1.8 oil leak drivers side |
dt4 |
Feb 17 2020, 01:46 PM
Senior Member Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
porschetub |
Feb 17 2020, 02:55 PM
Advanced Member Group: Members Posts: 4,754 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Might pay to start with valve cover gaskets,then check pushrod tube seals,report how you get on (IMG:style_emoticons/default/beer.gif) .
BeatNavy |
Feb 17 2020, 04:08 PM
Certified Professional Scapegoat Group: Members Posts: 2,944 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Might pay to start with valve cover gaskets,then check pushrod tube seals,report how you get on (IMG:style_emoticons/default/beer.gif) . (IMG:style_emoticons/default/agree.gif) with P'Tub. You should be able to get a light on the valve cover edges and the pushrod tube ends and see if you see any drips or seepage. Valve covers and pushrods are the normal suspects with oil on HE's. |
dt4 |
Feb 18 2020, 01:29 AM
Is this with the engine in situ?
I shall consult my Hayes manual / google / youtube thanks |
BeatNavy |
Feb 18 2020, 07:03 AM
Yes, both can be done with engine in. Valve cover replacement / reseal is part of normal maintenance with valve adjustment. Pushrod tube seals are a little trickier, but there are plenty of threads here about how to do it. To do the pushrod tube seals you need to remove valve cover, so plan accordingly.
dr914@autoatlanta.com |
Feb 18 2020, 09:46 AM
914 Guru Group: Members Posts: 8,110 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yup like everyone said, left front leak valve cover gaskets or pushrod tube seals. The only other two possibilities are:
left front breather hose leaking thermostat roller stud loose and leaking |
dt4 |
Feb 18 2020, 12:28 PM
thanks Rob and George
ClayPerrine |
Feb 18 2020, 12:31 PM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
On the passenger side it could also be the oil pressure sender or oil cooler seals.
porschetub |
Feb 18 2020, 07:02 PM
On the passenger side it could also be the oil pressure sender or oil cooler seals. (IMG:style_emoticons/default/agree.gif) ask me know how I know that on the oil pressure sender on my last overhaul (IMG:style_emoticons/default/biggrin.gif) . Motor otherwise looks tight and dry but yes cooler seals could be an issue but not worth checking yet. |
Lo-Fi Version | Time is now: 26th December 2024 - 09:22 PM |
