Nuts and Bolts, Sourcing the right hardware. |
mlindner |
Jan 10 2021, 05:52 AM
Senior Member Group: Members Posts: 1,598 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Yup, Belmetric and also McMaster.
Jan 10 2021, 07:24 AM
914-6 GT in waiting Group: Members Posts: 19,679 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Thanks @914e for this great shopping list. Super helpful. I'd add M8 schnorr washers for the CV bolts (16...but since you need to replace at least 8 of them every time you drop the engine, I'd get 50). I remember also using schnorr washers under the bolts on the strut tower plates. |
iankarr |
Jan 10 2021, 10:55 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,528 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Good call. M10 yellow.
914werke |
May 3 2022, 02:36 PM
"I got blisters on me fingers" Group: Members Posts: 11,038 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
resurrection:
The OE case through bolts used a "nylock" style nut that had a red top sealant on it. Are those OE fasteners still available? (IMG:style_emoticons/default/idea.gif) M10x1.25 17mm head 10mm tall part # 021101131E @CHIZ 914 Porsche classic shows the Bolt & the thick washer but not the Nut? Attached thumbnail(s) |
Root_Werks |
May 4 2022, 09:24 AM
Village Idiot Group: Members Posts: 8,525 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
brant |
May 4 2022, 09:34 AM
914 Wizard Group: Members Posts: 11,828 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
resurrection: The OE case through bolts used a "nylock" style nut that had a red top sealant on it. Are those OE fasteners still available? (IMG:style_emoticons/default/idea.gif) M10x1.25 17mm head 10mm tall part # 021101131E @CHIZ 914 Porsche classic shows the Bolt & the thick washer but not the Nut? Rich, I recently bought some of those nuts as they are used to seal the oil pump I went to a VW bug shop on line and bought them brant |
914werke |
May 4 2022, 11:01 AM
Thanks Brant I see those M8 nuts are still available. Good to know.
Unfortunately not the M10 ones. Funny I was corresponding with a rep from Belmetric & said they'd never seen anything like that before (IMG:style_emoticons/default/biggrin.gif) |
zoomCat |
Jan 19 2023, 01:50 PM
Member Group: Members Posts: 185 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None |
Hi All. As we dig deeper into our 914, we are finding a random assortment of nuts and bolts that I expect were incorporated into the car over the years. While I am not trying to source original hardware, I’d like to swap the odd ones out to be at more consistent (and, of course replacing any trashed/ rounded over/ damaged ones). Buying one or two at a time is going to get expensive and I cannot find a good reference for the right grade to use anyway (5.8, 8.8, 10.9, 12.9). Is there a short list of the most common hardware found on our cars that I could use to start a collection of new ones? Thank You! I just happened to place an order with Belmetric, This isn't every nut bolt and screw. It is about every m5, 6, 8,10, and 12 except the engines hardware. I also have 3 German cars so there is few spares. I'm buying steel cabinets with plastic divided boxes from Bolt depot. My attempt to have an ACE hardware in my garage, plus the hardware will be the right color. I hope to cut back on my weekly runs to ACE and returning with a tiny bag of hardware that I spent $20 on. 10 x BR6X8YLW - Hex Bolt 8.8 Yellow Zinc $1.60 25 x BR6X10YLW - Hex Bolt 8.8 Yellow Zinc $4.25 25 x BR6X12YLW - Hex Bolt 8.8 Yellow Zinc $4.50 10 x BR6X14YLW - Hex Bolt 8.8 Yellow Zinc $2.30 25 x BR6X20YLW - Hex Bolt 8.8 Yellow Zinc $5.25 4 x BR6X18YLW - Hex Bolt 8.8 Yellow Zinc $0.96 4 x BR6X16YLW - Hex Bolt 8.8 Yellow Zinc $0.72 10 x BR6X30PYLW - Hex Bolt 8.8 Yellow Zinc Partial $2.30 25 x BR8X10YLW - Hex Bolt 8.8 Yellow Zinc $5.50 5 x BR8X14YLW - Hex Bolt 8.8 Yellow Zinc $1.45 20 x BR8X16YLW - Hex Bolt 8.8 Yellow Zinc $5.60 10 x BR8X20YLW - Hex Bolt 8.8 Yellow Zinc $2.90 10 x BR8X25YLW - Hex Bolt 8.8 Yellow Zinc $3.70 11 x BR8X30PYLW - Hex Bolt 8.8 Yellow Zinc Partial $4.29 10 x BR8X40PYLW - Hex Bolt 8.8 Yellow Zinc Partial $4.10 10 x BR8X45PYLW - Hex Bolt 8.8 Yellow Zinc Partial $4.50 4 x BR10X85YLW - Hex Bolt 8.8 Yellow Zinc $4.68 10 x BR10X18YLW - Hex Bolt 8.8 Yellow Zinc $4.70 10 x BR10X20YLW - Hex Bolt 8.8 Yellow Zinc $4.20 4 x BR10X22YLW - Hex Bolt 8.8 Yellow Zinc $1.88 4 x BR10X16YLW - Hex Bolt 8.8 Yellow Zinc $1.60 4 x BR10X25YLW - Hex Bolt 8.8 Yellow Zinc $1.88 4 x BR10X30YLW - Hex Bolt 8.8 Yellow Zinc $1.96 4 x BR10X35YLW - Hex Bolt 8.8 Yellow Zinc $2.24 10 x BR5X10YLW - Hex Bolt 8.8 Yellow Zinc $2.40 10 x BR5X20YLW - Hex Bolt 8.8 Yellow Zinc $2.40 4 x BR5X12YLW - Hex Bolt 8.8 Yellow Zinc $0.96 4 x BR5X22YLW - Hex Bolt 8.8 Yellow Zinc $0.96 4 x BR12X80PYLW - Hex Bolt 8.8 Yellow Zinc Partial $6.12 10 x BR12X30YLW - Hex Bolt 8.8 Yellow Zinc $7.10 4 x BR12X60PYLW - Hex Bolt 8.8 Yellow Zinc $3.56 50 x WF6YLW - Flat Washer Yellow Zinc $4.50 50 x WF8YLW - Flat Washer Yellow Zinc $6.00 20 x WF6X11YLW - Flat Washer Small OD Yellow Zinc $1.80 10 x WF8X15YLW - Flat Washer Small OD Yellow Zinc $1.20 25 x WFHV6YLW - Hardened Flat Washer Yellow Zinc $3.25 10 x WW6AMECYLW - Wave Washer Mechanical Yellow Zinc $1.20 10 x WW7BYLW - Wave Washer Yellow Zinc $2.10 10 x WSH6YLW - Schnorr Washer Yellow Zinc $1.90 10 x WSH7MECYLW- Schnorr Washer Mechanical Yellow Zinc $2.60 25 x WL5MECYLW - Lock Washer Mechanical Yellow Zinc $2.00 25 x WL6MECYLW - Lock Washer Mechanical Yellow Zinc $2.00 25 x WL8MECYLW - Lock Washer Mechanical Yellow Zinc $3.50 25 x WL10MECYLW - Lock Washer Mechanical Yellow Zinc $3.75 10 x WL12MECYLW - Lock Washer Mechanical Yellow Zinc $1.90 20 x NR6YLW - Hex Nut Yellow Zinc Class 8 $2.00 20 x NR8YLW - Hex Nut Yellow Zinc Class 8 $3.20 10 x NR10YLW - Hex Nut Yellow Zinc Class 8 $2.30 4 x NR12YLW - Hex Nut Yellow Zinc Class 8 $1.00 4 x NNFH6YLW - Nylock Flange Nut Yellow Zinc HARDENED $1.16 4 x NNFH8YLW - Nylock Flange Nut Yellow Zinc HARDENED $1.44 4 x NNFH10YLW - Nylock Flange Nut Yellow Zinc HARDENED $1.96 20 x E302NT - 6.3mm Uninsulated Spade 16-14 Gauge No Tab $7.00 20 x E922TABBRS - 6.3mm Uninsulated Spade 18-16 Gauge With Tab $6.80 4 x E308BRS - 6.3mm Uninsulated Male Spade With Tab 16-14 Gauge $2.04 10 x E922NTTIN - 6.3mm Uninsulated Spade 20-17 Gauge No Tab $4.00 $171.16Sub-Total: $0.00Free Shipping Options (EXPECT DELAYS - Free Shipping): $171.16 I put this list into a CSV file, which can be used on Belmetric's Quick Order page. You can edit the file, or it is probably easier to edit after it's been uploaded. The Belmetric upload function is pretty hapless, if you make changes to the file that don't fit it's narrow requirements it will often just fail without any message. Belmetric_Hardware_Quick_Order__csv_.txt ( 1.02k ) Number of downloads: 86 |
Chaznaster |
Jan 19 2023, 07:11 PM
Member Group: Members Posts: 325 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
Hi All. As we dig deeper into our 914, we are finding a random assortment of nuts and bolts that I expect were incorporated into the car over the years. While I am not trying to source original hardware, I’d like to swap the odd ones out to be at more consistent (and, of course replacing any trashed/ rounded over/ damaged ones). Buying one or two at a time is going to get expensive and I cannot find a good reference for the right grade to use anyway (5.8, 8.8, 10.9, 12.9). Is there a short list of the most common hardware found on our cars that I could use to start a collection of new ones? Thank You! I just happened to place an order with Belmetric, This isn't every nut bolt and screw. It is about every m5, 6, 8,10, and 12 except the engines hardware. I also have 3 German cars so there is few spares. I'm buying steel cabinets with plastic divided boxes from Bolt depot. My attempt to have an ACE hardware in my garage, plus the hardware will be the right color. I hope to cut back on my weekly runs to ACE and returning with a tiny bag of hardware that I spent $20 on. 10 x BR6X8YLW - Hex Bolt 8.8 Yellow Zinc $1.60 25 x BR6X10YLW - Hex Bolt 8.8 Yellow Zinc $4.25 25 x BR6X12YLW - Hex Bolt 8.8 Yellow Zinc $4.50 10 x BR6X14YLW - Hex Bolt 8.8 Yellow Zinc $2.30 25 x BR6X20YLW - Hex Bolt 8.8 Yellow Zinc $5.25 4 x BR6X18YLW - Hex Bolt 8.8 Yellow Zinc $0.96 4 x BR6X16YLW - Hex Bolt 8.8 Yellow Zinc $0.72 10 x BR6X30PYLW - Hex Bolt 8.8 Yellow Zinc Partial $2.30 25 x BR8X10YLW - Hex Bolt 8.8 Yellow Zinc $5.50 5 x BR8X14YLW - Hex Bolt 8.8 Yellow Zinc $1.45 20 x BR8X16YLW - Hex Bolt 8.8 Yellow Zinc $5.60 10 x BR8X20YLW - Hex Bolt 8.8 Yellow Zinc $2.90 10 x BR8X25YLW - Hex Bolt 8.8 Yellow Zinc $3.70 11 x BR8X30PYLW - Hex Bolt 8.8 Yellow Zinc Partial $4.29 10 x BR8X40PYLW - Hex Bolt 8.8 Yellow Zinc Partial $4.10 10 x BR8X45PYLW - Hex Bolt 8.8 Yellow Zinc Partial $4.50 4 x BR10X85YLW - Hex Bolt 8.8 Yellow Zinc $4.68 10 x BR10X18YLW - Hex Bolt 8.8 Yellow Zinc $4.70 10 x BR10X20YLW - Hex Bolt 8.8 Yellow Zinc $4.20 4 x BR10X22YLW - Hex Bolt 8.8 Yellow Zinc $1.88 4 x BR10X16YLW - Hex Bolt 8.8 Yellow Zinc $1.60 4 x BR10X25YLW - Hex Bolt 8.8 Yellow Zinc $1.88 4 x BR10X30YLW - Hex Bolt 8.8 Yellow Zinc $1.96 4 x BR10X35YLW - Hex Bolt 8.8 Yellow Zinc $2.24 10 x BR5X10YLW - Hex Bolt 8.8 Yellow Zinc $2.40 10 x BR5X20YLW - Hex Bolt 8.8 Yellow Zinc $2.40 4 x BR5X12YLW - Hex Bolt 8.8 Yellow Zinc $0.96 4 x BR5X22YLW - Hex Bolt 8.8 Yellow Zinc $0.96 4 x BR12X80PYLW - Hex Bolt 8.8 Yellow Zinc Partial $6.12 10 x BR12X30YLW - Hex Bolt 8.8 Yellow Zinc $7.10 4 x BR12X60PYLW - Hex Bolt 8.8 Yellow Zinc $3.56 50 x WF6YLW - Flat Washer Yellow Zinc $4.50 50 x WF8YLW - Flat Washer Yellow Zinc $6.00 20 x WF6X11YLW - Flat Washer Small OD Yellow Zinc $1.80 10 x WF8X15YLW - Flat Washer Small OD Yellow Zinc $1.20 25 x WFHV6YLW - Hardened Flat Washer Yellow Zinc $3.25 10 x WW6AMECYLW - Wave Washer Mechanical Yellow Zinc $1.20 10 x WW7BYLW - Wave Washer Yellow Zinc $2.10 10 x WSH6YLW - Schnorr Washer Yellow Zinc $1.90 10 x WSH7MECYLW- Schnorr Washer Mechanical Yellow Zinc $2.60 25 x WL5MECYLW - Lock Washer Mechanical Yellow Zinc $2.00 25 x WL6MECYLW - Lock Washer Mechanical Yellow Zinc $2.00 25 x WL8MECYLW - Lock Washer Mechanical Yellow Zinc $3.50 25 x WL10MECYLW - Lock Washer Mechanical Yellow Zinc $3.75 10 x WL12MECYLW - Lock Washer Mechanical Yellow Zinc $1.90 20 x NR6YLW - Hex Nut Yellow Zinc Class 8 $2.00 20 x NR8YLW - Hex Nut Yellow Zinc Class 8 $3.20 10 x NR10YLW - Hex Nut Yellow Zinc Class 8 $2.30 4 x NR12YLW - Hex Nut Yellow Zinc Class 8 $1.00 4 x NNFH6YLW - Nylock Flange Nut Yellow Zinc HARDENED $1.16 4 x NNFH8YLW - Nylock Flange Nut Yellow Zinc HARDENED $1.44 4 x NNFH10YLW - Nylock Flange Nut Yellow Zinc HARDENED $1.96 20 x E302NT - 6.3mm Uninsulated Spade 16-14 Gauge No Tab $7.00 20 x E922TABBRS - 6.3mm Uninsulated Spade 18-16 Gauge With Tab $6.80 4 x E308BRS - 6.3mm Uninsulated Male Spade With Tab 16-14 Gauge $2.04 10 x E922NTTIN - 6.3mm Uninsulated Spade 20-17 Gauge No Tab $4.00 $171.16Sub-Total: $0.00Free Shipping Options (EXPECT DELAYS - Free Shipping): $171.16 I put this list into a CSV file, which can be used on Belmetric's Quick Order page. You can edit the file, or it is probably easier to edit after it's been uploaded. The Belmetric upload function is pretty hapless, if you make changes to the file that don't fit it's narrow requirements it will often just fail without any message. Belmetric_Hardware_Quick_Order__csv_.txt ( 1.02k ) Number of downloads: 86 That's awesome! |
Lo-Fi Version | Time is now: 5th January 2025 - 02:03 AM |
