Front oil cooler, Which model works |
RFoulds |
Aug 31 2020, 04:32 PM
Green Teen 66 Group: Members Posts: 837 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region |
Looking for the correct front oil cooler, preferable Setrab, to mount in front. The Patrick Motorsports one is 21.5 x 4.25, so I am guessing that is the maximum size I can go. Looking for a cheaper or direct alternative rather than spend $450 on the PMS one.
Retroracer |
Aug 31 2020, 04:45 PM
Senior Member Group: Members Posts: 622 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
Hey - I extracted one from a Mercedes 300D in the local pick n pull. It sits vertically in the Mercedes, but fits nicely (horizontally) in the GT style front mount shroud area. The fittings are each end and metric, and you'll have to fab up your own mounts, but otherwise its a functional, high "value for money" option. Made by Behr as well, keeping that Germanic flavor to your freshly cooled oil.
FYI, - Tony |
Retroracer |
Aug 31 2020, 04:51 PM
Cairo94507 |
Aug 31 2020, 04:53 PM
Michael Group: Members Posts: 10,125 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Mazda RX-7 Oil cooler?
davep |
Aug 31 2020, 05:48 PM
914 Historian Group: Benefactors Posts: 5,220 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Tony, what are the dimensions of this Mercedes 300D oil cooler. Any particular years.
RFoulds |
Aug 31 2020, 05:52 PM
Youre on to something with the Behr 300D cooler. Dimensions check out and used on EBay under $100, even new aluminum version only $250. Much better. Thanks
RFoulds |
Aug 31 2020, 05:54 PM
mb911 |
Aug 31 2020, 05:58 PM
914 Guru Group: Members Posts: 7,354 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I used the huge RSR sized cooler from CFR coolers but the Rx7 was the staple for years and years
Steve |
Aug 31 2020, 05:59 PM
914 Guru Group: Members Posts: 5,764 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
infraredcalvin |
Aug 31 2020, 06:57 PM
Distracted Member Group: Members Posts: 1,575 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Mazda RX-7 Oil cooler? You have to cut the shroud to make the RX7 cooler work, but it is doable I have this in my race car installed by the PO, itβs working very well this season. Got a hot one coming up this weekend in Fontana. |
porschetub |
Aug 31 2020, 08:31 PM
Advanced Member Group: Members Posts: 4,750 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
(IMG:style_emoticons/default/agree.gif) excellent choice ,when buying used get it cleaned ,you can soak it in a bath or get a ultrasonic clean which is best,amazing the shit that comes out after years of use. Diesel cars coolers tend to get really dirty which reduces oil cooling,petrol cars to a much lesser extent. |
Aug 31 2020, 09:06 PM
914-6 GT in waiting Group: Members Posts: 19,642 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/agree.gif) excellent choice ,when buying used get it cleaned ,you can soak it in a bath or get a ultrasonic clean which is best,amazing the shit that comes out after years of use. Diesel cars coolers tend to get really dirty which reduces oil cooling,petrol cars to a much lesser extent. Used coolers cost $75-150 + ship to get it clean and you are still risking your engine if something gets loose and travels through the oil path. |
Krieger |
Aug 31 2020, 10:41 PM
Advanced Member Group: Members Posts: 4,766 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Mazda RX-7 Oil cooler? You have to cut the shroud to make the RX7 cooler work, but it is doable I had one on my 6 cylinder track car. You need to do a bit of work to get the cooler to flow. Larger AN fittings, grind out a narrow inlet. |
bdstone914 |
Sep 1 2020, 07:40 AM
bdstone914 Group: Members Posts: 4,731 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@RFoulds
date='Aug 31 2020, 04:52 PM' post='2847509'] Youre on to something with the Behr 300D cooler. Dimensions check out and used on EBay under $100, even new aluminum version only $250. Much better. Thanks [/quote] I have a couple of them with the swivel fittings. They are a perfect fit and a quality Ferman made Behr cooler. Bruce |
bdstone914 |
Sep 1 2020, 07:45 AM
@davep
date='Aug 31 2020, 04:48 PM' post='2847507'] Tony, what are the dimensions of this Mercedes 300D oil cooler. Any particular years. [/quote] There are at least three different heights used on diesel Mercedes. Ranging in height from 2.75 to 5 inches in height. |
gms |
Sep 1 2020, 07:55 AM
Advanced Member Group: Members Posts: 2,707 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
sixnotfour |
Sep 1 2020, 08:41 AM
914 Wizard Group: Members Posts: 10,671 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE I prefer this Behr cooler me two , but have used mazda after market ones with enlarged fittings, Erics gts use it also |
Retroracer |
Sep 1 2020, 08:58 AM
Me too, Glenn. Me too..! - Tony |
Montreal914 |
Sep 1 2020, 09:21 AM
Senior Member Group: Members Posts: 1,725 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Retroracer |
Sep 1 2020, 09:50 AM
@Montreal914 - looks like a smaller version of the one I have. Attached shot shows part number as well:
@davep - the dimensions are (roughly) 20" wide and 4" high. It fits in nicely in a GT shroud without having to make cuts. - Tony |
Lo-Fi Version | Time is now: 22nd December 2024 - 12:10 AM |
