| EdwardBlume |
Jun 29 2020, 05:51 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
I’m looking to sell off some extra parts.
What’s a ZF limited slip diff worth? In a rebuilt 901 tranny with 3241 miles? And a new intermediate plate at the time? Thanks, |
| brant |
Jun 29 2020, 09:23 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,277 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Not sure but I wish I could afford it.
Bump |
| EdwardBlume |
Jun 29 2020, 11:32 PM
I guess they went into the 914/6 GT cars....
| sixnotfour |
Jun 30 2020, 08:07 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,369 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
some 914-4s had em , factory
| mepstein |
Jun 30 2020, 08:19 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,918 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
| Superhawk996 |
Jun 30 2020, 04:15 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,076 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
What’s a ZF limited slip diff worth? Thanks, IMHO value is capped by cost for a new Torsen or Quaife Helical LSD. About $2k. There may be some "extra" value to someone looking for a factory style multi plate clutch LSD but then you run into all sorts of questions about whether or not the clutch plates are still serviceable and how worn the LSD housing might be, how worn the springs are, and the parts that are either NLA or hard to find. There was an OEM plate style LSD on F/S about a year ago that went to about $1600, it also came with the appropriate transmission stubs that are hens teeth. http://www.914world.com/bbs2/index.php?sho...338115&st=0 YRMV. |
| EdwardBlume |
Jul 1 2020, 02:20 PM
Thanks for the input and good to know the details. I’ll see if I can find a good home that will use it!
| sixnotfour |
Jul 1 2020, 02:57 PM
| horizontally-opposed |
Jul 1 2020, 06:20 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,456 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None
Curious if people have a preference once "factory-ishness" and cost are taken out of the equation.
Drove a car with a torque-biasing diff a few years ago and didn't like it. Might have been a matter of suspension setup, but the car had odd tendencies as you rolled into the throttle on the way out of tight turns. It made me wonder if I might prefer the Quaife or factory LSD. |
| Montreal914 |
Jul 1 2020, 11:40 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,197 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
| Superhawk996 |
Jul 2 2020, 06:12 AM
Curious if people have a preference once "factory-ishness" and cost are taken out of the equation. Drove a car with a torque-biasing diff a few years ago and didn't like it. Might have been a matter of suspension setup, but the car had odd tendencies as you rolled into the throttle on the way out of tight turns. It made me wonder if I might prefer the Quaife or factory LSD. All LSD's will induce understeer on corner exit. Nature of the beast. It's a matter of degree depending on the the spec's of the LSD. If you set up the LSD to not do much bias on wheel slip, you won't get as much understeer tendency. But . . . no free lunch . . . you loose the effectivenss of the LSD when you have lots of wheel slip. The suspension can be set up (via springs, shocks, and bars) to have more tendency to oversteer to offset the LSD understeer. But of course that brings along a whole new set of problems. Oversteer is not desirable and it also become load dependent on a street car which is not as much of an issue on a race car. Modern electronic LSD's solve this problem to a large degree by being able to tune how and when the LSD activates. |
Lo-Fi Version | Time is now: 21st September 2026 - 06:30 PM |
