rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,237 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
You're a master of metal. Trying to wrap my head around how it bolts up to the headers. Too early in AM. Lots of 90* angles for the gases? What goes in the center gap? The exhaust note at 8k must be exquisite.
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,841 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
You're a master of metal. Trying to wrap my head around how it bolts up to the headers. Too early in AM. Lots of 90* angles for the gases? What goes in the center gap? The exhaust note at 8k must be exquisite. I think it’s a welding jig. It holds the flanges and pipes to get welded but not in the orientation for the car. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,788 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
QUOTE The exhaust note at 8k must be exquisite. kevin, same setup as my GT, you forgot what it sounds like ?? |
rhodyguy |
Just from the passes across the Columbia at Hood River. Too far away and I was a bit drunk at the time. Feeble memory IYCMMIYGMD.
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,948 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
Hey dude, wow...Congratulations! A quick question on the body work. Are those rear flares the original ones? And is it my imagination, or are those wider than the m471 supplied flares? Thanks and dang, congrats again.
Maltese Falcon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,041 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
You're a master of metal. Trying to wrap my head around how it bolts up to the headers. Too early in AM. Lots of 90* angles for the gases? What goes in the center gap? The exhaust note at 8k must be exquisite. Just an assmbley fixture that holds 3 components of the final exhaust/ not how they fit or appear on the GT. I do have a couple of great fabricators in the workshop, sometimes I just feel like " Mongo just a pawn with a hand-grinder in the game of Life " (IMG:style_emoticons/default/biggrin.gif) |
maj75 |
Member ![]() ![]() Group: Members Posts: 69 Joined: 26-May 20 From: Lighthouse Point, FL Member No.: 24,317 Region Association: None ![]() |
What is the gauge set-up on the left? Is it a 911 gauge with separate gas gauge?
Maltese Falcon |
Maltese Falcon |
Hey dude, wow...Congratulations! A quick question on the body work. Are those rear flares the original ones? And is it my imagination, or are those wider than the m471 supplied flares? Thanks and dang, congrats again. Paul...your eyes are not mistaken as these fenders were prototypes, hammered over bucks by hand. Slightly wider than the oe m471 stampings , and the lower contours a bit different as well. I checked these against my black six , converted to GT tribute in late '80s, with Factory sourced panels; Fender flare profiles + width have slight differences. Thank you for your interest ¡ |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
Marty's new nickname is M O N G O !!!!
Merry Christmas, Marty & family! See you some time in the new year. |
Maltese Falcon |
Marty's new nickname is M O N G O !!!! Merry Christmas, Marty & family! See you some time in the new year. Hey Lawrence...how did I not see that coming ¿! but you know I'm kind to animals and would never slug a horse (IMG:style_emoticons/default/smile.gif) Have a great Holiday season, keep safe & strong...will def see you in '21 (IMG:style_emoticons/default/driving.gif) |
Shivers |
Thanks Marty, they look so cool and being original they give me permission to look closer at the pics and make my own copy. Fronts look close to the m471 flare.
Maltese Falcon |
Going into the transaxle overhaul this week, the gear sets that we discovered are; A,F,O,S,X ...perhaps factory set for the LeMans course (1970's). Also in there is factory limited slip. There will be several upgrades made, but keeping the tail shifter in place for its period correctness...it actually shifts pretty good !
Maltese Falcon |
I was setting up the 2 megaphones for marking L and R (letter punch) just before sending off for ceramic coating, and revealed these small center punch marks.
2 = R side , 1 = L side...who didn't know that ¿ (IMG:style_emoticons/default/smile.gif) ![]() |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,260 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Gears A,F,O,S,X are a very interesting set. Almost like A&F are used to get out on to the track, and the rest are selected for the important sections. X seems a little short for the Mulsanne straight though.
Maltese Falcon |
Gear sets now utilized wil be A,F,M,S,X as the transitions are better. Our trans guru thinks along your same understanding, previous "O" gears set up for the certain areas of the track layout. Mulsanne Staight speeds ("X" gears) using almost all of the engine's 8k redline seemed reliable (on paper) for the 24 hour stretch. The recipe worked (IMG:style_emoticons/default/smile.gif)
@davep |
Maltese Falcon |
Maltese Falcon |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,620 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
Cool stuff Marty - happy '21!
I agree an X top gear at 8K is about as fast or faster than you'd wanna be going in a non-aero 914 ... My current 5th is a V and that's ~135mph which is pucker time |
slivel |
Old car....... older driver ![]() ![]() ![]() Group: Members Posts: 528 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California ![]() |
My short gear box is AFMSX and long box is AFNSY. With 275-45/16 Hoosiers the car would top out at 150 and this was needed at Miller Motorsports (now UMC). My car never felt nervous or light at that speed. A little downward rake helps, I think. My crank fired ignition was set to 7500 cut off but I tried to keep my shifting to 7000 whenever I could.
Lo-Fi Version | Time is now: 18th April 2025 - 04:42 AM |
