battery connection screw up |
sixnotfour |
Feb 15 2020, 01:39 PM
914 Wizard Group: Members Posts: 10,681 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE Also check the ground strap on the battery to chassis AND the ground strap on the transmission. Just forward of the muffler, top of tail housing of trans.. |
dt4 |
Feb 17 2020, 11:03 AM
Senior Member Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
DickSteinkamp |
Feb 17 2020, 11:23 AM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
It certainly sounds like the engine is not getting a good ground from the chassis.
See post #61 |
Spoke |
Feb 17 2020, 11:24 AM
Jerry Group: Members Posts: 7,104 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Is that the stock ground stud? Maybe it's not making contact. Try jumpering from the battery negative to another chassis ground. If this stud is bad, then the car should turn over with the ground going into a different stud.
sixnotfour |
Feb 17 2020, 11:40 AM
pic = 1000 words
QUOTE It certainly sounds like the engine is not getting a good ground from the chassis. See post #61 QUOTE Specifically, make sure you've got the ground strap snugly attached from rear of gearbox to a clean ground point that's on the underside of the trunk. Attached image(s) |
dt4 |
Feb 17 2020, 12:32 PM
pic = 1000 words QUOTE It certainly sounds like the engine is not getting a good ground from the chassis. See post #61 QUOTE Specifically, make sure you've got the ground strap snugly attached from rear of gearbox to a clean ground point that's on the underside of the trunk. I have cleaned that one up but will go at it again cheers |
sixnotfour |
Feb 17 2020, 04:23 PM
pic = 1000 words QUOTE It certainly sounds like the engine is not getting a good ground from the chassis. See post #61 QUOTE Specifically, make sure you've got the ground strap snugly attached from rear of gearbox to a clean ground point that's on the underside of the trunk. I have cleaned that one up but will go at it again cheers (IMG:style_emoticons/default/beerchug.gif) should have completed the ground path... (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/idea.gif) |
Spoke |
Feb 18 2020, 04:51 AM
dt4 |
Feb 18 2020, 06:38 AM
I have cleaned that one up but will go at it again cheers Did you try connecting the battery negative to another ground post on the chassis? This way you will actually be testing the transmission strap vs. just looking at it. That's tonights job |
dt4 |
Feb 18 2020, 02:30 PM
pic = 1000 words QUOTE It certainly sounds like the engine is not getting a good ground from the chassis. See post #61 QUOTE Specifically, make sure you've got the ground strap snugly attached from rear of gearbox to a clean ground point that's on the underside of the trunk. so I removed this earth strap last night and cleaned up both ends and the area around the stud Had the battery on charge over night as i had flattened it trying different earth points and it started first turn. Hopefully, thats put this thread to bed thanks for all the help folks (IMG:style_emoticons/default/thumb3d.gif) |
ctc911ctc |
Feb 18 2020, 02:40 PM
Senior Member Group: Members Posts: 948 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
pic = 1000 words QUOTE It certainly sounds like the engine is not getting a good ground from the chassis. See post #61 QUOTE Specifically, make sure you've got the ground strap snugly attached from rear of gearbox to a clean ground point that's on the underside of the trunk. so I removed this earth strap last night and cleaned up both ends and the area around the stud Had the battery on charge over night as i had flattened it trying different earth points and it started first turn. Hopefully, thats put this thread to bed thanks for all the help folks (IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 27th December 2024 - 06:51 AM |
