FS: 1976 914-6 3.0L Conversion |
patssle |
Feb 22 2020, 08:53 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
This is a 1976 Porsche 914 that has a 1981 Porsche 3.0L SC engine. Almost all work done to the car has been done by myself (except wrap, bodywork, and specialty rebuilt parts). I have owned the car since 2009. In 2010 I purchased a project 911 to swap the engine to my 914. After preparing the engine and collecting parts the swap was done in the summer of 2014. I have driven this car every fall and spring when there is nice weather. Mileage of engine and car is unknown. Annual driven estimates are 2-4 thousand miles. Engine pulls hard and is a true blast to drive in this tiny car. Previous owners gutted the car for autocross – this is a lightweight 914. Interior is bed liner – no carpet. No accidents under my ownership. The car has never been towed home. I also own a 2000 Boxster S that I work on myself as well.
$17,000 SOLD Issues: Slight rust issues were fixed by my body guy before being wrapped (paint underneath is faded red). Previous rust issues were already fixed before my purchase (battery hellhole). Racing seats need to be recovered or replaced – I have passenger seat but is not in car. The oil tank oil filter mount was not drilled center so I am using a remote oil mount. This allows for extra oil temp sensors that are featured in the center console and for the remote fan. Engine leaks like any classic Porsche engine as does the oil tank through a fitting or mount I apparently didn’t seal well enough when installed. Speedometer is not accurate – bounces around despite new cable. Specs: 1976 914 with a 1981 3.0L SC engine Weber 40IDA3C Carburetors MSDS 1-5/8 headers DANSK Muffler Sport Polished Stainless Steel (84 mm Dual Tail Pipes) 901 Side Shift Transmission (Rebuilt by Mike Callas / Rennsport Sealy) Patrick Motor Sports Engine Mount Vellios Oil Tank w/ Filler Neck and Dip Stick Kennedy Engineering Flywheel & Stage II Clutch w/ TOB MSD 6AL Ignition Distributor rebuilt and recurved by Barry Hershon (23 crank degrees) Alternator rebuilt by Houston Alternator 911 Starter Mocal 25 Row, 235 Matrix Oil Cooler w/ Remote Thermostat Engine oil cooler modified by Richard Johnson Valvoline VR1 Racing Oil 20w50 Aeroquip Stainless Steel Braided Hose -16 AN Tank to Engine, -12 AN Everywhere Else Gates LP (Low Permeation) Carb Fuel Line 5/16" CB Performance Fuel Pump 3M 1080 Scotchprint Gloss Hot Rod Red Wrap installed by Undergroundgrfx Turbo Tie-Rods Bilsteins P36-0112-H0 Inserts Mahle 5.5x15 Wheels BFG G-Force Sport Comp 2 Tires Front Sway Bar Installed (Rear Available) |
billh1963 |
Feb 23 2020, 06:22 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
That's a lot of car for the money!
JOEPROPER |
Feb 23 2020, 07:41 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
I can't believe that you still have that car.
Root_Werks |
Feb 24 2020, 11:54 AM
Village Idiot Group: Members Posts: 8,308 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Had I not just bought a 914-6, this would be one I would consider for sure. That is a lot of car for the money.
burton73 |
Feb 24 2020, 05:42 PM
burton73 Group: Members Posts: 3,503 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
If this car was a 75 or older it would of been gone in a flash
Bob B |
patssle |
Feb 25 2020, 12:10 PM
It'll be going on BaT if it doesn't sell in this last attempt. Just wanted to keep it in the Porsche community! It's a unique car that has to find the right owner - it's not for everyone. And yeah...the 1976 model year is a negative.
sholman5 |
Feb 25 2020, 03:32 PM
Kraut burner Group: Members Posts: 189 Joined: 11-September 16 From: Ormond beach, Fl. Member No.: 20,391 Region Association: South East States |
Who cares what year it is, it's a 914.
flat4guy |
Feb 25 2020, 09:41 PM
Member Group: Members Posts: 442 Joined: 10-October 16 From: nor cal Member No.: 20,484 Region Association: Northern California |
For those of us still stuck in Calif there is smog required on 76 and newer. Usually a deal breaker.
brant |
Feb 25 2020, 10:08 PM
914 Wizard Group: Members Posts: 11,614 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
mrholland2 |
Feb 26 2020, 11:08 AM
Senior Member Group: Members Posts: 750 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Feb 26 2020, 11:23 AM
For those of us still stuck in Calif there is smog required on 76 and newer. Usually a deal breaker. With a 1981 engine (and perhaps cats) would it not exceed the 1976 tailpipe requirements? Engine has carbs and no cat. But there are still 49 other states. |
pete000 |
Feb 26 2020, 11:51 AM
Seems like a great buy ! GLWS
Tdskip |
Feb 26 2020, 03:23 PM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
I may have this car confused with another one, but wasn't there a leak down / compression issue with one cylinder?
Tdskip |
Feb 26 2020, 03:26 PM
mrholland2 |
Feb 27 2020, 10:23 AM
With a 1981 engine (and perhaps cats) would it not exceed the 1976 tailpipe requirements? CA SMOG is not solely sniffer based, car needs to have its OEM set up and since this car's configuration was never sold by Porsche no way to get it through. Although I support clean air, the original law was supposed to be a 30 year rolling start date. ( In other words, it should be cars made in 1989 and earlier are exempt). Don't citizens have the right in California to start a Prop? Maybe it could be Prop 914. HA |
matthepcat |
Feb 27 2020, 11:35 AM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
This car could be registered in Ca, just would take some work and scheming.
mrholland2 |
Feb 27 2020, 12:34 PM
This car could be registered in Ca, just would take some work and scheming. I love a good scheme. . what would it be? (imagine a 54 year old kinda fat guy doing the Monte Burns scheming pose) (IMG:style_emoticons/default/idea.gif) |
matthepcat |
Feb 27 2020, 12:40 PM
Lol. That would have to be discussed in a PM.
(IMG:style_emoticons/default/shades.gif) This car could be registered in Ca, just would take some work and scheming. I love a good scheme. . what would it be? (imagine a 54 year old kinda fat guy doing the Monte Burns scheming pose) (IMG:style_emoticons/default/idea.gif) |
Tdskip |
Feb 28 2020, 08:28 AM
@patssle - please correct my memory if it is off, but if I am remembering correctly (and I may not be) low compression in one or more cylinders is kind of important to know.
nditiz1 |
Feb 28 2020, 01:31 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/agree.gif) I'd like to know this as well. This is something of my next 914.
- I'll take wide fenders already installed OR - more so I'd take a 6 already installed Being a 76 is kind of neat since there so few. MD owners dont need to worry about the smog laws I'd have to ditch the bubs though. |
Lo-Fi Version | Time is now: 26th April 2024 - 07:36 PM |
