Why in tarnations did they do that?, very curious |
ahycaramba |
Feb 3 2020, 10:06 PM
“I live my life a quarter mile at a time.” Group: Members Posts: 161 Joined: 17-March 15 From: Murrieta, California Member No.: 18,534 Region Association: Southern California |
Ok I had my car media blasted and found something very interesting. On both sides of the floor board and one under the foot pedals there are round impressions with a half moon shape cut into them, total of five. Is this from the factory? What was their thought process on that? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/screwy.gif) Thinking of welding them up.
Thanks in advance Al |
gms |
Feb 3 2020, 10:24 PM
Advanced Member Group: Members Posts: 2,708 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Most likely spot welder access or assembly line attachment related
ahycaramba |
Feb 3 2020, 10:40 PM
Feb 4 2020, 01:13 AM
Resident German Group: Admin Posts: 41,943 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Most likely spot welder access or assembly line attachment related (IMG:style_emoticons/default/agree.gif) |
peteyd |
Feb 4 2020, 07:09 AM
Senior Member Group: Members Posts: 733 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
I think that Al is asking about the circled portion.
These were present on all 911 floorpans as well. They were probably for drainage. That is all that we can imagine they were for. Whether it was for a process on the assembly line? I'm sure the 911 guys have discussed it as well. Pete |
ahycaramba |
Feb 4 2020, 08:14 PM
Thanks for the insight gentlemen.
Pete you were right on the money as to what i was referring to. I'm glad to know mine is not a one off. (IMG:style_emoticons/default/beerchug.gif) Al |
914forme |
Feb 4 2020, 08:55 PM
I wish it was for draining after it was dipped in anti corrosive, but most all of us have proof that never happened.
bkrantz |
Feb 4 2020, 09:26 PM
914 Guru Group: Members Posts: 8,175 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I see what you did there.
Literati914 |
Feb 5 2020, 12:00 AM
Senior Member Group: Members Posts: 1,780 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
ClayPerrine |
Feb 5 2020, 08:48 AM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The big round holes with the plugs in them were to hold the panel to the assembly jig. Once the body was assembled, the jig was removed and the plugs installed.
As for the small ones with the half moon cutout, I would doubt they were for spot welder access. That would require bending the metal before welding, and bending it back once done. Most spot welders on assembly lines are either big monsters with huge jaw openings, or they are built into the assembly jig. Maybe for drainage when they dip primed the chassis. |
UROpartsman |
Feb 5 2020, 04:11 PM
Member Group: Members Posts: 292 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None |
Indeed, these cut outs have been the subject of many discussions on 911 forums. Many folks believe they were intended to allow drainage after the parts were dip-primered, but Clay's body jig explanation also makes sense for the large holes. The openings were later sealed with bitumen on the inside and body schutz on the outside, so they were never intended to be open on a finished car.
Here's a NOS 911 floor pan with similar punch-outs. Attached image(s) |
ClayPerrine |
Feb 6 2020, 11:16 AM
I have a Porsche factory video of 356 bodies being built. It shows the metal being put on the jigs as they add each part, and they use the same big holes to connect to the jig. The little holes were to drain away the excess paint when the chassis was dip primered.
76-914 |
Feb 6 2020, 03:15 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I have a Porsche factory video of 356 bodies being built. It shows the metal being put on the jigs as they add each part, and they use the same big holes to connect to the jig. The little holes were to drain away the excess paint when the chassis was dip primered. Post it up in another thread Clay. (IMG:style_emoticons/default/drooley.gif) |
914forme |
Feb 6 2020, 07:45 PM
I guess Germans forgot primer is hygroscopic (IMG:style_emoticons/default/confused24.gif)
ClayPerrine |
Feb 7 2020, 02:16 PM
I have a Porsche factory video of 356 bodies being built. It shows the metal being put on the jigs as they add each part, and they use the same big holes to connect to the jig. The little holes were to drain away the excess paint when the chassis was dip primered. Post it up in another thread Clay. (IMG:style_emoticons/default/drooley.gif) I will have to rip the cd that it is on. Clay |
Lo-Fi Version | Time is now: 26th December 2024 - 03:24 PM |
