> Oil Galley Plugs, Conventional Wisdom
adolimpio
post Jan 24 2020, 11:21 PM
Art
I've read a few threads about the plugs, but there were some competing opinions, so I would like to ask for the latest thoughts.
1. What sealant should be used? One thing was clear - NO TEFLON. The most compelling suggestion was JB Weld. Is that a reasonable solution?
2. What kind of plug? Many opinions say NO to brass or aluminum because their head could be easily stripped. Steel was suggested. How about stainless? Any issue with the different expansion rates between the case and the plugs?
One thing is clear - they should be replaced. Of the 11 plugs, 2 almost fell out. They were definitely potential sources of future leaks!
Thanks for your thoughts!
cary
post Jan 24 2020, 11:54 PM
https://lnengineering.com/type-4-store/type...-full-flow.html
I just put these in an engine I'm rebuilding.
http://www.914world.com/bbs2/index.php?sho...p;hl=oil+galley
malcolm2
post Jan 25 2020, 07:18 AM
LN engineering also has a non full flow set. 5 steel plugs. I am working on my second engine now. Don’t remember if i used sealant last time. If i did it was whatever Jake recommended.
Mark Henry
that's what I do!
Steel plugs work fine, when you tap make sure it deep enough that the plug sits flush or almost flush, very important with one flywheel side plug. Liquid teflon is OK just not the tape. I don't like JB weld for this as you may need to clean them out next rebuild.
Only the 5 plugs, 3 behind the flywheel and the two at the front need to be done.
Superhawk996
post Jan 25 2020, 09:36 AM
I'll stir the pot. (IMG:style_emoticons/default/stirthepot.gif)
Aluminum plugs are my preference. In my engineering judgment there is no point mixing dissimilar materials when it comes to galley plugs. Not saying steel can't be used, Per Mark's guidance and tribal wisdwom, others most certainly have been used steel with success.
My reasons for my perference of aluminum plugs:
1) The factory plugs are aluminum. Why? To avoid the potential for leakage that can occur with dissimilar expansion rates. Granted, the OEM plugs are press fit and has a different type of failure mode than the threaded interference fit of a NPT plug. NPT is less likely to leak than a press fit but NPT's and associted tapping operations x 11 holes would have been more expensive to use in production.
2) Potential for galvanic corrosion increases with dissimilar materials. Negligible concern for sure but why add potential for galvanic corrosion in a pressured, potential oil leak path.
3) I've heard the complaint that Aluminum NPT hex's strip. I've never had this problem of stripping an aluminum hex on installation. As with the factory galley plugs, my view is that installation of the Aluminum NPT should be permanent. If the orginal set has been undisturbed for 45 years, I'm not going to plan on ever removing aluminum NPT's after a rebuild. Sure an engine could blow and there would be the need to reclean the galley but I'm not going to plan for that kind of catastrophic failure - the factory didn't nor will I. If need be, the aluminum NPT's can be machined out and replaced later, assuming the case was even still salvageable.
4) My preferred install method ensures a light shrink fit (same as the OEM plugs) in conjuction with the NPT. Put the oil galley plug in the freezer (that's why some call them freeze plugs (IMG:style_emoticons/default/av-943.gif) Just kidding . . watercooled thing I know ) for about 1/2 hour before you need them. Lightly heat the case with a torch. Doesn't need to be raging hot (200F is plenty) so let's not start debating about warping cases. Now thread in the the NPT plug quickly with just a light dab of blue Locktite mostly for lubrication purposes to ensure no thread galling occurs on install. As the case cools you'll end up with a light shrink fit.
Now as the case expands and contracts you have identical expansion rates, a light shrink fit, the benfit of multiple threads as a labrynth seal, a bit of locktite as thread sealant. It won't leak. And as an added bonus, that plug isn't coming out on its own - ever But, as noted above, don't expect to remove it easily in the future. Aint' gonna happen. It will have to be machined out.
Again not saying steel can't work, just that aluminum is my personal preference.
Mark Henry
post Jan 25 2020, 01:58 PM
that's what I do!
In this case it doesn't really matter which material you use, I only use steel plugs because one day I may have to take them out. Like with most engine builders it's hard to change the mindset when you have a solution that has worked for years, not to mention the couple hundred steel pipe plugs I have in stock. The dissimilar metals/leakage theory is just a no go with my thinking, metals don't expand in just one direction, they expand in all directions. If anything the pipe plug gets tighter as heat increases. I've never had a steel plug leak and I've done this mod on many of my own and customers engines. BTW the steel plug will never rust on the business side.
The pipe plugs I use have the micro-encapsulated thread sealant already on them, same as the 996 factory bolts. Took me awhile to trust this treatment, but they have never leaked. Tech tip if you get these plugs, is use a spare/bare plug to test fit the depth of the plug, then once happy install the ME plugs.
Always use a new or sharp 3/8" NPT tap, you drill to 9/16" and try to oval out the top hole, but best way is to carefully use a taper ream for proper size. I've cut the tip off of my reamer so it doesn't go in too deep. Lube the tap, there are special cutting lubes if you have them, but WD40 works good enough. Always check your test pipe plug depth as you cut with your tap. Don't worry about threads into a galley, but there's a blind plug in the front and one in the back, so don't drill in too far. The most outward hole (3-4 flywheel side) the plug must sit flush or just a hair proud or it will hit the flywheel. I leave the rest of the plugs a bit proud. There's holes with galley right behind them, the 1/2 flywheel hole (IIRC) is a hole really close to a cam galley, leave the plug almost half proud or some builders back cut the plug. Never over torque the pipe plug, but I know I put more torque on a steel plug than you ever could on an aluminum or brass plug. One thing I've never measured is the torque, the plug just stops in the taper, I give one more try and you're done.
Do install all the plugs before you start engine assembly, if there's any issue with depth you want to know before assembly.
Superhawk996
post Jan 25 2020, 02:53 PM
QUOTE(Mark Henry @ Jan 25 2020, 02:58 PM) *
Nope. Quick materials science lesson:
You are correct that material expands in all directions.
However, in the case of a hole, there is no material at the center to expand inward or outward. The material that composes the circumference of the hole expands in all directions and increases the diameter of the hole. Something that wouldn't previously fit though the hole with a size difference of 0.001"-0.003" now can. All due to the growth in the diameter of the hole as it is heated and expands the material that composes the hole in all directions. The larger the hole, the more it will expand when heated.
Here is a quick video of the principle.
https://www.youtube.com/watch?v=3pnj4ytORQw
If there is a material of the same thermal expansion that fills the hole (i.e. an aluminum galley plug), it all expands at the same rate. There is no relative growth differential between the two parts. This is how the OEM aluminum press fit oil plugs generally stay in place for 40+ years. Without a thermal expansion difference between parts the press fit stays the same, hot or cold. No relative movement between the two parts.
If there is a plug material of a lesser thermal expansion (i.e. steel plug in our case) at the center, it doesn't expand as fast as the aluminum that composes the hole is expanding and the steel plug gets looser.
This effect is also how/why the steel pilot shaft of Type 4 oil pump shaft is able to be pushed outward though the aluminum oil pump housing. The aluminum housing shaft hole grows faster than the steel shaft and the interference fit between them becomes less. The steel shaft is looser in the aluminum housing. Oil pressure then slips behind the steel shaft in the pump body shaft pocket, and now we have a small hydrualic ram effect that is actually working to push the looser steel shaft though the housing. As we all know, with enough time and especially with an overheated engine, the shaft can actually be pushed out into contact with the cam gear. (IMG:style_emoticons/default/sad.gif)
As you've noticed in application, the difference between our two positions (steel plugs vs. aluminum plugs) is minimal but it is indeed there. The steel plug is getting looser in the oil galley hole. In the case of the steel NPT plug, the threads will prevent the plug from being pushed out by the oil galley hydraulic pressure. Most likely any potential for oil weepage is being addressed by the thread sealant you use with the steel plugs.
Again to be completely clear, I'm not trying to imply you don't do quality work. Just that difference between our positions is minimal in practice.
You are spot on that as an engine builder, you have a lot higher risk of engines coming back. Especially if they are race engines. I completely understand why you do what you do, and wouldn't question the quality of one of your motors. Heck, I'd love the luxury of being able to pay you to build mine. (IMG:style_emoticons/default/biggrin.gif)
dr914@autoatlanta.com
post Jan 25 2020, 03:16 PM
empi makes a nice assortment set
malcolm2
post Jan 25 2020, 07:37 PM
QUOTE(dr914@autoatlanta.com @ Jan 25 2020, 03:16 PM) *
Come on Doc, you are 15 paragraphs behind (IMG:style_emoticons/default/shades.gif)
adolimpio
post Jan 28 2020, 06:52 PM
Art
Thanks for all the help, it was very useful.
- Lo-Fi Version Time is now: 14th December 2025 - 04:59 AM
