rear trunk gas strut modification?, Tips, parts, location. |
930cabman |
Sep 5 2024, 04:07 PM
Advanced Member Group: Members Posts: 3,834 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
thanks for all the replies...seems like some like it and some dont. on mine, the torsion bars had ripped one side of the hinge mount off and the PO put it back in there with some screws. I think ill order the JWest kit to fix that. (IMG:style_emoticons/default/welcome.png) I have a set on the shelf and will be installing after paint, hopefully will be fine |
rhodyguy |
Sep 5 2024, 04:14 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,207 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
With new paint and all, you might consider installing the bases first. Welding and working around fresh paint could be disastrous. There’s usually some rust to contend with.
930cabman |
Sep 5 2024, 04:27 PM
With new paint and all, you might consider installing the bases first. Welding and working around fresh paint could be disastrous. There’s usually some rust to contend with. Thanks for the heads up, rust is 0, but a good idea to install, remove for paint and reinstall after |
Lo-Fi Version | Time is now: 15th January 2025 - 09:07 AM |
