Fog light hardware?, The bracket to the body |
NARP74 |
Jun 5 2021, 03:56 PM
Senior Member Group: Members Posts: 1,300 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I need a pic of the body mount hardware for the lights, the bracket to the car. The inside looks like a captive nut or something. You can see it under the headlight from the front trunk. Tough angle to get a pic, but it would really be appreciated.
My car, 74 2.0 must have been wrecked at some point and had another front grafted on. It might have been an older one so they used sheet metal screws for mounting the lights that won't hold anymore. PET, pg 285, seems to say it uses a M10 x 16 pan head screw, some sort of spring washer but does not mention the nut. I may just have to hold one back there manually and hope it holds, maybe use a nylock. Not trying to make it perfect, just better than it is now. Thanks in advance for the help. |
Jun 5 2021, 04:14 PM
914-6 GT in waiting Group: Members Posts: 19,648 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
9146C |
Jun 5 2021, 04:20 PM
Member Group: Members Posts: 228 Joined: 14-September 19 From: US Member No.: 23,460 Region Association: None |
Is this what you're looking for? (Not my Ad)
https://www.ebay.com/itm/NICE-CLEAN-USED-OR...T-/283820942881 |
NARP74 |
Jun 5 2021, 05:11 PM
Is this what you're looking for? (Not my Ad) https://www.ebay.com/itm/NICE-CLEAN-USED-OR...T-/283820942881 That is what I do have. I need the hardware that attaches the bracket to the front of the car. The screw seems normal, not sure what the spring washer is, maybe just a lock washer. And the nut is captive to the body somehow. Those are the parts and pics I am looking for. |
9146C |
Jun 5 2021, 05:23 PM
Thanks for the clarification!
On my '72, the mounting nuts were welded to/integral to the front body panel. The attached photo comes from another post here on 914World. The red circle indicates the mounting hole for the horn and the green circle indicates the mounting hole for the fog light. I don't recall exactly the size of the bolt...M10x16 sounds about right for the threaded/welded nut on the front panel. I don't recall if it was a spring washer or a lock washer...sorry. Attached image(s) |
NARP74 |
Jun 5 2021, 05:34 PM
I found a pic from the front. It looks like the nut is able to float around a bit in the hole. What would help is a pic from the inside under the headlight to let me see how it is captured.
edrotol |
Jun 5 2021, 05:55 PM
edrotol Group: Members Posts: 197 Joined: 23-April 06 From: Woburn, MA Member No.: 5,910 Region Association: North East States |
NARP74 |
Jun 5 2021, 06:09 PM
Not what I was expecting. Should have gone here first. Been trying to get the answer for a week or two from searches, friends, local owners. Done in 2 hours. I'll send you a note.
Great resource and community! |
76-914 |
Jun 5 2021, 08:00 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Not what I was expecting. Should have gone here first. Been trying to get the answer for a week or two from searches, friends, local owners. Done in 2 hours. I'll send you a note. Great resource and community! (IMG:style_emoticons/default/welcome.png) We all felt like we'd discovered NIRVANA when we found this site. If the answer ain't here it's probably not been asked yet. (IMG:style_emoticons/default/beerchug.gif) |
Jett |
Jun 5 2021, 08:38 PM
Senior Member Group: Members Posts: 1,672 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Not what I was expecting. Should have gone here first. Been trying to get the answer for a week or two from searches, friends, local owners. Done in 2 hours. I'll send you a note. Great resource and community! (IMG:style_emoticons/default/welcome.png) We all felt like we'd discovered NIRVANA when we found this site. If the answer ain't here it's probably not been asked yet. (IMG:style_emoticons/default/beerchug.gif) +1! Lol |
iankarr |
Jun 5 2021, 08:44 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,526 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
The captive nut for round fog lights is apparently only through 74. For 75-76, the BUBs had rectangular fog lights that lived in the front of the bumper, so the nut below the headlight bucket was eliminated. The shape of the headlight bucket is a little different, too...to make room for the “bumper shock”. (IMG:style_emoticons/default/welcome.png)
L-Jet914 |
Jun 5 2021, 09:45 PM
Member Group: Members Posts: 290 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I need a pic of the body mount hardware for the lights, the bracket to the car. The inside looks like a captive nut or something. You can see it under the headlight from the front trunk. Tough angle to get a pic, but it would really be appreciated. My car, 74 2.0 must have been wrecked at some point and had another front grafted on. It might have been an older one so they used sheet metal screws for mounting the lights that won't hold anymore. PET, pg 285, seems to say it uses a M10 x 16 pan head screw, some sort of spring washer but does not mention the nut. I may just have to hold one back there manually and hope it holds, maybe use a nylock. Not trying to make it perfect, just better than it is now. Thanks in advance for the help. The washers used on the bolt side are a spring washer. I recently installed a set of Hella 118 Euro driving lights/fog lights on my 74 1.8L. I used all new hardware. Stainless steel allen head bolts M10x16 with new wave washers into the captive nuts. I purchased a wave washer kit from amazon with different sized wave washers grant it I didn't need all of them, but now I have extras. |
NARP74 |
Jun 5 2021, 10:43 PM
Thanks everyone.
Does the bolt have a shoulder or is it threaded to the head? I need some more practice reading the PET, the item number for the washer had 23 part numbers in it. Couldn't figure out which one it would be. |
NARP74 |
Jul 10 2021, 10:37 AM
Thought I would share my solution. This car is never going to be correct or perfect again, it's had a hard life, (without too much money). I am just trying to make it better than when I got it.
Solved the problem for about $4 at the local hardware store and a little time. It is much better than it was as you can see by the pic of what used to hold the lights on. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 26th December 2024 - 03:29 PM |
