mikey914
post Dec 17 2019, 06:12 PM
Post #40
The rubber man
These are running this week, Didn't generate enough interest to do the urethane. We can revisit them if there is enough interest, just can't justify bringing in the material.
PM's to follow shortly.
- Lo-Fi Version Time is now: 16th December 2024 - 10:36 PM
