> 914 in-car spares kit, What spare parts do you keep in your 914?
horizontally-opposed
post Feb 15 2020, 08:05 PM
I used to carry a lot more spares with me before I pulled my car apart for paint, and then converted it to a 911 engine. I wasn't much concerned about originality or "concours" correctness...just didn't want to get stranded. I'd like to get back after that.
Back then it was:
15x5.5 Gasburner with 165R15 tire (lighter full-size spare)
944 scissor jack (lighter, and my jack points were suspect)
Tool kit (not the original...)
Fuses + relays + bulbs
Fan belt
Clutch clevis pin
Clutch cable (under rear trunk carpet)
Throttle cable (under rear trunk carpet)
If you were going to do it now, or are doing it, what would be/is in your kit?
EDIT: Going to make a running tally for (my) "ideal kit" based on the above and other ideas on this thread:
Front trunk
Full-size spare on light alloy wheel
Aluminum scissor jack (in lieu of stock steel jack)
Tool kit (original or roll your own), breaker bar w/19mm soft socket
Fuses, relays, bulbs, clutch clevis, fan belt, fuel filter, select ignition parts
Extra motor oil
Rear trunk
Clutch cable (laid flat under trunk carpet)
Throttle cable (laid flat under trunk carpet)
This thread has a number of other good ideas—as well as some fun ones—but the list above focuses on items that could be tough to get in a pinch but won't add much weight or take up a lot of space. Past the spare tire, jack, and tools, very little weight at all. I am sure everyone's take on "smart" things to bring along differs, particularly for a longer trip, but keep the ideas coming. They might help someone new to 914s out…as well as those of us who aren't. (IMG:style_emoticons/default/smile.gif) Especially the tequila...
Front yard mechanic
post Feb 15 2020, 08:35 PM
Tequila and a cell phone (IMG:style_emoticons/default/beer3.gif)
jim_hoyland
post Feb 15 2020, 08:51 PM
Get that VIN ?
Kinda depends on how far you are going.
rhodyguy
post Feb 15 2020, 08:53 PM
1/2" drive Breaker bar and a 19mm socket wrapped in a towel in the front trunk. For long trips? 1/2" drive 19mm hex head.
wes
post Feb 15 2020, 09:31 PM
wes
For a really long drive,, my truck and trailer.
sb914
post Feb 15 2020, 09:43 PM
Surf Guru
VegasRacer
post Feb 15 2020, 10:13 PM
ELVIRA
Fill the glove box with these and you will be fine. (IMG:style_emoticons/default/biggrin.gif)
When I had an X/19, they said to pack the title and return airfare.
mlmgm
post Feb 15 2020, 10:48 PM
We also pack one or two quarts of oil, (just in case) and have a billet jack that's pretty light and compact.
post Feb 15 2020, 10:59 PM
QUOTE(mlmgm @ Feb 15 2020, 08:48 PM) *
^ Pretty slick....
https://www.calcarcover.com/product/low-pro...uminum-jack/705
Suspect that might fit behind a seat? I like the aluminum 944 jack I've got next to the spare tire right now, but wonder if this is lighter or more compact, or lifts as high? Hm.
post Feb 15 2020, 11:00 PM
So far, tequila and Benjamins are in the lead... (IMG:style_emoticons/default/idea.gif)
RickS
post Feb 15 2020, 11:20 PM
QUOTE(horizontally-opposed @ Feb 15 2020, 08:59 PM) *
^ Pretty slick....
One review said that it didn’t raise his Porsche high enough to remove a tire. Had to carry a wood block for it. Fail.
VegasRacer
post Feb 16 2020, 12:32 AM
ELVIRA
I am happy to add the weight and give up the space to carry a set of reflective safety triangles. (IMG:style_emoticons/default/busted_cop.gif)
Plus: Full size spare. 911 jack. Tools. Fuses.
brant
post Feb 16 2020, 07:50 AM
Every year I take 1000/plus mile road trip in my teener
I carry a lot though;
Axles,alternator, distributor, battery charger with extension cord, complete djet system with ecu and regulator board, plus much more
rgalla9146
post Feb 16 2020, 07:52 AM
6 cyl. w/ carbs ?
CD unit
Fuel pump
Fuel filter
Spark plugs
Gas can new, no smell
FlacaProductions
post Feb 16 2020, 09:07 AM
I like the jack but wondering about these if they come to be:
easy to store but should be stable and should be high enough...
https://www.kickstarter.com/projects/crossj...ack/description
KSCarrera
post Feb 16 2020, 09:26 AM
Region Association: England
Throttle cable, clutch cable, cable ties, 19mm socket and breaker, and a small adjustable wrench. Oh, and my iPhone... And one of these:
Boxster 986 spare wheel/tyre (lightweight and same diameter overall as the 195/65x15s I have on the car) and matching alumin(i)um jack.
mlmgm
post Feb 16 2020, 12:49 PM
Our car sits fairly low, so the billet jack works for us. We looped it under the factory bracket in the front trunk and trimmed a leather belt to secure it.
We used the Porsche medicine bag to carry the tools, etc. It also matches our seats.
jim_hoyland
post Feb 16 2020, 03:38 PM
Get that VIN ?
In addition to the stuff listed already; a test light is great to verify there is power to the coil or fuel pump as well as under dash fuse panel. Small, easy to use,
jim_hoyland
post Feb 16 2020, 03:43 PM
Get that VIN ?
QUOTE(KSCarrera @ Feb 16 2020, 07:26 AM) *
(IMG:style_emoticons/default/agree.gif) Great set for the front trunk
DRPHIL914
post Feb 16 2020, 06:11 PM
Dr. Phil
Easy, you just need one of these with you (IMG:style_emoticons/default/lol-2.gif)
- Lo-Fi Version Time is now: 4th February 2025 - 11:51 PM
