She lists to Port in rear, Suspension height difference |
sixnotfour |
Jul 4 2021, 07:06 PM
914 Wizard Group: Members Posts: 10,681 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Depending on Ballast (you) might want to raise the left a bit extra.. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/driving.gif)
Gatornapper |
Jul 7 2021, 08:18 AM
Senior Member Group: Members Posts: 1,262 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
I'm 179 lbs. Think the xtra is probably not needed.
Likely to be 10lbs less by end of summer....... GN Depending on Ballast (you) might want to raise the left a bit extra.. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/driving.gif) |
JamesM |
Jul 7 2021, 09:55 AM
Advanced Member Group: Members Posts: 2,023 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I have the service record from the local Porsche dealer that about 3,000 miles prior to my getting the car, their shop had replaced the left rear trailing arm bushings. Was the camber set properly on the rear after the work was done? If they didnt shim the rear control arms properly it could result in a drop on one side. I would look at that and overall corner balance, but even then, these chassis were hand made and they all have some level of variance |
Gatornapper |
Jul 8 2021, 03:54 AM
FYI -
Instructions on how to correctly set the front torsion bars to spec are found in Chapter 7 of the Haynes Manual, Section 16, p. 106. What's weird is the size of the torsion bar adjustment bolts. 11mm wrench is too small, 12mm too big. I'm 179 lbs. Think the xtra is probably not needed. Likely to be 10lbs less by end of summer....... GN Depending on Ballast (you) might want to raise the left a bit extra.. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/driving.gif) |
Gatornapper |
Jul 14 2021, 04:08 PM
George -
Thank you again for your perfect analysis. But your diagnosis was not only correct, but solved another more important problem that I did not know I had. Setting the torsion bars to spec did indeed solve the height difference between left and right. But it did something far more important. Having never checked the torsion bar settings, I found both to be completely loose. This means that the bars (springs) were not in effect until after the suspension was activated by a bump in the road or a turn. There was slack on both bars! Setting both bars to spec leveled out the car, AND tightened up the handling noticeably - to my great pleasure. It was almost as if I added sway bars! (winter project). GN jack the front slightly from the center of the cross member to take most of the weight off of the front (do not have to lift the tires off of the ground) and see if the rear straightens out. If so the front torsion bars are out of adjustment |
barefoot |
Jul 14 2021, 04:28 PM
Senior Member Group: Members Posts: 1,334 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
FYI - Instructions on how to correctly set the front torsion bars to spec are found in Chapter 7 of the Haynes Manual, Section 16, p. 106. What's weird is the size of the torsion bar adjustment bolts. 11mm wrench is too small, 12mm too big. I think you'll find the 11 MM is correct, clean your bolts (IMG:style_emoticons/default/biggrin.gif) |
Gatornapper |
Jul 15 2021, 08:08 AM
Yes, they are a bit munged up for some reason.....if I file the flats down, I'm sure 11mm will work........next time car is on lift I'll do that.....weird how they got munged up........
Thanks! GN FYI - Instructions on how to correctly set the front torsion bars to spec are found in Chapter 7 of the Haynes Manual, Section 16, p. 106. What's weird is the size of the torsion bar adjustment bolts. 11mm wrench is too small, 12mm too big. I think you'll find the 11 MM is correct, clean your bolts (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 27th December 2024 - 12:31 AM |
