Maltese Falcon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,037 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
@Horizontally-opposed We also have the specs + assembly components to build FIA spec 510 Datsun competition headers. No calls for those, probably not too many Orig BRE Historic 510s around with the FIA head (IMG:style_emoticons/default/biggrin.gif)
Gotta love the air cooled Porsche cult , for the sheer numbers of International followers (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/aktion035.gif) |
Maltese Falcon |
@mb911 some of my mfi clients steal a bit of a heat off of the "S" pipe, using a fabricated clamp-on style "Heat riser" tube, into a 1" hose going topside.
SKL1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest ![]() ![]() |
How will you do the preheat for MFI with just headers? [/quote] Don't have the pre-heat hooked up now- that part is closed off. Not a problem here in the desert!! |
gereed75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,342 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States ![]() ![]() |
Man you have been into some cool stuff over the years, and now #40
I have actually had my hands on at least two DATSUN comp FIA heads the ports on them are so big that they have fallen out of favor with tuners these days. besides you need the matching header and manifold to really use them. cool stuff though.! PM replied to. |
Maltese Falcon |
Datsun 510 competition/ FIA exhaust port difference , compared to the 510 street version header ports are day and night.
Don't forget big Cam profiles, larger valves + ported heads, larger venturi carbs, and operating mostly W/O/T will require getting all of that combustion moving out of the exhaust stream a lot quicker ! OD of the FIA header is 1.75", which is the tube size we build headers for a 3.6/3.8/4.0 air cooled flat six (IMG:style_emoticons/default/welder.gif) ![]() |
Archie |
Member ![]() ![]() Group: Members Posts: 197 Joined: 23-September 09 From: Western Canada Member No.: 10,844 Region Association: Pacific Northwest ![]() |
It is with great excitement to announce that #40 has found new ownership with us, in the Schneider Family. Michael & Renee Hagen, two of the most amazing individuals I have gotten to know so well, have entrusted #40's ownership to us going forward, and we couldn't be more thrilled. With such history, we are honored to oversee this vehicle in to its next chapter of life within our possession. Cheers, Matthew PS: With respect to both parties, the purchase price will not be disclosed. French plates? |
Maltese Falcon |
@Archie mais Ouis ¡
Archie |
Maltese Falcon |
Maltese Falcon |
Interesting find in the mfi-drive cover plate; 3 French 1/2 Francs used as shim spacers (IMG:style_emoticons/default/biggrin.gif)
tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,543 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
Interesting find in the mfi-drive cover plate; 3 French 1/2 Francs used as shim spacers (IMG:style_emoticons/default/biggrin.gif) Exactly what I'd expect in a Le Mans car! (IMG:style_emoticons/default/lol-2.gif) |
AZBanks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,064 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region ![]() ![]() |
27 cents profit right there.
The engine looks amazing. |
pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,886 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
Well that just proves she is legit ! you must keep it in there!
Maltese Falcon |
Engine builder says that the Drive on the cam-tower is not ribbed as in an MFI pump; but has a specific slot machined into the face. He says that an hour-meter could have been driven off of it via cable-drive.
Maltese Falcon |
Something to this example , small 2 1/16" dia. gauge
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,771 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
906. 911R , 910 Tach drive..
Attached image(s) ![]() |
Maltese Falcon |
Maltese Falcon |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,728 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
The right rear engine tin in the picture is modified so that it can be installed or removed
on a dressed engine. The MFI pump drive can be installed and adjusted at build time rather than at the track. Neat idea. No evidence of Carrera chain tensioners. BTW the car appears briefly in the thread 'Old 914 Footage' Fantastic ! Marty keep the pics coming. You lucky dog. |
Maltese Falcon |
Lo-Fi Version | Time is now: 10th April 2025 - 04:23 PM |
