Curbandgutter |
Senior Member ![]() ![]() ![]() Group: Members Posts: 565 Joined: 8-March 13 From: Murrieta CA Member No.: 15,637 Region Association: Southern California ![]() ![]() |
Count me in!!!! Those are awesome. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif)
Aerostatwv |
Member ![]() ![]() Group: Members Posts: 144 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region ![]() ![]() |
Dittos, count me in as well.
Thanks, Chris |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,759 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
These look really nice. What are the color ranges? Does the 850ish price include the hardware or is that separate? Well, The smoke charcoal (same as the ones previously produced is the stock $850 build. I can get green ,Red, yellow a rose smoke color ,and I'm sure there are a few others. What it means is that I have to be able to get the material you want in a reasonable cost Each roof takes a full sheet due to the size. The shipping for the smoke will be divided among the entire lot of them. If I can source the the colored material at the same place them we can add in. The 1st ones for prototype are going to be clear. The hardware is just that. It can use stock hardware to attach, we did make version of the latch that worked, but it costs to make them so we broke them out to hold the costs down. |
Mikey914 |
@Mikey914 How do you adapt to the early and late rear targa latches? The distance between the locating bumps is different. The rubber blocks that fit into them are also different the height and width to match the lower latch. I know if you put an early top on a tale car it will shift side to side. Shims and foam block, can be as easy as big washers. It's not much. |
BillJ |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,273 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None ![]() ![]() |
These look really nice. What are the color ranges? Does the 850ish price include the hardware or is that separate? Well, The smoke charcoal (same as the ones previously produced is the stock $850 build. I can get green ,Red, yellow a rose smoke color ,and I'm sure there are a few others. What it means is that I have to be able to get the material you want in a reasonable cost Each roof takes a full sheet due to the size. The shipping for the smoke will be divided among the entire lot of them. If I can source the the colored material at the same place them we can add in. The 1st ones for prototype are going to be clear. The hardware is just that. It can use stock hardware to attach, we did make version of the latch that worked, but it costs to make them so we broke them out to hold the costs down. Thanks for clarifying and sounds really cool. I have a silver car so smoke is probably the right one unless there is a silver version! Really glad you are making these. |
SO.O.C914er |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,521 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California ![]() |
Put me down for a smokie one......thanks Paul
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,831 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
How about Alaska blue?
Villemi |
Newbie ![]() Group: Members Posts: 48 Joined: 7-January 20 From: France Member No.: 23,807 Region Association: France ![]() |
I'm ok for one too !!! For the color I don't Know
nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
I'm pretty sure I'd be game for this.
How do I get you to make one for the 911 targa (IMG:style_emoticons/default/idea.gif) |
wes |
wes ![]() ![]() ![]() Group: Members Posts: 1,591 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California ![]() ![]() |
If smoke - charcoal was the original that’ll be my order with hardware, And thanks!
IDEFIX63 |
Newbie ![]() Group: Members Posts: 4 Joined: 15-April 18 From: COLUMBIA SC Member No.: 22,039 Region Association: South East States ![]() |
Will you be able to ship to france or at least south carolina (I have a friend there who can help me if shipping to france is too costly...)?
Anyway, you can count me in! this top would be really nice under the sun of france! |
DucRS |
Member ![]() ![]() Group: Members Posts: 105 Joined: 29-May 19 From: Riverbank CA Member No.: 23,173 Region Association: Central California ![]() |
I’d like a smoked/charcoal original colored one.
drem914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,053 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California ![]() ![]() |
If smoke - charcoal was the original that’ll be my order, And thanks! I think I will do one also, if you can squeeze one more in? I have to to empty out my gift card some how. (IMG:style_emoticons/default/piratenanner.gif) |
ahycaramba |
“I live my life a quarter mile at a time.” ![]() ![]() Group: Members Posts: 161 Joined: 17-March 15 From: Murrieta, California Member No.: 18,534 Region Association: Southern California ![]() ![]() |
Count Me in for a smoked one. (IMG:style_emoticons/default/piratenanner.gif)
ValcoOscar |
Garage Life ![]() ![]() ![]() ![]() Group: Members Posts: 2,493 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California ![]() ![]() ![]() |
YES....put me on the list.
CHARCOAL GRAY, SMOKE O |
Mikey914 |
Mikey914 |
Mikey914 |
Will you be able to ship to france or at least south carolina (I have a friend there who can help me if shipping to france is too costly...)? Anyway, you can count me in! this top would be really nice under the sun of france! Yes we can, they are a decent size so shipping isn't super cheap. If you visit your friend I'd use some silk tape to make handles on the box and call it a checked bag. Either way I'm sure we can ship, as we have sent one to Germany last round. Mark |
zfisher6164 |
Newbie ![]() Group: Members Posts: 41 Joined: 19-January 19 From: California Member No.: 22,809 Region Association: None ![]() ![]() |
I would be in for a charcoal top
Rob914 |
Member ![]() ![]() Group: Members Posts: 115 Joined: 8-April 03 From: Lake Villa, IL Member No.: 541 Region Association: None ![]() ![]() |
Mark,
I'm undecided on color but I'm in for one with hardware. |
Lo-Fi Version | Time is now: 31st March 2025 - 03:32 AM |
