10 Pages V < 1 2 3 4 > »
> Time to un-DAPO the "new" car, Bad things happened to a nice car
BillC
post Jun 29 2020, 10:56 AM
Post #21
So, we got the engine and fuel tank out yesterday. And, the DAPOs didn't disappoint.
On the engine, where the Decel Valve should be, I found this:
Yup, that's a fuel pressure regulator on a home-made mounting bracket. It does look similar to a decel valve, but they're just not quite the same thing. Plus, they didn't bother connecting or plugging the vacuum line that connects to the decel valve, so there's the source of the high idle.
In the front, they did mount the fuel pump and filter under the tank. However, they did it by using a sheet metal screw to attach a hose clamp and then clamped the pump, with a little bit of old hose for noise dampening.
Not really a great mount, but probably the least "DAPO" thing they did to the car.
The previous owner did mention that the car seemed to lose power at higher speeds. I think I may have found out why:
Apparently that crimp isn't enough to stop the car from running, but came very close. Also explains why it took so long to drain the fuel tank.
post Jun 29 2020, 12:25 PM
Post #22
Resident German
For what it's worth, i really like the color!
(IMG:style_emoticons/default/first.gif)
BillC
post Jul 1 2020, 04:12 PM
Post #23
QUOTE(SirAndy @ Jun 29 2020, 02:25 PM) *
Thanks! So do I.
Well, it's finally time to put up or shut up. Up 'til now, I've been complaining about what has been done to the car over the years, now it's time to actually do something about it.
Sunday, we pulled the engine and trans from the car. Monday, I spent time removing more stuff from the car. Yesterday, I pushed the engine-less car out of the garage and hosed out as much dirt as I could from the frunk, the gas tank area and under the rear trunk. No pictures of any of this, figured it was kinda boring and yesterday was quite soggy.
Today is the start of the metal repairs. I started with the holes in the divider panel between the gas tank and the frunk. Here's what it looked like to start:
To start, I cut out the "web" between the holes, to make one large hole, which seemed easier to patch than 3 smaller holes.
Then, I put a piece of cardboard behind the hole and used a pencil to outline out a patch. I cut out the cardboard, traced it on a piece of sheet metal and then cut out the piece of metal. Here's a pic of the patch tacked in place.
Then I got to work, welding and grinding. Here are a couple of pics of the patch installed and cleaned up (outside and inside):
And, with a coat of primer:
It seemed appropriate to use the primer that I won at Octeenerfest three years ago:
Craigers17
post Jul 1 2020, 04:43 PM
Post #24
This situation seems particularly frustrating....especially on what look like some otherwise pretty solid longs. Did they really have to go through 4 frigg'n layers? It's really hard to imagine what the intended result was supposed to be.
2mAn
post Jul 1 2020, 04:56 PM
Post #25
trying to see how long I can go without a 914
(IMG:style_emoticons/default/WTF.gif)
(IMG:style_emoticons/default/chair.gif)
Superhawk996
post Jul 1 2020, 05:02 PM
Post #26
QUOTE(Craigers17 @ Jul 1 2020, 06:43 PM) *
My guess is AC lines. My car had similar butchery from AC install
Wyvern
post Jul 1 2020, 05:03 PM
Post #27
When I started reading this I did not know what a "DAPO" was ... but each time I saw it i got a better idea , now I know . LOL
My buddy and I have talked about making a book PO FU ... but that may be a better name .
We need a DAPO thread
BillC
post Jul 1 2020, 05:22 PM
Post #28
Yes, very frustrating. They went through three layers of structural metal and the heating duct. The worst part is that I have to cut big holes in the three structural layers to get to the heat duct and then rebuild things on my way out.
QUOTE(Superhawk996 @ Jul 1 2020, 07:02 PM) *
No idea. Someone else had previously suggested oil cooler lines. Could have been either, or something else entirely. Whatever it was supposed to be, they didn't complete it -- other than the frunk divider, there are no other holes where you'd expect AC or oil cooler lines to be run (at least, that I have found).
QUOTE(Wyvern @ Jul 1 2020, 07:03 PM) *
I learned about "DAPO"s on this forum, too. Very fitting acronym.
If someone starts a thread, I'll be nominating the picture that Craigers picked out.
BillC
post Jul 2 2020, 05:19 PM
Post #29
Made more progress today.
Removed the rear window and the engine deck lid. Found another thing that needs to be fixed -- apparently they stripped out the nut for the deck lid mount, so they drilled it out and dropped a bolt in from above. Was originally thinking of just putting a helicoil in to fix the welded nut, but it may have been drilled out too large for that, will measure tomorrow.
Welded up the holes in the firewall, Also wirebrushed the rusty areas on the firewall and the window mounting area. Treated the rust with Loctite Rust Converter, which will get primered and painted after it dries.
Also, the touch-up paint finally arrived from Paintscratch.com (we're having UPS problems). So, I touched up the frunk and gas tank areas. Looking much better:
Montreal914
post Jul 2 2020, 05:50 PM
Post #30
Not sure what your front sway bar setup is but I don't see any reinforcement plate on the inner wall, is it mounted on the wheel well side? Or was the factory installed sway bar didn't have the added plate? (IMG:style_emoticons/default/confused24.gif)
BillC
post Jul 2 2020, 05:53 PM
Post #31
QUOTE(Montreal914 @ Jul 2 2020, 07:50 PM) *
It's a factory-installed sway bar, so no added plate on the inside. The mounting plates are spot-welded on the outside with multiple spots.
BillC
post Jul 3 2020, 04:44 PM
Post #32
It doesn't seem like I accomplished much today, but it took all day to do it.
I installed a new retractable antenna. Had to leave the old antenna base grommet, since the area of affected paint is larger than the new base.
Then, I removed the windshield wiper assembly. I cleaned up and treated the rust around the wiper post holes. Then, I disassembled the wiper assembly and cleaned and greased the posts.
Hopefully, tomorrow I'll be able to paint around the post holes and then Sunday I'll be able to reinstall the wiper assembly.
I also installed new hoses for the window washers, while I have easy access under the cowl. At some point, I'll install an electric pump for the washer.
BillC
post Jul 6 2020, 04:26 PM
Post #33
Well, I didn't make as much progress as hoped this weekend.
I went to reinstall the window wiper mechanism, and ended up breaking the 47-year-old rubber isolator mount. <sigh> So, time to order another part and wait for it to arrive. Hello, 914Rubber....
In the meantime, I fixed the control cables for the heating & ventilation system. Don't know why, but some of the cables were connected to the wrong locations.
And, I fixed the stripped nut in the decklid mount. Since (I hope) everyone likes pictures, I took a bunch of this process. Of course, it took as long to take all the pics as it did to perform the actual repair.
First step is to drill out the bad threads. Fortunately, the DAPO didn't over-drill the hole, it was just about the right size.
Then, I tapped the hole with the helicoil tap:
Then, to make sure the helicoil won't come out, I added some red loctite.
Next step was to install the helicoil insert. Here's a pic of the install tool, with the insert about halfway installed:
Final step was to break off the driving tang. The full kit comes with this special "breaker" tool (aka, a piece of steel rod), but it can be done with a screwdriver if you just buy the basic kit.
All done. This won't come out without destroying the mount.
Cairo94507
post Jul 6 2020, 05:54 PM
Post #34
Michael
Very nice. You are making great progress and tackling things one at a time will keep you from getting over loaded. (IMG:style_emoticons/default/beerchug.gif)
Front yard mechanic
post Jul 6 2020, 08:07 PM
Post #35
If you ever sell the car think what the next owner will call you (IMG:style_emoticons/default/slap.gif)
BillC
post Jul 7 2020, 06:36 AM
Post #36
QUOTE(Front yard mechanic @ Jul 6 2020, 10:07 PM) *
Well, among other things, I am trying to avoid being lumped into the same category of (future) previous owners.
The guy who bought my previous 914 seemed very happy with it, and that includes having it shipped to a well-known 914 shop for a thorough inspection prior to receiving the car.
IronHillRestorations
post Jul 7 2020, 03:16 PM
Post #37
I. I. R. C.
Sad to see the misfortune of some cars. I hope my 2nd 914 never shows up here. I'd be curious as to the cost of the car Bill, if it was a high dollar car or not.
get off my lawn
post Jul 7 2020, 03:20 PM
Post #38
QUOTE(Front yard mechanic @ Jul 6 2020, 07:07 PM) *
LOL note to self: don't sell a car to anyone on 914world (IMG:style_emoticons/default/poke.gif)
Superhawk996
post Jul 8 2020, 06:40 AM
Post #39
QUOTE(BillC @ Jul 7 2020, 08:36 AM) *
(IMG:style_emoticons/default/happy11.gif)
Let's be honest - over the course of 40+ years, lots of these cars have had work done on them by people that that should have at least learned to work on a lawnmower before undertaking repairs on an automobile. (IMG:style_emoticons/default/sheeplove.gif)
Congratuations @BillC for taking the time and effort to fix it with a sense of quality and workmanship that was often lacking in the orignal reapirs we find on these cars.
BillC
post Jul 9 2020, 07:08 PM
Post #40
The order with the rubber isolator finally came, so I installed the wiper motor and wipers.
The hardest part of the installation is the nut for the other end of the isolator. It hides under the dash, and is very difficult to reach with the dash in place. Fortunately, if you take out the ashtray mount (two phillips screws and push forward to unclip), you can just barely get access with a 1/4" drive deep socket (10mm) and a universal joint. The red circle shows the inside nut.
- Lo-Fi Version Time is now: 4th December 2024 - 02:21 AM
