Finish on wheels question |
dt4 |
Feb 9 2020, 04:16 AM
Senior Member Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
bdstone914 |
Feb 9 2020, 05:42 AM
bdstone914 Group: Members Posts: 4,735 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
They are anodized. The pedals ate polished and the recessed areas satin.
dt4 |
Feb 9 2020, 06:34 AM
Thanks, that's good to know
dt4 |
Feb 12 2020, 12:59 PM
dt4 |
Feb 12 2020, 01:00 PM
TargaToy |
Feb 12 2020, 01:19 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 706 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
dt4 |
Feb 12 2020, 02:27 PM
I used a 200 grit sanding pad on a 3" airsander to remove the anodising and the scuff marks etc... then went upto 600 then 1000 then 2000 then polished with a mopping pad and autosol metal polish
I had to planish the centre cap to get it reasonably flat first as it was pretty beat up ten sanded it flat before polishing |
dt4 |
Feb 12 2020, 02:29 PM
I will see how they get on before deciding whether to seal them
jim_hoyland |
Feb 13 2020, 01:32 PM
Get that VIN ? Group: Members Posts: 9,558 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Nice job; what would seal the surfaces ?
Front yard mechanic |
Feb 13 2020, 02:34 PM
Senior Member Group: Members Posts: 1,242 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Silver paint goes a long way not to be a Debbie downer (IMG:style_emoticons/default/barf.gif)
dt4 |
Feb 15 2020, 01:19 PM
Not a fan then lol
One of the centre caps is pretty beaten up |
Mikey914 |
Feb 15 2020, 01:27 PM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I used a 200 grit sanding pad on a 3" airsander to remove the anodising and the scuff marks etc... then went upto 600 then 1000 then 2000 then polished with a mopping pad and autosol metal polish I had to planish the centre cap to get it reasonably flat first as it was pretty beat up ten sanded it flat before polishing When you polish they will be more shinny. I stock the polished and the anodized. Polishing and making look good take a lot of time. That and dis-similar metals will continue to corrode the OEM caps making them hard to remove https://900designs-container.zoeysite.com/s...h/?q=center+cap Make sure to look at the set of 4 as it's cheaper than individuals Attached thumbnail(s) |
dt4 |
Feb 16 2020, 12:31 PM
A bit of planishing, sanding and polishing later
Lo-Fi Version | Time is now: 26th December 2024 - 12:10 PM |
