> Judging CV Joint Wear?
bkrantz
post Sep 15 2020, 08:11 PM
I am pretty sure my car's original(?) CV joints have excess wear. Take a look.
bkrantz
Cage wear.
bkrantz
post Sep 15 2020, 08:12 PM
Inner flange wear.
Any comments? I think these are toast.
What do people like for replacement joints?
914Sixer
post Sep 16 2020, 06:11 AM
Is there grooves where the wear is? No pitting on the balls. If not assemble them with no grease and feel for slack. Some slack is ok, just so it is not sloppy.
wndsrfr
post Sep 16 2020, 06:29 AM
In my opinion those are shot. Get new so you can sleep at night.
Mark Henry
post Sep 16 2020, 06:37 AM
that's what I do!
Run your finger along the groove, if you feel divots they're done.
Those aren't the worse I've seen, if low budget you might get a few more years out of them, but cleaning and packing CV's is a messy job. I'd rather replace and be done with it.
Don't forget the boots while you're at it.
djway
post Sep 16 2020, 12:48 PM
This is one case where Feeling Groovy is not a good thing....
brant
post Sep 16 2020, 01:02 PM
I agree.
those are worn... but not completely worn out
you can reverse them, switch them around and wear in a different pattern to extend the life.
the available modified VW joints have not held up as long as stock joints in my experience....
so using these on the street in a mild application... especially if they are moved around... would be fine for a few years. I've put the VW joints onto my race car and had more wear in 2 years... than stock joints wore in 5
914werke
post Sep 16 2020, 03:28 PM
if the wear spots are actual divots not just shiny they are done. Check the balls also. as was mentioned if they are pitted ..toast. The problem is once worn the CV can hyper-extend and all of the sudden you have a clunking coming from the engine bay as the .5 shafts are now striking the drive flange under acceleration.
bkrantz
post Sep 16 2020, 09:15 PM
Thanks, guys. I can definitely feel the grooves and pits, so would rather not reuse these.
Are replacement 914 CV joints unobtanium?
bbrock
post Sep 16 2020, 10:13 PM
QUOTE(bkrantz @ Sep 16 2020, 09:15 PM) *
You can buy complete axles from Porsche for a king's ransom. You can also buy just cv joints but what you will get are 914/6 joints with the wrong spline count for your axles.
porschetub
post Sep 16 2020, 11:00 PM
Reuse them and see ,seen a lot worse ,how they are cleaned and repacked has served me well, re-indexing is ok but to me it is a short time solution.
Any chipping on the races or blue "spots" are a warning ,never seen the balls peel of hardening but seems it could happen ?,so keep your balls good (IMG:style_emoticons/default/biggrin.gif) .
- Lo-Fi Version Time is now: 5th July 2025 - 06:19 PM
