Who needs more than 2.0 liters?!?! |
siverson |
Feb 26 2020, 11:36 AM
Advanced Member Group: Benefactors Posts: 2,457 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
I'm going to be putting my green 914 for sale again shortly, so I put together some short videos. I liked this one:
https://www.youtube.com/watch?v=qs5S42tLC9o (Yes I should get a gopro mount or something.) -Steve |
DickSteinkamp |
Feb 26 2020, 11:38 AM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
(Yes I should get a gopro mount or something.) -Steve ...and a rev limiter (IMG:style_emoticons/default/biggrin.gif) |
ValcoOscar |
Feb 26 2020, 11:42 AM
Garage Life Group: Members Posts: 2,482 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
I'm going to be putting my green 914 for sale again shortly, so I put together some short videos. I liked this one: https://www.youtube.com/watch?v=qs5S42tLC9o (Yes I should get a gopro mount or something.) -Steve Sweet car Steve...I've seen your green 914-6 twice. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/smile.gif) That sucker hauls ASS. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/bootyshake.gif) Oscar |
Feb 26 2020, 11:43 AM
914-6 GT in waiting Group: Members Posts: 19,700 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I saw the car at WCR - Beautiful (IMG:style_emoticons/default/smilie_pokal.gif)
siverson |
Feb 26 2020, 11:51 AM
Almost stock 2.0 but with E cams. It really has no problem spinning to ~7,200. And aok with the engine builder (European Motorsports). -Steve |
ClayPerrine |
Feb 26 2020, 11:55 AM
Life's been good to me so far..... Group: Admin Posts: 15,974 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Who needs more than 2.0 liters?!?! I do!!!!! There is on replacement for displacement! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) |
Root_Werks |
Feb 26 2020, 11:59 AM
Village Idiot Group: Members Posts: 8,537 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Always like the sound of the short stroke sixes. Looks like fun!
Chris H. |
Feb 26 2020, 12:05 PM
Senior Member Group: Members Posts: 4,053 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
ClayPerrine |
Feb 26 2020, 12:19 PM
Always like the sound of the short stroke sixes. Looks like fun! From Henry Schmidt at Supertech. 2.8 SHORT STROKE 66 MM STROKE 95 MM BORE 2.2 "S" CRANK 3.0 TURBO CASE TURBO OIL PUMP SC HEADS PORTED TO 40 MM IN 38 MM EX TITANIUM VALVE SPRING RETAINERS TWIN ANDIAL DISTRIBUTOR DC80 CAMS (JOHN DOHERTY) camgrinder on this forum 10.5 TO 1 COMPRESSION MODIFIED 2.2 '"S" MFI PUMP, SEALED W/ BREATHER 41.5 MM BUTTERFLY HOUSINGS 41.5 X 46 MM MAG STACKS SUPERTEC FUEL INJECTOR LINES SUPERTEC ENRICHMENT DEVICE EURO RACING HEADERS (George does a nice job) 226 FAN W/1.3 TO ONE DRIVE RATIO SINGLE WIRE ALTERNATOR RSR SHROUD ( GETTY DESIGN) SOLID TENSIONERS (never fail) THIS BAD BOY SHOULD MAKE 300+ HORSE POWER AND TURN 8500 RPM That is a real screamer!!! http://forums.pelicanparts.com/911-engine-...roke-2-8-a.html I traded a 76 turbo engine I had for a pair of 2.4 MFI motors. Before trading it off, I considered building the 2.8 short stroke motor listed above. I decided I wanted a motronic motor eventually. So I made the trade. Clay |
rhodyguy |
Feb 26 2020, 12:36 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,207 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
What kind of money does an engine like that one run? Both kidneys and a piece of your liver?
Root_Werks |
Feb 26 2020, 12:41 PM
Always like the sound of the short stroke sixes. Looks like fun! From Henry Schmidt at Supertech. 2.8 SHORT STROKE 66 MM STROKE 95 MM BORE 2.2 "S" CRANK 3.0 TURBO CASE TURBO OIL PUMP SC HEADS PORTED TO 40 MM IN 38 MM EX TITANIUM VALVE SPRING RETAINERS TWIN ANDIAL DISTRIBUTOR DC80 CAMS (JOHN DOHERTY) camgrinder on this forum 10.5 TO 1 COMPRESSION MODIFIED 2.2 '"S" MFI PUMP, SEALED W/ BREATHER 41.5 MM BUTTERFLY HOUSINGS 41.5 X 46 MM MAG STACKS SUPERTEC FUEL INJECTOR LINES SUPERTEC ENRICHMENT DEVICE EURO RACING HEADERS (George does a nice job) 226 FAN W/1.3 TO ONE DRIVE RATIO SINGLE WIRE ALTERNATOR RSR SHROUD ( GETTY DESIGN) SOLID TENSIONERS (never fail) THIS BAD BOY SHOULD MAKE 300+ HORSE POWER AND TURN 8500 RPM That is a real screamer!!! http://forums.pelicanparts.com/911-engine-...roke-2-8-a.html I traded a 76 turbo engine I had for a pair of 2.4 MFI motors. Before trading it off, I considered building the 2.8 short stroke motor listed above. I decided I wanted a motronic motor eventually. So I made the trade. Clay Jeff (sixnotfour) built a 2.5 for me many moons ago. Loved that engine. De-stroked 2.7. |
Feb 26 2020, 12:46 PM
What kind of money does an engine like that one run? Both kidneys and a piece of your liver? I think a basic rebuild from any of the top builders runs $20-25K Hot rods like the one Clay posted are more like $50+ Our shop recently built a 3.4 with 300 rear wheel HP so that's like 360 at the crank. It's for a street car that gets driven regularly. They are getting help from an ex Andial employee who knows how to build these kind of engines. It's a lot more than just assembling expensive parts. |
911GT2 |
Feb 26 2020, 12:53 PM
Member Group: Members Posts: 195 Joined: 2-March 11 From: The Netherlands Member No.: 12,773 Region Association: Europe |
eric9144 |
Feb 26 2020, 01:40 PM
Advanced Member Group: Members Posts: 2,759 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
Dropping that hammer with one hand holding a phone and the other doing the shifting (IMG:style_emoticons/default/lol-2.gif) Clearly it tracks super straight!
I like how the follow up video is "Porsche 914 spanks 911" (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) GLWTS, there's not a lot out there and quality cars seem to be few and far between! |
siverson |
Feb 26 2020, 01:42 PM
That 2.0 was rebuilt in 2014 by European Motorsports and was about $19k all in. It was actually a bit more expensive to keep it as a 2.0 rather than going to a 2.2 or 2.4, but since its an original six I wanted to keep it almost entirely stock. Cams and later chain tensioners being the other exceptions.
Cairo94507 |
Feb 26 2020, 01:50 PM
Michael Group: Members Posts: 10,168 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Steve's car is beautiful and we all know it runs like it looks. Anyone who buys his Six will not regret it. GLWTS. (IMG:style_emoticons/default/beerchug.gif)
ClayPerrine |
Feb 26 2020, 02:01 PM
I got verbally slapped by Betty for suggesting we put 2.2 S pistons, cylinders and cams in Elwood.
But I deserved it. We agreed that car would be made as completely stock as possible. Your car sounds really good. Hope the new owner enjoys it. |
Lo-Fi Version | Time is now: 13th January 2025 - 04:06 PM |
