| sjhenry1075 |
Jan 13 2021, 01:22 PM
Member ![]() ![]() Group: Members Posts: 270 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States
Hey everyone. Happy New Year! So is everyone else spending their stimulus on their 914's?
To anyone else who has purchased the speaker pods from 914rubber, what is the best way to cut out the center portion of the pod? |
| Chris914n6 |
Jan 13 2021, 01:33 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,556 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
It's ABS so anything, but watch the heat as it will melt back together and need extra work to make pretty. Also if you can smell it take a break as you don't want to be inhaling the fumes.
| sjhenry1075 |
Jan 13 2021, 01:45 PM
| lierofox |
Jan 13 2021, 03:27 PM
Member ![]() ![]() Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California
For mine I measured the speaker's lip dimensions, then marked and drilled a hole in the center of the opening in the pod for a pivot, and used a dremel with a circle cutting jig. The ones I got were the fiberglass ones though, not the ABS plastic.
| Mikey914 |
Jan 14 2021, 02:34 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
They will cut the same, and the ABS will not leave the glass splinters. One of the reasons we went to ABS
A 5" hole saw works well too. |
| sjhenry1075 |
Jan 14 2021, 07:25 AM
Lo-Fi Version | Time is now: 24th September 2026 - 03:13 AM |
