J West Fuse Panel, How to get the relay nipples into the panel |
NS914 |
Dec 29 2019, 04:08 PM
Member Group: Members Posts: 198 Joined: 9-June 09 From: Dartmouth, Nova Scotia Member No.: 10,455 Region Association: Canada |
Hi Guys,
Picking away at my 914 and have installed my J West fuse panel. One challenge I am having is getting those relay nipples to push into the panel frame. Does anyone have any ideas....I am ready to tape them up out of the way or drill the hole a little bigger to get them in but before I do anything really studid.....ideas. Grant |
914Sixer |
Dec 29 2019, 06:03 PM
914 Guru Group: Members Posts: 9,034 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Are you using any kind of lube?
lierofox |
Dec 29 2019, 11:08 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
For mine I believe I used a quick spritz of silicone spray, and then just worked them in, starting by pushing at an angle to get one side through, and then just used a few tools to pry the edge through the opening, walking my way around. A mixture of needle nose pliers and careful persuasion with a blunt metal pick.
ConeDodger |
Dec 30 2019, 01:36 PM
Apex killer! Group: Members Posts: 23,852 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
NS914 |
Dec 31 2019, 08:00 AM
Thanks Guys, yes I have been just using some WD 40 and trying to push them in....I will return to this task later...LOL!
I have a ton of work to get this car on the road by the spring....its gonna happen! No one believes me but I will show them...LOL! Happy New Year Everyone, Grant |
Mark Henry |
Dec 31 2019, 09:24 AM
A bit of baby oil, slightly twisting them as you flick them back and forth, clamps help but be gentle. If that doesn't work try slowly reaming the hole.
(IMG:style_emoticons/default/w00t.gif) |
Lo-Fi Version | Time is now: 26th December 2024 - 07:13 AM |
