wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,751 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
Smooth in either direction + looking forward to that First 100L fill-up (IMG:style_emoticons/default/blink.gif) https://www.youtube.com/watch?v=ypakZKACjmo?feature good thing you were not at a BP service station down here 2 weeks ago thinking of doing that! |
Maltese Falcon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,041 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
So...who knows which of the 2 drivers took #40 over the finish line, Claude or Guy (IMG:style_emoticons/default/idea.gif) ¿
just wondering out loud (IMG:style_emoticons/default/number40_914.jpg) |
wonkipop |
So...who knows which of the 2 drivers took #40 over the finish line, Claude or Guy (IMG:style_emoticons/default/idea.gif) ¿ just wondering out loud (IMG:style_emoticons/default/number40_914.jpg) you must know mr s! i don't. but i know claude ballot-lena always drove with a red helmet. the other driver, guy chasseuil had a light colored or white helmet in photos. there is a shot of the car just after race coming into winners paddock. looks like a white helmet on driver - maybe - very hard to tell. one other photo with both drivers in it after finish. looks like guy c is driving. and claude b-l has his girl friend (?) on his lap in the passenger seat. wild guess - was guy chasseuil at the wheel at finish. ![]() |
wonkipop |
film stills.
last lap. he is coming around behind the yellow vette. think its a white helmet but its black and white so.....? ![]() driving into finishers paddock. the yellow vette has just driven in before him. has taken his helmet off. ![]() thats as close as i can get. there is a photo right at finish line. but can't see through the windscreen to see the helmet. (IMG:style_emoticons/default/sad.gif) claude ![]() |
Maltese Falcon |
Ready to mount...since there was no vent tube/vent hole drilled into the trunk floor, I'm not going that route. A simple piece of foam rubber= the breather ; better than the breather tank just flopping around in there (IMG:style_emoticons/default/biggrin.gif)
The black rubber strap is a 356/ 912 parts bin item ! ![]() |
Maltese Falcon |
The jury is still out, but getting closer regarding the pilot of #40 accross the finish line. This description assembled here by photographer/racer/author Michael Keyser shows the post-moment where the race finished. Guy in the driver's seat, Claude passenger and his girlfriend on his lap.
So far @wonkipop has a good clue!! Michael tells me that he still has contact with Guy over in France and will be in touch with him. Can't get better than that...the #40's co-driver report ! (IMG:style_emoticons/default/driving.gif) ![]() |
BillJ |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,273 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None ![]() ![]() |
Ready to mount...since there was no vent tube/vent hole drilled into the trunk floor, I'm not going that route. A simple piece of foam rubber= the breather ; better than the breather tank just flopping around in there (IMG:style_emoticons/default/biggrin.gif) The black rubber strap is a 356/ 912 parts bin item ! ![]() Just picked up one of these. What specifically is the strap part number? And specific brackets for it? And how are you routing hoses? |
Maltese Falcon |
@BillJ the rubber hold-down strap is a 912 battery holder, Factory pn# 90161102521.
It comes with attachment fasteners already in place at both ends. After you shape the alum base plate (I use .125" ga.), you will need to make a small flat "Hook" style receiver* to place on the backside of the plate...this catches the steel "Loop" on the rubber strap. *You can either tig weld the Hook/ or set with JB weld. For the other end of the Strap>the end that you pull and lock in place, I simply shaped the inside of a steel washer to match the shape of the hook and welded on to the flat bracket. Then it's bent to a 45° angle...easy to mate the hook into place. The venting (clear vinyl tube) connects to a push-on fitting located on the GT oil-filler neck. ![]() ![]() |
Maltese Falcon |
Scheels are ready; the original "Skins" will be preserved in a large glass-framed display, #40 Wall Art (IMG:style_emoticons/default/aktion035.gif)
BillJ |
Thanks for the details on the puke tank. The lines seem smaller than the ones i use. Where do rthey oute?
Maltese Falcon |
@BillJ yes the vent line nipple on the gt filler neck seems a bit smaller in dia than the one on my normal 9146 oil tank, just get the correct size vent tube / and a suitable grommet. Red cap on top is where the waste oil is emptied; grey foam (prev post) on the Right is a simple breather, engine is not making much blowby at all. I've seen some GT's that have a road-tube that will go into ( in place of the grey foam) a hole cut in the trunk floor and aim down by the trans.
wonkipop |
The jury is still out, but getting closer regarding the pilot of #40 accross the finish line. This description assembled here by photographer/racer/author Michael Keyser shows the post-moment where the race finished. Guy in the driver's seat, Claude passenger and his girlfriend on his lap. So far @wonkipop has a good clue!! Michael tells me that he still has contact with Guy over in France and will be in touch with him. Can't get better than that...the #40's co-driver report ! (IMG:style_emoticons/default/driving.gif) ![]() they were both stylish blokes driving a stylish car to a stylish victory. (right down to the girlfriend with the french short hair-cut sitting on a lap) so it kind of doesn't matter marty. but its nice for you to know the details. i hope you get the answer. by the way. i love my dunpy sticker. so do all the ford guys here i show it to. i'm trying to score you a super-roo repro from rare spares. they have to do another run of them. i'll get you one when they get some stock from the printer in the right size. have you got a ford to stick it on? (IMG:style_emoticons/default/beerchug.gif) |
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,947 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
The jury is still out, but getting closer regarding the pilot of #40 accross the finish line. This description assembled here by photographer/racer/author Michael Keyser shows the post-moment where the race finished. Guy in the driver's seat, Claude passenger and his girlfriend on his lap. So far @wonkipop has a good clue!! Michael tells me that he still has contact with Guy over in France and will be in touch with him. Can't get better than that...the #40's co-driver report ! (IMG:style_emoticons/default/driving.gif) ![]() Too bad this picture is not larger. I'd think the most recent driver would have helmet hair. |
BillJ |
Maltese Falcon |
@Shivers (IMG:style_emoticons/default/biggrin.gif)
@BillJ the tribute is looking (IMG:style_emoticons/default/first.gif) have you sorted the engine troubles¿¿ @wonkipop...yes an F150, F250 and Explorer (IMG:style_emoticons/default/flag.gif) Marty |
BillJ |
Yes was just a leaking line. Car is otherwise great!
Maltese Falcon |
Maltese Falcon |
Maltese Falcon |
Maltese Falcon |
Lo-Fi Version | Time is now: 17th April 2025 - 01:02 AM |
