She lists to Port in rear, Suspension height difference |
Gatornapper |
Jul 2 2021, 09:06 AM
Senior Member Group: Members Posts: 1,262 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
One of the first thing I noticed when I picked up my sweet barn find 914 4 years ago was a height difference in the rear (only) - she lists to port by 1/2".
I have the service record from the local Porsche dealer that about 3,000 miles prior to my getting the car, their shop had replaced the left rear trailing arm bushings. In working extensively on my 14 for the last 4 years (my shop has a lift), I can find no cause for the 1/2" height difference in the body at the rear axle center. Car had 60k original miles when I got it, now 63,600. I believe rear spring/shocks are original, and show no issues. Any help would be appreciated as to cause and fix for the list. TIA, GN |
Jul 2 2021, 09:15 AM
914-6 GT in waiting Group: Members Posts: 19,647 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Every 914 I've purchased with original shocks needed replacement as well as springs. A couple of them had one bad shock and one really bad one (usually on driver side) and made the car crooked.
mrholland2 |
Jul 2 2021, 10:35 AM
Senior Member Group: Members Posts: 761 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Is "port" on a car left or right? (IMG:style_emoticons/default/smile.gif)
VegasRacer |
Jul 2 2021, 10:40 AM
ELVIRA Group: Benefactors Posts: 8,709 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
The sailor Left the Port. |
barefoot |
Jul 2 2021, 11:59 AM
Senior Member Group: Members Posts: 1,334 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Previous owner (before you) must have been quite heavy (IMG:style_emoticons/default/biggrin.gif)
Al Meredith |
Jul 2 2021, 02:34 PM
Senior Member Group: Members Posts: 969 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
Should say "aft " instead of rear. 50 years since I left the USNavy and I still talk like that.
zipedadoo |
Jul 2 2021, 02:52 PM
Member Group: Members Posts: 135 Joined: 23-January 14 From: Arizona Member No.: 16,921 Region Association: None |
Mine did the same thing. I put on new springs, new shocks, new shock rubbers and trailing arm bushings. It still sat lower on the left side. I ended up putting some washers/spacers under the top shock mounting rubber, sits level now. Would have liked to find out exactly what the problem was instead of my back yard engineering fix.
dr914@autoatlanta.com |
Jul 2 2021, 03:45 PM
914 Guru Group: Members Posts: 8,110 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
jack the front slightly from the center of the cross member to take most of the weight off of the front (do not have to lift the tires off of the ground) and see if the rear straightens out. If so the front torsion bars are out of adjustment
Superhawk996 |
Jul 2 2021, 04:05 PM
914 Guru Group: Members Posts: 6,598 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
(IMG:style_emoticons/default/agree.gif) as a 1st step.
Unless you measured the rear spring rates, and the check load, there is no way to say with certainty that the rear springs are OK. Ideally; I’d measure corner weights to see what is going on. Know anyone with race scales? Sometimes local truck stop will work but I have never tried to put something like a 914 on them - might be too short of a wheelbase. |
partwerks |
Jul 2 2021, 08:19 PM
Senior Member Group: Members Posts: 1,599 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
jack the front slightly from the center of the cross member to take most of the weight off of the front (do not have to lift the tires off of the ground) and see if the rear straightens out. If so the front torsion bars are out of adjustment To say it differently, if they are too far out of adjustment, it can twist the rear of the car? How are they adjusted? |
73-914 |
Jul 2 2021, 08:34 PM
Senior Member Group: Members Posts: 599 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None |
Front yard mechanic |
Jul 2 2021, 09:20 PM
Senior Member Group: Members Posts: 1,242 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Get a fat girl friend and drive on bumpy roads (IMG:style_emoticons/default/cheer.gif)
euro911 |
Jul 3 2021, 01:49 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,859 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Should say "aft " instead of rear. 50 years since I left the USNavy and I still talk like that. I bet you still go to the "Head"Poop deck (IMG:style_emoticons/default/stromberg.gif) (IMG:style_emoticons/default/rolleyes.gif) |
zipedadoo |
Jul 3 2021, 07:24 AM
jack the front slightly from the center of the cross member to take most of the weight off of the front (do not have to lift the tires off of the ground) and see if the rear straightens out. If so the front torsion bars are out of adjustment To say it differently, if they are too far out of adjustment, it can twist the rear of the car? How are they adjusted? At the back of the a arms there is an adjusting screw. Lift the front end up a bit, to take the pressure off the screw, and tighten them to raise the front end. I adjusted mine last night and found that my bushings are shot on the left side. |
infraredcalvin |
Jul 3 2021, 08:45 AM
Distracted Member Group: Members Posts: 1,575 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
jack the front slightly from the center of the cross member to take most of the weight off of the front (do not have to lift the tires off of the ground) and see if the rear straightens out. If so the front torsion bars are out of adjustment To say it differently, if they are too far out of adjustment, it can twist the rear of the car? How are they adjusted? @partwerks If this is the same issue for your car, I’d suggest starting a separate thread or posting this question in your thread about upgrading brakes. You’ve got a lot of other things going on with your suspension that need to be better understood before making adjustments to your torsion bars. |
bdstone914 |
Jul 3 2021, 09:25 AM
bdstone914 Group: Members Posts: 4,735 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Gatornapper
Hopefully it is a spring or bushing issue. I had a car that was1-1/2 inch lower on one side. The whole car was twisted was an air launch and landing on the drivers long. You can check for this by removing the top and see if the targa bar is parallel to the windshield frame. |
Gatornapper |
Jul 3 2021, 08:18 PM
George -
Thank you so much. Will do. I haven't noticed any difference in the front, but now that you suggest the problem might be there, I'll measure that too - Not quite sure I know where I should jack from - don't remember a cross member up front - but then I was never looking for one.....I'll find it I'm sure. As always, appreciate the wisdom. GN jack the front slightly from the center of the cross member to take most of the weight off of the front (do not have to lift the tires off of the ground) and see if the rear straightens out. If so the front torsion bars are out of adjustment |
Gatornapper |
Jul 3 2021, 08:21 PM
FRM -
Like the girl I've had for 48 years and she's a tiny size 6 (up from a 4) and maybe 112 lbs.......planning on keeping her. And she's more beautiful now than when we married! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) GN |
worn |
Jul 4 2021, 05:49 PM
can't remember Group: Members Posts: 3,373 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Should say "aft " instead of rear. 50 years since I left the USNavy and I still talk like that. I bet you still go to the "Head" Damn straight. Port is left starboard is right, red lights are the color of port wine. You don’t expect me to believe that everyone doesn’t say avast when you want something to stop, or that when you change lanes you don’t always make sure that the car you just passed is a abaft the stern bumper? |
Gatornapper |
Jul 4 2021, 07:00 PM
George, et al -
Sure nuf. Left front is 3/8" low - but I never measured it as for some reason it's not noticeable in front. My bad. Will adjust left torsion bar see if that evens out the rear. If not, it should get it within 1/8" which will not be perceptible to most. GN jack the front slightly from the center of the cross member to take most of the weight off of the front (do not have to lift the tires off of the ground) and see if the rear straightens out. If so the front torsion bars are out of adjustment |
Lo-Fi Version | Time is now: 26th December 2024 - 09:59 AM |
