Powder coat epoxy primer from PPG, Heard of this? |
TravisNeff |
Nov 25 2019, 08:24 PM
I am looking around local shops to blast my 914, I saw that they offered Epoxy priming as part of the service - Turns out it is a powder coat epoxy product from PPG.
Has anyone heard of this? The spec sheet from PPG is a little ambiguous for top coats. PCMT70101 ENVIROCRON® Powder Coat http://www.azprostrip.com/epoxy-primer/ |
sixnotfour |
Nov 25 2019, 09:07 PM
914 Wizard Group: Members Posts: 10,681 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
I am looking around local shops to blast my 914, I saw that they offered Epoxy priming as part of the service - Turns out it is a powder coat epoxy product from PPG. Has anyone heard of this? The spec sheet from PPG is a little ambiguous for top coats. PCMT70101 ENVIROCRON® Powder Coat http://www.azprostrip.com/epoxy-primer/ interior // temp of bake ? ...good for stripped shells but ?? i had my shell sprayed and baked ,,but had the body shop spray the epoxy..10 yrs ago.. |
Nov 25 2019, 09:30 PM
914-6 GT in waiting Group: Members Posts: 19,649 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Looks like it's low temp (350 degrees) powder coating. I saw a 911 chassis that was done that way and it looked great. They made it the same color as the final paint and left the interior unpainted.
Mark Henry |
Nov 25 2019, 10:06 PM
I'd ask if it's easy to sand off if you have welding repairs.
The stuff my powder coat guy uses (finish powder coat) is really hard to sand off which could be a royal nightmare with welding prep. |
Nov 25 2019, 10:09 PM
I'd ask if it's easy to sand off if you have welding repairs. The stuff my powder coat guy uses (finish powder coat) is really hard to sand off which could be a royal nightmare with welding prep. (IMG:style_emoticons/default/agree.gif) I would make sure all your welding is done before powder goes on. |
Boothy |
Nov 26 2019, 05:56 AM
Member Group: Members Posts: 93 Joined: 17-January 19 From: Abington, MA Member No.: 22,805 Region Association: North East States |
May not be the same but I sprayed my 356 with an epoxy primer 6-7 years ago. came out well. Really sticks.
jmitro |
Nov 26 2019, 09:49 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
yea there's epoxy primer and then there's powder coat.
OP is referring to a product supposedly containing both properties in one |
Andyrew |
Nov 26 2019, 10:10 AM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Sounds like the start of a $20k paint job.
TravisNeff |
Nov 26 2019, 10:22 AM
Spec sheet.
Attached File(s) Epoxy_Primer_Page_Add_on_PDF.pdf ( 161.05k ) Number of downloads: 33 |
TravisNeff |
Nov 26 2019, 11:22 AM
I called the shop and asked a couple of questions. They say that it is compatible to topcoat with any other PPG products, high build primers etc.
Ballpark prices were $1,100 for the shell if I get most of the seam sealer out. $125 for each door and if I did the decklids too it would be around $1600 total with media blast, de-ionizing and powder epoxy. Sounds about the same price for media and traditional epoxy spray application? |
Andyrew |
Nov 26 2019, 11:29 AM
I called the shop and asked a couple of questions. They say that it is compatible to topcoat with any other PPG products, high build primers etc. Ballpark prices were $1,100 for the shell if I get most of the seam sealer out. $125 for each door and if I did the decklids too it would be around $1600 total with media blast, de-ionizing and powder epoxy. Sounds about the same price for media and traditional epoxy spray application? That pricing does sound pretty good! |
Lo-Fi Version | Time is now: 26th December 2024 - 08:54 PM |
