Shifting Issue, Especially 2nd and 4th |
StarBear |
Jul 3 2021, 11:43 AM
Advanced Member Group: Members Posts: 2,085 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Doing shakedown runs getting ready for the NE Gathering. (IMG:style_emoticons/default/driving.gif)
All of a sudden 2nd gear is hard to find 2/3 of the time (resulting in grinding, presumably with reverse) and sometimes 4th is hard to find. Had a new JM West shifter put in this past Fall, replacing all bushings etc. Shifter in need of an adjustment? Clutch seems fine but not ruling that out? Group wisdom greatly appreciated! (IMG:style_emoticons/default/pray.gif) |
dr914@autoatlanta.com |
Jul 3 2021, 01:16 PM
914 Guru Group: Members Posts: 8,110 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
either you broke a bushing, have a loose set screw, or the nut for the splined rod at the back of the shift lever has loosened
Doing shakedown runs getting ready for the NE Gathering. (IMG:style_emoticons/default/driving.gif) All of a sudden 2nd gear is hard to find 2/3 of the time (resulting in grinding, presumably with reverse) and sometimes 4th is hard to find. Had a new JM West shifter put in this past Fall, replacing all bushings etc. Shifter in need of an adjustment? Clutch seems fine but not ruling that out? Group wisdom greatly appreciated! (IMG:style_emoticons/default/pray.gif) |
StarBear |
Jul 3 2021, 02:08 PM
either you broke a bushing, have a loose set screw, or the nut for the splined rod at the back of the shift lever has loosened Doing shakedown runs getting ready for the NE Gathering. (IMG:style_emoticons/default/driving.gif) All of a sudden 2nd gear is hard to find 2/3 of the time (resulting in grinding, presumably with reverse) and sometimes 4th is hard to find. Had a new JM West shifter put in this past Fall, replacing all bushings etc. Shifter in need of an adjustment? Clutch seems fine but not ruling that out? Group wisdom greatly appreciated! (IMG:style_emoticons/default/pray.gif) Thanks! Will check them out. Thought (?) I heard a bit of a clunk under or on the left side of the car a few miles before it started happening. The boot from the firewall is in place as is the cap on the transmission casing. |
windforfun |
Jul 3 2021, 05:36 PM
Senior Member Group: Members Posts: 1,999 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
either you broke a bushing, have a loose set screw, or the nut for the splined rod at the back of the shift lever has loosened Doing shakedown runs getting ready for the NE Gathering. (IMG:style_emoticons/default/driving.gif) All of a sudden 2nd gear is hard to find 2/3 of the time (resulting in grinding, presumably with reverse) and sometimes 4th is hard to find. Had a new JM West shifter put in this past Fall, replacing all bushings etc. Shifter in need of an adjustment? Clutch seems fine but not ruling that out? Group wisdom greatly appreciated! (IMG:style_emoticons/default/pray.gif) Thanks! Will check them out. Thought (?) I heard a bit of a clunk under or on the left side of the car a few miles before it started happening. The boot from the firewall is in place as is the cap on the transmission casing. Firewall bushing? If so, just cut the wall of the new one at 45 degrees & slip it on the shift rod. Then push it into the firewall (from the engine well). |
StarBear |
Jul 3 2021, 08:54 PM
either you broke a bushing, have a loose set screw, or the nut for the splined rod at the back of the shift lever has loosened Doing shakedown runs getting ready for the NE Gathering. (IMG:style_emoticons/default/driving.gif) All of a sudden 2nd gear is hard to find 2/3 of the time (resulting in grinding, presumably with reverse) and sometimes 4th is hard to find. Had a new JM West shifter put in this past Fall, replacing all bushings etc. Shifter in need of an adjustment? Clutch seems fine but not ruling that out? Group wisdom greatly appreciated! (IMG:style_emoticons/default/pray.gif) Thanks! Will check them out. Thought (?) I heard a bit of a clunk under or on the left side of the car a few miles before it started happening. The boot from the firewall is in place as is the cap on the transmission casing. Nice idea. Will investigate. Firewall bushing? If so, just cut the wall of the new one at 45 degrees & slip it on the shift rod. Then push it into the firewall (from the engine well). |
Dr Evil |
Jul 8 2021, 11:15 AM
Send me your transmission! Group: Members Posts: 23,034 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Man, I hope this is external. That would be simple and painless. If not, we can see what needs done. Some internal failures will do this and sometimes upgrading externals forces internals to fail faster than they already were.
StarBear |
Jul 8 2021, 12:03 PM
In the operating room now. Will report ASAP. Should be minor such as screw or bushing.
john77 |
Jul 8 2021, 12:29 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
I just went through this, shifter was catching reverse instead of going into second from first... and 4th was really hard to find no matter how much I tried to adjust the shift pattern.
Turned out the set screw between the shift rod and shift linkage just after the firewall bushing had backed out. |
StarBear |
Jul 8 2021, 02:11 PM
I just went through this, shifter was catching reverse instead of going into second from first... and 4th was really hard to find no matter how much I tried to adjust the shift pattern. Turned out the set screw between the shift rod and shift linkage just after the firewall bushing had backed out. Thanks! Am hoping that's all it is. (IMG:style_emoticons/default/idea.gif) |
StarBear |
Jul 15 2021, 01:23 PM
Resolution! Both bushings in the shifter coupling by the firewall. One toast, the other gone. They were ok last year when the shifter was replaced. Go figure. Vroom vroom! On to the NE Gathering (and rain festival, apparently).
Lo-Fi Version | Time is now: 26th December 2024 - 05:52 PM |
