914-6 engine, Value |
HansJan |
Feb 10 2020, 07:37 AM
Member Group: Members Posts: 399 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
gereed75 |
Feb 10 2020, 09:09 AM
Senior Member Group: Members Posts: 1,315 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
I believe that is from a very early 914-6 chassis number European model. Ref here http://p914-6info.net/Engine_Numbers.htm
As previously stated this a fairly complete unit. Heat exchangers are worth $1500 if in good condition. Heat valves are there too if original six are worth something. Also has front motor mount and carbs Depending on what all else you have agree worth About 6000 |
sbsix |
Feb 10 2020, 09:11 AM
only the lead dog enjoys a change in scenery... Group: Members Posts: 455 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
That is a 1970 914-6 European engine number.
HansJan |
Feb 10 2020, 09:40 AM
Thank you.
Any ballpark ideas what it would cost to convert my 4 to accept this 6? I understand that it needs front mounted oil-cooler, an oil tank and engine tins. Am I missing something else expensive? |
Feb 10 2020, 09:50 AM
914-6 GT in waiting Group: Members Posts: 19,649 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Thank you. Any ballpark ideas what it would cost to convert my 4 to accept this 6? I understand that it needs front mounted oil-cooler, an oil tank and engine tins. Am I missing something else expensive? Shouldn’t need a front cooler. Stock sixes never had them. Engine mount, oil lines, heat exchangers or headers, muffler, oil pressure and temp gauge. Engine harness. Shift rod modification. Labor |
gereed75 |
Feb 10 2020, 09:56 AM
No need for a front mount cooler. This engine will run fine on the engine mounted cooler. You will need an oil tank and the lines, a fuel pump suitable for carbs, the bulkhead engine mount, maybe a different shift rod depending on trans type and what is in your car now, throttle linkage, engine tins, muffler,
I’m sure there are other things but these are the big ones. Most of these items are available after market in some shape or form. Start researching. It is all here. Assuming this is a stock two liter six, you might be disappointed in the performance compared to your big four. |
brant |
Feb 10 2020, 10:04 AM
914 Wizard Group: Members Posts: 11,824 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Thank you. Any ballpark ideas what it would cost to convert my 4 to accept this 6? I understand that it needs front mounted oil-cooler, an oil tank and engine tins. Am I missing something else expensive? its a lot of details. probably 10K in parts it also depends on what else you might change while your there... . 5 bolt wheels and brakes? New shocks? Sway bars? just the motor requires: shift linkage/with shifter and trans rods to convert to a side shift? tach throttle cable throttle bell crank motor (hopefully it doesn't need a 10K rebuild) motor mount oil tank, plus associated filler neck, cap, dipstick, mounting rubber oil feed line oil return line flywheel (might be on the motor) and new clutch components for wear headers muffler muffler bracket possibly engine tins other things and freshening while your in there brant |
Feb 10 2020, 10:35 AM
Brant is right, check on the motor condition before you set of on the six jorney. $!0K is pretty much the DIY price to rebuild these engines. And that's if all the major components are usable and rebuildable. Then add $1-2K on top of that for a carb rebuild.
porschetub |
Feb 10 2020, 12:54 PM
Advanced Member Group: Members Posts: 4,754 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Thank you. Any ballpark ideas what it would cost to convert my 4 to accept this 6? I understand that it needs front mounted oil-cooler, an oil tank and engine tins. Am I missing something else expensive? Not sure if you mentioned what this motor runs like ?,no point in trying to keep to a budget with a '6' build as you will most likely spend way more,it just keeps mounting up....ask me how I know. I was able to make a lot of parts for my conversion and save $$$ but not everyone can do that. Good luck. |
Lo-Fi Version | Time is now: 26th December 2024 - 08:01 PM |
