Demick |
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 ![]() ![]() |
Duane
With that setup, I would recommend running the fan at all times (at least at a reduced speed). When the fan is not running, the engine fan is pulling air through the cooler in the opposite direction and heating up the air in your engine compartment (hence, preheating the air that your engine uses for cooling as well as the air going into the intake). Ideally, you want to keep the air flow direction always going from the engine bay to the fender. Running the fan will ensure this is always the case. Demick |
Joseph Mills |
on a Sonoma diet now... ![]() ![]() ![]() Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 ![]() |
Brant, Good point, although I run a stock valence. But, my car is lowered. The front doughnut is 4.5" so as you point out, there has to be "some" loss of air movement there. Plus, a stock cooling system is just barely adequate in warmer climates. Plus, my engine has Euro P/Cs & flycut heads so compression is bumped a bit, plus a moderate cam. It produces a bit more HP than stock, so it's going to produce a bit more heat. I'm not convinced that my cooling would be resolved by raising the car. Anyway, it is set up for AX and is corner balanced with a 50% cross reading. Not going to touch that! (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) I may just hang the cooler off the trunk, but I'm "thinking about" fitting it into the fender well, inspite of others opinions that are much more knowlegeable than mine. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Do you have any other pics of your car? I'm thinking of a similar paint scheme. |
Joseph Mills |
Duane, Thanks for the info and pic. That configuration had not occured to me. Demick has pointed this out... have you tried running the fan all the time? My cooler is narrow enough that it can be placed at a right angle to yours. I'm considering putting an air intake (scoop) on my rocker panel and also under it for fresh air. Plus the two fans. Along with a protective screen on standoffs on the back side to keep debris off. If it turns out that it increases my engine temps, I'll just use it in the winter (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,642 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Joseph....
so if your running a stock valance (no spoiler?) then I'm probably wrong about the lack of airflow. the situation I had back when was one of those rubber lipped spoilers that was 1 inch off of the ground and allowed no air flow at the highway at 80mph send me your email address and I'll link you into my ofoto's for more pics. brant |
Lo-Fi Version | Time is now: 23rd June 2024 - 12:43 PM |
