14 Pages V « < 12 13 14
> Just another home build 2056 upgrade...but this one is mine!, Redux THrÄ“: It's been so FUN lets do it again.....
rfinegan
post Mar 13 2022, 04:39 PM
Post #261
QUOTE(BeatNavy @ Mar 13 2022, 06:23 PM) *
I agree that sucks Robert. Are you sure it's something internal and not something intake or ignitiion related? When you tore it down last time you had evidence of valve interference. Were you getting the same symptoms last time? Those compression numbers look good, so....maybe NOT something internal.
Otherwise I have not clue but hope for the best.
IM still hopeful as its not a catastrophic fail yet.. but the howling is seen on the first 15 min brake in and again on this build and can be heard on the video too. So internal seem likely..I will swap out he starter next as This was new to the 2056 on first start and ez to swap a Bosch in its place. Else its a bearing? I did reuse the bearings from first build as everything "LOOKED" ok and so were the journals
930cabman
post Mar 17 2022, 09:30 AM
Post #262
QUOTE(rfinegan @ Mar 13 2022, 04:39 PM) *
A howling sound might make me think something like gear noise. Could be as simple as a nick on either the cam gear(s) or the distributor drive gear(s). Best of luck
VaccaRabite
post Mar 17 2022, 11:07 AM
Post #263
En Garde!
Is the howling noise the noise you re concerned about what we hear in the video BEFORE you turn the engine over and it sputters a little bit? The video you posted on the 12th?
@rfinegan
If the key is in (I'm guessing it is as the head temps are reading) but the engine is off and something is howling, I'm thinking fuel pump. How is the fuel pressure at the engine?
Zach
rfinegan
post Mar 17 2022, 11:47 AM
Post #264
To me it sounds like a dry bearing and pulls /slow the engine down till a stall. This is the sound it made just prior to my valves bending and pushrods (see first fail). Odd enough, returning the next day the sound was gone and only a miss fire on Cylider 2 (the popping was seen on cylinder one in video)
Currently it is running on 4 cylinders and no noise. I have done several leak downs and compression test. Still in the Diagnostic phase of figuring what the heck is going on. Ever day its something different and new symptoms
Fuel pump is under the hood and 2-3 psi. It is relayed with the key on via the power relay on the play board. Self regulating at the pump
QUOTE(VaccaRabite @ Mar 17 2022, 01:07 PM) *
@rfinegan
Zach
Root_Werks
post Mar 17 2022, 07:46 PM
Post #265
Village Idiot
Could it have been a tight thrust play? Maybe something ground it's way free enough to no longer cause noise, friction and resistance?
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 08:17 PM
