Rust repair before paint, The quest for solid metal in the driver side Long - 73 narrow body/4 rebuild thread |
friethmiller |
Aug 27 2024, 06:48 AM
Senior Member Group: Members Posts: 618 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
Just looking through your latest post / pictures. Excellent work. The heater pipe is pretty easy to do. Just don't try to weld the heat tube clips to the longitudinal - like I did on my first 914 (IMG:style_emoticons/default/headbang.gif). Didn't work. I overside the holes just a bit and go with a larger pop-rivet. Depending on the amount of rust work needed for the inner rocker and inner wheelhouse area, you'll be buttoning up the drivers side soon.
dtmehall |
Aug 28 2024, 06:28 PM
Newbie Group: Members Posts: 16 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
Here are photos from the work in process on my car in the body shop, with the end result
dtmehall |
Aug 28 2024, 07:23 PM
btw, the body shop working on my car fabricated all the panels.
Lo-Fi Version | Time is now: 16th September 2024 - 12:59 PM |
