Idle hunting, Where do I start? |
steuspeed |
Mar 16 2021, 07:24 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
I'm working on fixing my idle search. All new vacuum lines, plugs and wires. Car starts and runs smooth for about 1-2minutes, then the idle dumps and starts hunting up and down. My ECU knob was turned full clockwise by the PO. I turned it back to the factory setting.
Stock 2.0L 1973 car with Pertronix. Where should I look next? |
Bleyseng |
Mar 16 2021, 11:36 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Do you have the resistor installed?
rjames |
Mar 17 2021, 01:14 AM
I'm made of metal Group: Members Posts: 4,157 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Are you sure no vacuum leaks?
Does changing the position of the ECU knob do anything? Are all of the FI parts correct for your car? Has the MPS been rebuilt or futzed with? |
wonkipop |
Mar 17 2021, 01:24 AM
Advanced Member Group: Members Posts: 4,667 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
not sure i can help as have a 1.8 L jet.
but have had an idle hunting issue and i think i cracked it....maybe. but perhaps not the same symptoms as yours. the cars are getting old, that maybe new issues arise in relation to materials etc. who knows. its fun sorting them out. see here what i found. don't read the whole thing. just go to my last post. http://www.914world.com/bbs2/index.php?showtopic=352145 hope you crack the problem. (IMG:style_emoticons/default/beerchug.gif) |
steuspeed |
Mar 17 2021, 04:59 PM
I see a white wire/connector/black wire to cylinder head temp sensor. I do not see a resistor. Can I probe the white wire back to the ECU?
steuspeed |
Mar 17 2021, 05:17 PM
Are you sure no vacuum leaks? Does changing the position of the ECU knob do anything? Are all of the FI parts correct for your car? Has the MPS been rebuilt or futzed with? Pretty sure no vacuum leaks. Car start and runs nice. I can adjust the idle to say 1100 for warm up. After about 1 min the idle drops and starts hunting. It will hunt and die with the ECU knob in the factory location. If I turn the knob fully clockwise it will still hunt but barley stay alive. The MPS epoxy is gone, so someone has at least turned the outer screw. I tried to get it out, but it only turns about 2x back and forth. The coils read 87.6 ohms and 339.7 ohms. No continuity between coils. I believe all the FI parts are correct and there except Decel valve has been removed. Caps on air box. |
BeatNavy |
Mar 17 2021, 05:50 PM
Certified Professional Scapegoat Group: Members Posts: 2,944 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I think you're running lean. You need to troubleshoot the things that can cause that condition:
1. Low fuel pressure 2. Clogged injectors 3. Incorrect TPS calibration (although it seems like your idle knob IS making a difference) 4. Bad or poorly tuned MPS 5. Missing (or bad) D-Jet component, e.g., as Bleyseng says, ballast resistor. 6. etc. etc. Try disconnecting the TI (ambient air temp) sensor. That will enrichen things a tad. See what impact that has, if any. Are you seeing any symptoms outside of idle? Poor power or hesitation, bucking, etc.? I assume you don't have an O2 sensor / gauge. |
914werke |
Mar 17 2021, 06:09 PM
"I got blisters on me fingers" Group: Members Posts: 11,022 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/agree.gif) hunting idle is usually a symptom of lean AFR
mgphoto |
Mar 17 2021, 09:44 PM
"If there is a mistake it will find me" Group: Members Posts: 1,366 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Most times it’s the idle screw on the throttle body, its screwed out to far.
cary |
Mar 17 2021, 11:01 PM
Concur with Rob & Rich, too lean.
steuspeed |
Mar 18 2021, 12:09 AM
What should the start idle be set at? |
steuspeed |
Mar 18 2021, 12:10 AM
BeatNavy |
Mar 18 2021, 05:18 AM
I wouldn't worry too much about the idle bypass screw at this point. You can try adjusting it to see what happens, but if you are lean it isn't going to have that much impact. That's actually another symptom of a lean idle condition -- idle bypass not having much impact on idle speed.
Confirm you are running lean and then figure out why. Again, any symptoms under driving conditions, or only idle? |
steuspeed |
Mar 18 2021, 03:36 PM
I think you're running lean. You need to troubleshoot the things that can cause that condition: 1. Low fuel pressure 2. Clogged injectors 3. Incorrect TPS calibration (although it seems like your idle knob IS making a difference) 4. Bad or poorly tuned MPS 5. Missing (or bad) D-Jet component, e.g., as Bleyseng says, ballast resistor. 6. etc. etc. Try disconnecting the TI (ambient air temp) sensor. That will enrichen things a tad. See what impact that has, if any. Are you seeing any symptoms outside of idle? Poor power or hesitation, bucking, etc.? I assume you don't have an O2 sensor / gauge. I checked in my 74 car for a resistor. None in that car either. I swapped the MPS and no change. I disconnected the air temp sensor. No change either. The car runs great. Lots of power. No hesitation or bucking. No O2 sensor. Hands free key starts. Idles nice for about 1-2 minutes before going into oscillation. |
steuspeed |
Mar 18 2021, 03:38 PM
I wouldn't worry too much about the idle bypass screw at this point. You can try adjusting it to see what happens, but if you are lean it isn't going to have that much impact. That's actually another symptom of a lean idle condition -- idle bypass not having much impact on idle speed. Confirm you are running lean and then figure out why. Again, any symptoms under driving conditions, or only idle? The idle screw is working well. I can dial up any idle I choose. I found 1500-1800 cold on another thread. |
saigon71 |
Mar 19 2021, 05:33 AM
Advanced Member Group: Members Posts: 2,006 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Agreed that you are running lean at idle.
Start by turning the idle mixture knob on your ECU clockwise all the way - this is full rich. If this smooths out your idle, turn the knob counterclockwise a click at a time until the engine idle starts to hunt, then back off one click. Give the engine a little time to adjust between each adjustment. If that doesn't work: The 1973 model year used a ballast resistor of 270 ohms from the factory - it seems you are missing this. Pick up a resistor of this value and wire it in series with the CHT temp sender. This resistor effectively richens the mixture accross all operating conditions. Keep us posted on what you find. Good luck! |
JamesM |
Mar 19 2021, 08:45 AM
Advanced Member Group: Members Posts: 2,019 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Agreed that you are running lean at idle. Start by turning the idle mixture knob on your ECU clockwise all the way - this is full rich. If this smooths out your idle, turn the knob counterclockwise a click at a time until the engine idle starts to hunt, then back off one click. Give the engine a little time to adjust between each adjustment. If that doesn't work: The 1973 model year used a ballast resistor of 270 ohms from the factory - it seems you are missing this. Pick up a resistor of this value and wire it in series with the CHT temp sender. This resistor effectively richens the mixture accross all operating conditions. Keep us posted on what you find. Good luck! That^^ Also should add though that the resistor was only used on some of the 73 cars, this (and a few other things) changed through the 73 production run and the later 73 cars use the same setup as the 74 cars. Need to verify your ECU and MPS part numbers to see what is in there. If you search you may be able to find the cutover date/vin as i know that information is out there, just dont recall off the top of my head, and it isnt reliable anyways as a lot of cars have swapped parts at this point. But, if it is running fine everywhere else, start with the idle mixture knob on the ECU as stated. |
rjames |
Mar 19 2021, 11:39 AM
Agreed that you are running lean at idle. Start by turning the idle mixture knob on your ECU clockwise all the way - this is full rich. If this smooths out your idle, turn the knob counterclockwise a click at a time until the engine idle starts to hunt, then back off one click. Give the engine a little time to adjust between each adjustment. If that doesn't work: The 1973 model year used a ballast resistor of 270 ohms from the factory - it seems you are missing this. Pick up a resistor of this value and wire it in series with the CHT temp sender. This resistor effectively richens the mixture accross all operating conditions. Keep us posted on what you find. Good luck! That^^ Also should add though that the resistor was only used on some of the 73 cars, this (and a few other things) changed through the 73 production run and the later 73 cars use the same setup as the 74 cars. Need to verify your ECU and MPS part numbers to see what is in there. If you search you may be able to find the cutover date/vin as i know that information is out there, just dont recall off the top of my head, and it isnt reliable anyways as a lot of cars have swapped parts at this point. But, if it is running fine everywhere else, start with the idle mixture knob on the ECU as stated. Agree. Go slow with the adjustment knob. Each click or two should make a noticeable difference. |
914_7T3 |
Mar 19 2021, 01:28 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,872 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
My ‘73 had the same symptoms and it was indeed the ECU adjustment. Turned out to be an easy fix.
Lo-Fi Version | Time is now: 22nd December 2024 - 12:28 AM |
