914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,465 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
(IMG:style_emoticons/default/cheer.gif) Here is a replacement for one of the 5 major OE nylon bushings that are critical to smooth shifting in your 914.
Specifically for the 901 Side-shift transmission This is a kit including a self lubricating bronze bushing, spring washer & snap ring. It replaces the OE castellated nylon bushing that the shift rod slides through. It has the added benefit of correcting for a worn or ovaled opening in the console Available HERE on 914werke.com (IMG:style_emoticons/default/bye1.gif) ![]() |
StarBear |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,021 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
A quick question: How many are needed for full replacement? Five suggested in the post, with two at the shifter (see photo), or are there different ones fordifferent places? Thanks!
Attached thumbnail(s) ![]() |
914werke |
For a stock car, only one.
The set up pictured above is a non stock Kit that happens to utilize a pair of the Bushings. The 5 bushes referenced are the: Firewall bushing, coupler bushings (2), Console bushing (which this replaces ) & the cup bushing (IMG:style_emoticons/default/smile.gif) |
StarBear |
Thanks!!
For a stock car, only one. The set up pictured above is a non stock Kit that happens to utilize a pair of the Bushings. The 5 bushes referenced are the: Firewall bushing, coupler bushings (2), Console bushing (which this replaces ) & the cup bushing (IMG:style_emoticons/default/smile.gif) |
914werke |
Lo-Fi Version | Time is now: 7th September 2024 - 05:59 PM |
