2 Pages V < 1 2
> Early 1970 914 original barn find..., Going to see it Friday, owner finally wants to sell it...
oakdalecurtis
post May 25 2021, 11:29 AM
Post #21
Oakdalecurtis
QUOTE(mepstein @ May 25 2021, 10:02 AM) *
QUOTE(oakdalecurtis @ May 25 2021, 12:16 PM) *
QUOTE(ClayPerrine @ May 25 2021, 08:32 AM) *
Check the numbers on the steering wheel. Lots of 70 914s have the one that is the same as the 911 RSR wheel, and those go for big money.
If it is cheap enough, I would buy it and get it running again.
Clay
Clay and/or Mep, where are the numbers to be found on the steering wheel??? And I presume that when you refer to a "flat porsche hub" that you are referring to the center of the steering wheel?
Numbers and dates are on the front of the hub. Behind the horn pad.
An early four would be:
914.347.804.10 - hard rubber wheel
914.347.805.10 - leather covered wheel
‘72 on went to a VW dimension hub and end in “11”. Same spline count but use a different rear plastic hub spacer and aren’t a perfect fit if you switch early for late or late for early. However the fit is acceptable.
I don't want to mar or damage anything on his car, and my 914 has a Momo wheel, so I'm not familiar with old stock steering wheels. Can the horn pad be gently pried off with a flat screwdriver or is there a better way?
post May 25 2021, 12:01 PM
Post #22
914-6 GT in waiting
QUOTE(oakdalecurtis @ May 25 2021, 01:29 PM) *
Clay
Just twist it off the wheel counter clockwise. Takes a quarter turn and 3 seconds. Twist clockwise to re install.
wonkipop
post May 25 2021, 04:00 PM
Post #23
QUOTE(ClayPerrine @ May 25 2021, 09:32 AM) *
Clay
never knew that.
i have an 804.10 in my box of stuff that i have had since 89.
post May 25 2021, 04:20 PM
Post #24
914-6 GT in waiting
QUOTE(wonkipop @ May 25 2021, 06:00 PM) *
Clay
never knew that.
Early four wheel. ~ $200-250 to the 911 guys.
wonkipop
post May 25 2021, 04:27 PM
Post #25
QUOTE(mepstein @ May 25 2021, 04:20 PM) *
Clay
never knew that.
thanks for tip, i'll let the locals know - its no use to me.
EdwardBlume
post May 26 2021, 08:52 PM
Post #26
1/70 build date?
mangrum
post May 27 2021, 11:12 AM
Post #27
QUOTE(SirAndy @ May 24 2021, 12:41 PM) *
QUOTE(oakdalecurtis @ May 24 2021, 09:32 AM) *
Does everyone agree with Front Yard Mechanic, that, based on what you see and know at this stage, it's only worth 2k?
That early rear bumper is 1k alone, if restored.
Not to mention the early snowplow rear valance.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 4th January 2025 - 11:29 PM
