914/6 engine mount mishmash |
Tdskip |
Mar 14 2021, 08:18 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning and thanks for the help yesterday on the oil tank lines.
Can I ask for some help in figuring out what I’ve got going on here. This looks to me like an early design/replica of the factory 914/6 amount but it does not want to work with the work mount that actually bolts on to the engine. When I did a test fit they don’t bolt up properly and the black engine side mount won’t fit vertically and is forced to be offset/angled which isn’t right of course. So either the grey mount is off, the black mount is the wrong one, or these aren’t compatible. I’m not experienced enough to spot the issue, my hunch is the grey mount is OK and the black engine side is incorrect but that is a guess. Thanks for any help you can offer. |
Retroracer |
Mar 14 2021, 08:23 PM
Senior Member Group: Members Posts: 617 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
Yup, you're working through every combination! The sport mounts have the large plate at the top and hang down.
This is very similar to my set up which was sourced from Maddog; its a little different, the "weld on" part has channeling to deal with the loom entry. Now you've go the mounting figured out, you need to work out what exact height to weld it in to the bulkhead.... The best way (IMHO) is to bolt up the dressed engine, tranny to the rear mounts, while supporting the engine at the front, then adjust incrementally to ensure that the engine tin sits parallel to the body skirt, plus all the shift linkage clears the engine. Then mark the ideal bracket height.... So that's the preferred method. I didn't have all the parts when I did it, so ended up close, but not perfect. I had to shim the sports mounts a little to get it where I wanted, so there is some room for adjustment post-welding. Make sure you hit the car centerline though...! - Tony |
930cabman |
Mar 15 2021, 07:37 AM
Advanced Member Group: Members Posts: 3,214 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
maddog |
Mar 15 2021, 10:12 AM
Member Group: Members Posts: 200 Joined: 19-May 03 From: Grand Rapids Michigan Member No.: 710 Region Association: None |
looks like the style of bulkhead mount that AA sells?
http://www.autoatlanta.com/Porsche-Bulkhea...PN-RMIS200.html |
Mar 15 2021, 10:26 AM
914-6 GT in waiting Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
ClayPerrine |
Mar 15 2021, 01:53 PM
Life's been good to me so far..... Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Mar 15 2021, 02:05 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Lo-Fi Version | Time is now: 26th June 2024 - 06:27 AM |
