| Ebradley |
Nov 20 2020, 01:50 PM
Member ![]() ![]() Group: Members Posts: 60 Joined: 16-April 20 From: California Member No.: 24,142 Region Association: Southern California |
Hi all
I recently drove my 74 Porsche 914 2.0 on a hot day and the car would not start after driving. I thought maybe vapor Lock. Drove it yesterday and it was 78degrees and the same thing happened. Normally drives amazing. After driving, stalled at the traffic light. Then would just turn over but no start. Do you think it’s vapor lock? After 15min it started up and I was on my way Thanks for the advice |
| ctc911ctc |
Nov 20 2020, 03:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,395 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
Start with the easy stuff.
Engine Temp Sensor is where I would start. Also: https://members.rennlist.com/pbanders/DJetP...tm#troubleshoot Report back with more details, we will solve this with you, Hi all I recently drove my 74 Porsche 914 2.0 on a hot day and the car would not start after driving. I thought maybe vapor Lock. Drove it yesterday and it was 78degrees and the same thing happened. Normally drives amazing. After driving, stalled at the traffic light. Then would just turn over but no start. Do you think it’s vapor lock? After 15min it started up and I was on my way Thanks for the advice |
| Lg914 |
Nov 20 2020, 04:33 PM
Member ![]() ![]() Group: Members Posts: 53 Joined: 4-July 19 From: Lake Geneva Member No.: 23,275 Region Association: None |
It sounds like it could be the fuel filter. After a bit of sitting, enough fuel seeps trough to get it running for a bit till it staves out.
| JamesM |
Nov 20 2020, 06:21 PM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Is it still fuel injected?
Where is the fuel pump in the front or the rear? |
| Ebradley |
Nov 21 2020, 12:25 AM
Yes, original fuel injection. Fuel pump in stock location. Car gas 109,000 original miles
| ClayPerrine |
Nov 21 2020, 05:30 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
That does sound like the typical symptoms of vapor lock.
Hook a fuel pressure gauge to it and verify it is loosing fuel pressure when the problem happens. The fix is to move the pump up front. If you do move it, then replace the fuel lines with a set of the stainless steel Tangerine lines. The old plastic lines have been known to fail and cause engine fires. |
| Tdskip |
Nov 21 2020, 07:05 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,784 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
If that happens again try flooring it to see if it will catch, same thing happened in my Saab 99 which uses the same system.
Not a fix, but might get you back and running faster. |
Lo-Fi Version | Time is now: 18th November 2026 - 03:36 PM |
