We've had a failure but someone gets $50, Open casket burial- Even after autopsy |
Morph914 |
Apr 20 2020, 06:37 AM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
999,914
ctc911ctc |
Apr 20 2020, 01:32 PM
Senior Member Group: Members Posts: 946 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Apr 20 2020, 01:43 PM
Resident German Group: Admin Posts: 41,934 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
1,821,213 You should have said 1,829,828 (2 x 914,914) which is my guess and obviously a much better number! (IMG:style_emoticons/default/biggrin.gif) |
Mikey914 |
Apr 20 2020, 01:50 PM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are through 565k we don’t run testing on weekends (IMG:style_emoticons/default/biggrin.gif) |
abes914 |
Apr 20 2020, 02:11 PM
Member Group: Members Posts: 366 Joined: 30-March 11 From: Long Beach Member No.: 12,880 Region Association: Southern California |
I think you meant 666 914-8 (IMG:style_emoticons/default/happy11.gif) Matches your 8 cylinder car more |
abes914 |
Apr 20 2020, 02:13 PM
I know what Jenny's answer would be: 8675309 Dang. You got me dancing and singing (IMG:style_emoticons/default/piratenanner.gif) |
Mblizzard |
Apr 24 2020, 06:58 PM
After buying 8 of these (a complete tongue in cheek statement) I found a major flaw!
I noted that some of these fitted very lose in the relay board. If this happens don’t fret. A quick spread of the contacts using a razor blade or thin flat blade screw driver solves the issue easily. Great product guys! |
Mikey914 |
May 11 2020, 07:12 PM
We have a winner. The fatality occurred at 615665. Would love to have seen it go further but really it's overkill. So looks like @SB914 is the winner. I'll drop you a PM with the code Thanks for playing! Attached thumbnail(s) |
Mikey914 |
May 11 2020, 07:14 PM
Open casket after the autopsy
914e |
May 11 2020, 07:48 PM
Member Group: Members Posts: 497 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
So if I drive the 914 twice a day everyday, I can only expect it last 400 years?
sb914 |
May 12 2020, 05:20 AM
Surf Guru Group: Members Posts: 4,410 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
We have a winner. The fatality occurred at 615665. Would love to have seen it go further but really it's overkill. So looks like @SB914 is the winner. I'll drop you a PM with the code Thanks for playing! @mikey914 (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/aktion035.gif) thanks mark!!!!! I’m super stoked. (IMG:style_emoticons/default/beer3.gif) seven !!! |
914 RZ-1 |
May 12 2020, 03:28 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
1,821,213 You should have said 1,829,828 (2 x 914,914) which is my guess and obviously a much better number! (IMG:style_emoticons/default/biggrin.gif) Yeah, that would have been better. I had a reason for picking this number, but have forgotten it. |
lierofox |
May 12 2020, 06:23 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
Rest in peace, relay!
What part of it failed? Coil? Contacts? |
worn |
May 12 2020, 06:43 PM
can't remember Group: Members Posts: 3,367 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
So, we’re testing one of our new improved relays and we’re currently through 545,000 cycles. We are doing live load testing on a timer that cycles ever 7 seconds. It may stop tomorrow, it may keep going for a few more months. So let’s bet how many cycles can we get before it dies? Closest guess gets a $50 credit What’s your number.? I bought the relays, but as a retired scientist I have to take issue. The real test is to take ten of your relays and put them upside down outside for a year in Portland. You are presupposing a failure mode that is unlikely. Still, I like my new relays, and I hope they will be reliable. |
Mikey914 |
May 12 2020, 07:16 PM
Why would we put them outside? Testing should be for the application they are being used for. Anything else is just playing.
If we have to take ten it may take awhile. We've seen enough that we offer a 2 yr warranty, that's way better than anything else on the market. (IMG:style_emoticons/default/biggrin.gif) |
914-300Hemi |
May 12 2020, 07:58 PM
Senior Member Group: Members Posts: 1,372 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California |
914,911,958
EdwardBlume |
May 12 2020, 08:40 PM
Nice!
BananaTroll |
May 13 2020, 05:18 PM
The Ratt-Man Group: Members Posts: 8 Joined: 15-September 18 From: Northern New York Member No.: 22,491 Region Association: North East States |
908,000
worn |
May 13 2020, 05:26 PM
Why would we put them outside? Testing should be for the application they are being used for. Anything else is just playing. If we have to take ten it may take awhile. We've seen enough that we offer a 2 yr warranty, that's way better than anything else on the market. (IMG:style_emoticons/default/biggrin.gif) I said I bought them, I like them. I just don’t think the originals failed from over use. I think they failed because of age and corrosion. Most 914s have spent considerable time outdoors. At least the two I have did. I figure Portland is worse than some, and better than others. It snowed here on Sunday, but they didn’t put out road salt. If the body’s rust, so can the relays. Thank God I can now get dependable relays from a reliable, stand up source. Not like the cheap, fail out of the box relays I have been getting. Thanks Mark! |
flat4guy |
May 13 2020, 08:38 PM
Member Group: Members Posts: 460 Joined: 10-October 16 From: nor cal Member No.: 20,484 Region Association: Northern California |
and I was going to say 615666. haha
Lo-Fi Version | Time is now: 19th December 2024 - 07:46 AM |
