Master cylinder reservoir cover |
Bleyseng |
Jan 15 2020, 01:20 PM
Where can you get one ?
sixnotfour |
Jan 15 2020, 02:11 PM
914 Wizard Group: Members Posts: 10,411 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
You have to party like its 1999, I havent seen em since..
Bleyseng |
Jan 15 2020, 02:41 PM
A new part for 914Rubber to make???
dr914@autoatlanta.com |
Jan 15 2020, 02:42 PM
914 Guru Group: Members Posts: 7,819 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
GaroldShaffer |
Jan 15 2020, 02:56 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I have only seen a few of these. My autocross / track day car has one on it.
Jan 15 2020, 03:16 PM
performance products made them and sold them to automotion. We never sold them because the reservoir already had a drain and a cup to catch excess fluid and we were always careful to keep the brakes in good working order, the cap tight, and the flex lines good so that the fluid would not boil
Bleyseng |
Jan 15 2020, 03:52 PM
It just finishes off the front trunk area....
burton73 |
Jan 15 2020, 04:14 PM
burton73 Group: Members Posts: 3,498 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
This is really easy if Garold used his part for tooling. Clean it and pour into it with aluminum filled Polly Urethane and then use that for the tooling. Parts can be made by vacuum forming. Pulling over the tool with .060 or .090 polyethylene on a small Vacauform. I have a retired unit here at my shop.
Set up a tool for cutting and then use a router to cut the parts. Bob Burton -- Burton Plastics-- Burton73 (IMG:style_emoticons/default/bye1.gif) |
brant |
Jan 15 2020, 04:20 PM
914 Wizard Group: Members Posts: 11,613 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I have them on both of my cars.
they are excellent for track use... on the track at temp... there is always some pressured over, or boiled over fluid that comes out of the cap even with a new cap gasket. so these covers are great at containing that small amount of fluid for track days or racing. |
Coondog |
Jan 15 2020, 04:27 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Got one on my 914.....,. (IMG:style_emoticons/default/smile.gif)
cary |
Jan 15 2020, 10:01 PM
If Mark chimes in. I have one on my car. Automotion a long time ago.
Mikey914 |
Jan 16 2020, 01:25 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Mikey914 |
Jan 16 2020, 01:28 AM
This is really easy if Garold used his part for tooling. Clean it and pour into it with aluminum filled Polly Urethane and then use that for the tooling. Parts can be made by vacuum forming. Pulling over the tool with .060 or .090 polyethylene on a small Vacauform. I have a retired unit here at my shop. Set up a tool for cutting and then use a router to cut the parts. Bob Burton -- Burton Plastics-- Burton73 (IMG:style_emoticons/default/bye1.gif) Due to the undercut, vacuforming wouldn't work as well as injection molding, but I have a unit and may try 1st to see. |
sixnotfour |
Jan 16 2020, 02:37 AM
QUOTE performance products made them and sold them to automotion. you got that backwards..... (IMG:style_emoticons/default/beerchug.gif) |
Bleyseng |
Jan 16 2020, 05:02 AM
Yay for Mike giving this a try!!!!
Mikey914 |
Jan 16 2020, 10:13 AM
AS soon as I have the details worked out I'll do a GB.
Lets see if I can hold the 1999 price. I think I can. |
burton73 |
Jan 16 2020, 03:43 PM
This is really easy if Garold used his part for tooling. Clean it and pour into it with aluminum filled Polly Urethane and then use that for the tooling. Parts can be made by vacuum forming. Pulling over the tool with .060 or .090 polyethylene on a small Vacauform. I have a retired unit here at my shop. Set up a tool for cutting and then use a router to cut the parts. Bob Burton -- Burton Plastics-- Burton73 (IMG:style_emoticons/default/bye1.gif) Due to the undercut, vacuforming wouldn't work as well as injection molding, but I have a unit and may try 1st to see. I see no undercut on this part. Pull over the tool. You can see the flare at the bottom. Easy part. This machine make pull over parts like clear RC Cars bodies. I have had this machine for 40 years Bob B |
Mikey914 |
Jan 17 2020, 10:32 AM
Wasn’t quite sure. I had seen these before and the one I saw did have a slight undercut.
I’ll have to make these to see how well the stay in place, but I do think thermoforming will work. If so , I can sell these at $12 a pop maybe even less (IMG:style_emoticons/default/biggrin.gif) |
windforfun |
Jan 17 2020, 05:59 PM
Senior Member Group: Members Posts: 1,775 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Lo-Fi Version | Time is now: 26th April 2024 - 10:35 AM |
